Serviio on Nexetna, FreeNAS?
• Page 1 of 1
I use Nexenta (which is OpenSolaris) on my NAS and looking for a DLNA server. Is it possible to build serviio for Nexenta? I can contribute to this.
Re: Serviio on Nexetna, FreeNAS?
Looks like I posted on the wrong board. Sorry for that
Zip (on holiday) will answer you for serviio, but first, could you make a ffmpeg build on Nexetna?
FFmpeg can not currently be compiled on OpenSolaris (see link below)
http://opensolaris.org/jive/thread.jspa ... eID=312902
I'll give a try to build ffmpeg on nexenta , is there a list of other libraries that are necessary for serviio?
The opensolaris link is 2008 and there are suggestion just to use up to date gcc so I believe ffmpeg could be built on opensolaris
For latest serviio 0.6.2 under windows OS, Zip used a gcc 4.4.2 and following ffmpeg configuration:
configuration:
--enable-static
--disable-shared
--disable-ffplay
--disable-ffserver
--enable-memalign-hack
--enable-libmp3lame
--enable-librtmp
--extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm'
--arch=x86
--enable-runtime-cpudetect
--enable-pthreads
--target-os=mingw32
--cross-prefix=i686-mingw32-
--pkg-config=pkg-config
libavutil 51. 11. 0 / 51. 11. 0
libavcodec 53. 8. 0 / 53. 8. 0
libavformat 53. 6. 0 / 53. 6. 0
libavdevice 53. 2. 0 / 53. 2. 0
libavfilter 2. 25. 0 / 2. 25. 0
libswscale 2. 0. 0 / 2. 0. 0
configuration:
--enable-static
--disable-shared
--disable-ffplay
--disable-ffserver
--enable-libmp3lame
--enable-librtmp
--arch=x86
--enable-pthreads
--target-os=mingw32
Thanks, will try tonight..
Illico wrote:For latest serviio 0.6.2 under windows OS, Zip used a gcc 4.4.2 and following ffmpeg configuration:
configuration:
--enable-static
--disable-shared
--disable-ffplay
--disable-ffserver
--enable-libmp3lame
--enable-librtmp
--arch=x86
--enable-pthreads
--target-os=mingw32
That's for the Windows build. Especiallly the stuff around extra-libs.
You'll also need Java 1.6.
Petr
Help translate Serviio
I built it successfully without librtpm and libmp3lame. Where shall I get sources for the libs?
boris_kaminer wrote:I built it successfully without librtpm and libmp3lame. Where shall I get sources for the libs?
lame is on the serviio donwload page.
librtmp - google for rtmpdump
Petr
Thank you
Is any of x264 or h264 codecs included into ffmpeg or they could be included just like rtmp or lame libraries?
ffmpeg can decode h264 by default, encoding is not needed for Serviio but you can link x264 library if you need it for something else
Petr
Finally, I've managed to build everything except FLV. It runs fine on Nexenta.
But it's appeared that combination of serviio and Panasonic TX-VT30 cannot show 1080p movies as smooth as needed. Frames are dropped, sound becomes distorted.
The problem could be either in NAS hadware (slow CPU) or in TV itself.
So I dropped the idea and continue to use DUNE with NAS.
• Page 1 of 1
Users browsing this forum: Google [Bot] and 15 guests
