Samsung PS50B650 not recognised by Serviio
Peterh
Post Fri Jun 11, 2010 4:18 pm
I have a Samsung PS50B650 currently running Tversity - and having issue with basic .avs not being able to play on TV - have installed Serviio - but Serviio
is not even being recognised as an available server - have tried all available settings in Serio - any hints ???
Post Fri Jun 11, 2010 8:30 pm
Re: Samsung PS50B650 not recognised by Serviio
enter the IP address your server is on to the Bound IP address box in the UI
Peterh
Post Sun Jun 13, 2010 1:13 pm
zip wrote:enter the IP address your server is on to the Bound IP address box in the UI
Thanks Zip but not being a Geek/Savy please explain in more detail what all that jagon means please
ie. "Server" - "IP address" - "Bound IP" - "UI" [/Quote]
Peter
Post Sun Jun 13, 2010 2:02 pm
Each network card in your PC has given IP arddress which identifies it on the network (format is like 123.123.123.123). Serviio tries to guess what card is used to connect to the player device, and if you have more (e.g. wi-fi and cable) it might be the wrong one.
So try to enter the IP address of the card you use to connect to your home network and enter it into Bound IP address field in Serviio console.
List of your IP addresses can be obtained by executing:
cmd.exe
and then in the cmd window type:
ipconfig
It'll list the network adapters, find the one that is used and get its IPv4 value.
Return to User experiences
