Can't find my serviio media server on the Sony Bravia TV
fobatem
Post Wed Jul 27, 2011 11:15 am
I have a terrible problem with my KDL-60EX705. It isn't possible to connect from the TV to the Server and I don't know why. I set up a Serviio server on a win 7 system x86. I shut down the firewall on this system. But it woulndt work.
The network status on my TV shows OK so i think the tv is ready to recieve the Serviio server.
Here i will post my Log. mybe someone can help me with my Problem.
Thx you for all your posts.
Greetings Flo
LOG:
2011-07-27 12:05:45,005 INFO  [RestletServer] Starting Restlet server exposed on localhost:23423
2011-07-27 12:05:45,345 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-07-27 12:05:50,443 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2011-07-27 12:05:51,184 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-07-27 12:05:51,564 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-07-27 12:05:51,855 INFO  [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-07-27 12:05:51,945 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-07-27 12:05:52,085 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-07-27 12:05:52,165 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-07-27 12:05:52,426 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2011-07-27 12:05:52,476 INFO  [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-07-27 12:05:52,796 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-07-27 12:05:53,317 INFO  [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-07-27 12:05:53,457 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-07-27 12:05:53,557 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-07-27 12:05:55,870 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-07-27 12:05:56,061 INFO  [WebServer] Socket buffer set to 65535 bytes
2011-07-27 12:05:57,122 INFO  [WebServer] WebServer starting on port 8895
2011-07-27 12:05:58,164 INFO  [Device] Created UPnP Device with UUID: 89970f24-d514-3c4f-af1c-197d54f2ebd0, bound address: 10.1.117.28
2011-07-27 12:05:58,935 INFO  [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-07-27 12:05:59,255 INFO  [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-07-27 12:05:59,315 INFO  [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-07-27 12:05:59,315 INFO  [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-07-27 12:05:59,325 INFO  [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-07-27 12:05:59,325 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-07-27 12:05:59,325 INFO  [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1311764759325, LastAccessTime = 1311764759325, getTimeToLiveSeconds() = -1, createTime = 1311764759325 ]
2011-07-27 12:05:59,325 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-07-27 12:05:59,586 INFO  [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-07-27 12:05:59,586 INFO  [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-07-27 12:05:59,586 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-07-27 12:05:59,586 INFO  [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-07-27 12:05:59,586 INFO  [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-07-27 12:05:59,586 INFO  [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-07-27 12:05:59,586 INFO  [CompositeCacheConfigurator] Finished configuration in 301 ms.
2011-07-27 12:05:59,596 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-07-27 12:05:59,652 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-07-27 12:05:59,653 INFO  [EventDispatcher] Starting EventDispatcher
2011-07-27 12:05:59,706 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Intel(R) PRO/100 VE-Netzwerkverbindung) and address 10.1.117.28, timeout = 0
2011-07-27 12:05:59,846 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2011-07-27 12:05:59,846 INFO  [RendererSearchSender] Searching for Renderer devices
2011-07-27 12:06:05,044 INFO  [ServiioConsole] Starting Serviio Console
2011-07-27 12:06:06,696 INFO  [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-07-27 12:06:12,715 INFO  [Messages] Loaded console message bundle for locale: en
2011-07-27 12:06:14,087 INFO  [Messages] Loaded console message bundle for locale: de
2011-07-27 12:06:14,207 INFO  [UpdateChecker] Checking if a new version is available
2011-07-27 12:06:26,825 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-07-27 12:06:26,835 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-07-27 12:06:40,403 INFO  [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-07-27 12:06:41,122 INFO  [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: de
2011-07-27 12:09:49,524 WARN  [EventDispatcher] Error 400 received from event subscriber
2011-07-27 12:12:15,163 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-07-27 12:12:15,313 INFO  [WebServer] WebServer shutting down
2011-07-27 12:12:15,313 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-07-27 12:12:15,313 INFO  [EventDispatcher] Leaving EventDispatcher
2011-07-27 12:12:15,413 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2011-07-27 12:12:20,103 INFO  [RendererExpirationChecker] Leaving RendererExpirationChecker
2011-07-27 12:13:13,139 INFO  [MediaServer] ------------------------------------------------------------------------
2011-07-27 12:13:13,169 INFO  [MediaServer] Serviio DLNA media streaming server v 0.5.2 (rev. 4e3210bd9ff3)
2011-07-27 12:13:13,169 INFO  [MediaServer] Petr Nejedly 2009-2011
2011-07-27 12:13:13,169 INFO  [MediaServer] http://www.serviio.org
2011-07-27 12:13:13,169 INFO  [MediaServer] Java 1.6.0_26-Sun Microsystems Inc.
2011-07-27 12:13:13,169 INFO  [MediaServer] OS Windows 7 x86 6.1
2011-07-27 12:13:13,169 INFO  [MediaServer] File encoding: windows-1252
2011-07-27 12:13:13,169 INFO  [MediaServer] ------------------------------------------------------------------------
2011-07-27 12:13:13,940 INFO  [RestletServer] Starting Restlet server exposed on localhost:23423
2011-07-27 12:13:14,141 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-07-27 12:13:22,573 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2011-07-27 12:13:23,234 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-07-27 12:13:23,564 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-07-27 12:13:23,765 INFO  [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-07-27 12:13:23,865 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-07-27 12:13:24,015 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-07-27 12:13:24,085 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-07-27 12:13:24,335 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2011-07-27 12:13:24,395 INFO  [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-07-27 12:13:24,706 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-07-27 12:13:25,237 INFO  [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-07-27 12:13:25,377 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-07-27 12:13:25,467 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-07-27 12:13:26,418 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-07-27 12:13:26,529 INFO  [WebServer] Socket buffer set to 65535 bytes
2011-07-27 12:13:26,709 INFO  [WebServer] WebServer starting on port 8895
2011-07-27 12:13:27,340 INFO  [Device] Created UPnP Device with UUID: 7577a094-f8a2-32ec-9d58-1c20fb826d32, bound address: 192.168.2.100
2011-07-27 12:13:27,500 INFO  [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-07-27 12:13:27,550 INFO  [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-07-27 12:13:27,550 INFO  [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-07-27 12:13:27,560 INFO  [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-07-27 12:13:27,560 INFO  [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-07-27 12:13:27,560 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-07-27 12:13:27,560 INFO  [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1311765207560, LastAccessTime = 1311765207560, getTimeToLiveSeconds() = -1, createTime = 1311765207560 ]
2011-07-27 12:13:27,560 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-07-27 12:13:27,590 INFO  [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-07-27 12:13:27,590 INFO  [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-07-27 12:13:27,590 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-07-27 12:13:27,590 INFO  [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-07-27 12:13:27,590 INFO  [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-07-27 12:13:27,590 INFO  [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-07-27 12:13:27,590 INFO  [CompositeCacheConfigurator] Finished configuration in 40 ms.
2011-07-27 12:13:27,600 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-07-27 12:13:27,662 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2011-07-27 12:13:27,672 INFO  [RendererSearchSender] Searching for Renderer devices
2011-07-27 12:13:27,682 INFO  [EventDispatcher] Starting EventDispatcher
2011-07-27 12:13:27,682 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-07-27 12:13:27,692 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Intel(R) PRO/100 VE-Netzwerkverbindung) and address 192.168.2.100, timeout = 0
2011-07-27 12:13:54,841 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-07-27 12:13:54,851 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-07-27 12:15:14,740 INFO  [RendererManager] Stored a new renderer: uuid='d4f2288a-6033-47a1-b952-d3c12da5422c', name = 'Unrecognized device', ipAddress='192.168.2.100', profile = '1'
2011-07-27 12:16:40,222 INFO  [ServiioConsole] Starting Serviio Console
2011-07-27 12:16:41,135 INFO  [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-07-27 12:16:43,343 INFO  [Messages] Loaded console message bundle for locale: en
2011-07-27 12:16:44,467 INFO  [Messages] Loaded console message bundle for locale: de
2011-07-27 12:16:44,588 INFO  [UpdateChecker] Checking if a new version is available
2011-07-27 12:16:53,365 INFO  [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-07-27 12:16:54,254 INFO  [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: de
2011-07-27 12:18:45,736 INFO  [WebServer] WebServer shutting down
2011-07-27 12:18:45,736 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-07-27 12:18:45,737 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-07-27 12:18:45,737 INFO  [EventDispatcher] Leaving EventDispatcher
2011-07-27 12:18:46,238 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2011-07-27 12:18:47,260 INFO  [RendererSearchSender] Searching for Renderer devices
2011-07-27 12:18:47,300 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Intel(R) PRO/100 VE-Netzwerkverbindung) and address 192.168.2.100, timeout = 0
2011-07-27 12:18:47,300 INFO  [EventDispatcher] Starting EventDispatcher
2011-07-27 12:18:47,300 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-07-27 12:18:47,300 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-07-27 12:18:47,300 INFO  [WebServer] WebServer starting on port 8895
2011-07-27 12:18:47,880 INFO  [RendererExpirationChecker] Leaving RendererExpirationChecker
2011-07-27 12:21:02,781 INFO  [RendererManager] Stored a new renderer: uuid='9840fc9c-25f2-4cb4-8d77-d22acf13f1db', name = 'sony', ipAddress='192.168.2.4', profile = '9'
2011-07-27 12:21:02,796 INFO  [WebServer] WebServer shutting down
2011-07-27 12:21:02,797 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-07-27 12:21:02,797 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-07-27 12:21:02,797 INFO  [EventDispatcher] Leaving EventDispatcher
2011-07-27 12:21:03,380 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2011-07-27 12:21:03,390 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-07-27 12:21:03,390 INFO  [RendererSearchSender] Searching for Renderer devices
2011-07-27 12:21:03,411 INFO  [WebServer] WebServer starting on port 8895
2011-07-27 12:21:03,446 INFO  [EventDispatcher] Starting EventDispatcher
2011-07-27 12:21:03,451 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Intel(R) PRO/100 VE-Netzwerkverbindung) and address 192.168.2.100, timeout = 0
2011-07-27 12:21:03,452 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-07-27 12:24:15,246 INFO  [ServiioConsole] Leaving Serviio Console
2011-07-27 12:24:15,391 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-07-27 12:24:15,509 INFO  [WebServer] WebServer shutting down
2011-07-27 12:24:15,509 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-07-27 12:24:15,510 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-07-27 12:24:15,510 INFO  [EventDispatcher] Leaving EventDispatcher
2011-07-27 12:24:16,002 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2011-07-27 12:24:16,002 INFO  [DatabaseManager] Shutting down database
2011-07-27 12:24:16,262 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-07-27 12:24:24,954 INFO  [ServiioConsole] Starting Serviio Console
2011-07-27 12:24:25,045 INFO  [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-07-27 12:24:32,605 WARN  [ServiioConsole] Cannot connect to the server to get DB initialization info
2011-07-27 12:24:39,926 WARN  [ServiioConsole] Cannot connect to server: Communication Error (1001) - Connection refused: connect
2011-07-27 12:24:39,926 INFO  [Messages] Loaded console message bundle for locale: en
2011-07-27 12:24:47,156 WARN  [ServiioConsole] Cannot connect to server: Communication Error (1001) - Connection refused: connect
2011-07-27 12:24:55,488 INFO  [ServiioConsole] Leaving Serviio Console
2011-07-27 12:25:13,654 INFO  [ServiioConsole] Starting Serviio Console
2011-07-27 12:25:13,725 INFO  [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-07-27 12:25:21,145 WARN  [ServiioConsole] Cannot connect to the server to get DB initialization info
2011-07-27 12:25:28,376 WARN  [ServiioConsole] Cannot connect to server: Communication Error (1001) - Connection refused: connect
2011-07-27 12:25:28,376 INFO  [Messages] Loaded console message bundle for locale: en
2011-07-27 12:25:31,861 INFO  [MediaServer] ------------------------------------------------------------------------
2011-07-27 12:25:31,861 INFO  [MediaServer] Serviio DLNA media streaming server v 0.5.2 (rev. 4e3210bd9ff3)
2011-07-27 12:25:31,861 INFO  [MediaServer] Petr Nejedly 2009-2011
2011-07-27 12:25:31,861 INFO  [MediaServer] http://www.serviio.org
2011-07-27 12:25:31,861 INFO  [MediaServer] Java 1.6.0_26-Sun Microsystems Inc.
2011-07-27 12:25:31,861 INFO  [MediaServer] OS Windows 7 x86 6.1
2011-07-27 12:25:31,861 INFO  [MediaServer] File encoding: windows-1252
2011-07-27 12:25:32,001 INFO  [RestletServer] Starting Restlet server exposed on localhost:23423
2011-07-27 12:25:32,081 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-07-27 12:25:32,361 INFO  [UpdateChecker] Checking if a new version is available
2011-07-27 12:25:34,643 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2011-07-27 12:25:35,302 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-07-27 12:25:35,789 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-07-27 12:25:35,990 INFO  [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-07-27 12:25:36,135 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-07-27 12:25:36,346 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-07-27 12:25:36,510 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-07-27 12:25:36,945 INFO  [WebServer] Socket buffer set to 65535 bytes
2011-07-27 12:25:36,946 INFO  [Device] Created UPnP Device with UUID: 7577a094-f8a2-32ec-9d58-1c20fb826d32, bound address: 192.168.2.100
2011-07-27 12:25:36,980 INFO  [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-07-27 12:25:36,986 INFO  [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-07-27 12:25:36,990 INFO  [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-07-27 12:25:36,990 INFO  [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-07-27 12:25:36,992 INFO  [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-07-27 12:25:36,992 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-07-27 12:25:36,992 INFO  [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1311765936992, LastAccessTime = 1311765936992, getTimeToLiveSeconds() = -1, createTime = 1311765936992 ]
2011-07-27 12:25:37,015 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-07-27 12:25:37,034 INFO  [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-07-27 12:25:37,035 INFO  [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-07-27 12:25:37,035 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-07-27 12:25:37,035 INFO  [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-07-27 12:25:37,035 INFO  [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-07-27 12:25:37,035 INFO  [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-07-27 12:25:37,035 INFO  [CompositeCacheConfigurator] Finished configuration in 46 ms.
2011-07-27 12:25:37,049 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2011-07-27 12:25:37,139 INFO  [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-07-27 12:25:37,549 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-07-27 12:25:38,272 INFO  [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-07-27 12:25:38,461 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-07-27 12:25:38,561 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-07-27 12:25:38,629 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-07-27 12:25:38,673 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-07-27 12:25:38,674 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2011-07-27 12:25:38,674 INFO  [RendererSearchSender] Searching for Renderer devices
2011-07-27 12:25:38,677 INFO  [WebServer] WebServer starting on port 8895
2011-07-27 12:25:38,714 INFO  [EventDispatcher] Starting EventDispatcher
2011-07-27 12:25:38,716 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Intel(R) PRO/100 VE-Netzwerkverbindung) and address 192.168.2.100, timeout = 0
2011-07-27 12:25:38,720 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-07-27 12:25:40,407 INFO  [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-07-27 12:25:41,147 INFO  [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: de
2011-07-27 12:26:05,837 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-07-27 12:26:05,858 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-07-27 12:26:06,027 INFO  [ServiioConsole] Leaving Serviio Console
2011-07-27 12:26:08,690 INFO  [ServiioConsole] Starting Serviio Console
2011-07-27 12:26:08,765 INFO  [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-07-27 12:26:09,477 INFO  [Messages] Loaded console message bundle for locale: en
2011-07-27 12:26:10,176 INFO  [Messages] Loaded console message bundle for locale: de
2011-07-27 12:26:10,294 INFO  [UpdateChecker] Checking if a new version is available
2011-07-27 12:27:21,113 INFO  [WebServer] WebServer shutting down
2011-07-27 12:27:21,113 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-07-27 12:27:21,114 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-07-27 12:27:21,114 INFO  [EventDispatcher] Leaving EventDispatcher
2011-07-27 12:27:21,682 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2011-07-27 12:27:21,684 INFO  [Device] Updated bound IP address of Device with UUID: 7577a094-f8a2-32ec-9d58-1c20fb826d32, bound address: 192.168.2.4
2011-07-27 12:27:21,695 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-07-27 12:27:21,766 INFO  [RendererSearchSender] Searching for Renderer devices
2011-07-27 12:27:21,774 INFO  [EventDispatcher] Starting EventDispatcher
2011-07-27 12:27:21,775 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-07-27 12:27:21,775 INFO  [WebServer] WebServer starting on port 8895
2011-07-27 12:27:23,698 INFO  [RendererExpirationChecker] Leaving RendererExpirationChecker
2011-07-27 12:30:13,960 INFO  [WebServer] WebServer shutting down
2011-07-27 12:30:13,961 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-07-27 12:30:13,961 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-07-27 12:30:13,961 INFO  [EventDispatcher] Leaving EventDispatcher
2011-07-27 12:30:15,052 INFO  [Device] Updated bound IP address of Device with UUID: 7577a094-f8a2-32ec-9d58-1c20fb826d32, bound address: 192.168.2.100
2011-07-27 12:30:15,060 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-07-27 12:30:15,060 INFO  [RendererSearchSender] Searching for Renderer devices
2011-07-27 12:30:15,071 INFO  [WebServer] WebServer starting on port 8895
2011-07-27 12:30:15,115 INFO  [EventDispatcher] Starting EventDispatcher
2011-07-27 12:30:15,118 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Intel(R) PRO/100 VE-Netzwerkverbindung) and address 192.168.2.100, timeout = 0
2011-07-27 12:30:15,121 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-07-27 12:35:16,115 INFO  [RendererManager] Stored a new renderer: uuid='40e5c876-d4b1-4c69-b902-5603b8245721', name = 'Unrecognized device', ipAddress='192.168.2.100', profile = '1'
2011-07-27 12:53:12,114 INFO  [RendererManager] Stored a new renderer: uuid='24f7e133-65ad-4689-a84a-d1a9d8a8f8a1', name = 'test', ipAddress='10.1.110.168', profile = '9'
2011-07-27 12:53:12,120 INFO  [WebServer] WebServer shutting down
2011-07-27 12:53:12,120 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-07-27 12:53:12,120 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-07-27 12:53:12,121 INFO  [EventDispatcher] Leaving EventDispatcher
2011-07-27 12:53:12,663 INFO  [Device] Updated bound IP address of Device with UUID: 7577a094-f8a2-32ec-9d58-1c20fb826d32, bound address: 10.1.110.28
2011-07-27 12:53:12,673 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-07-27 12:53:12,673 INFO  [RendererSearchSender] Searching for Renderer devices
2011-07-27 12:53:12,693 INFO  [WebServer] WebServer starting on port 8895
2011-07-27 12:53:12,759 INFO  [EventDispatcher] Starting EventDispatcher
2011-07-27 12:53:12,759 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-07-27 12:54:55,912 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-07-27 12:54:55,913 INFO  [WebServer] WebServer shutting down
2011-07-27 12:54:55,913 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-07-27 12:54:55,913 INFO  [EventDispatcher] Leaving EventDispatcher
2011-07-27 12:54:57,847 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-07-27 12:54:57,847 INFO  [RendererSearchSender] Searching for Renderer devices
2011-07-27 12:54:57,857 INFO  [WebServer] WebServer starting on port 8895
2011-07-27 12:54:57,927 INFO  [EventDispatcher] Starting EventDispatcher
2011-07-27 12:54:57,937 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-07-27 12:56:29,198 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-07-27 12:56:29,408 INFO  [WebServer] WebServer shutting down
2011-07-27 12:56:29,408 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-07-27 12:56:29,408 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-07-27 12:56:29,408 INFO  [EventDispatcher] Leaving EventDispatcher
2011-07-27 12:56:30,340 INFO  [DatabaseManager] Shutting down database
2011-07-27 12:56:30,730 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-07-27 12:59:14,869 INFO  [MediaServer] ------------------------------------------------------------------------
2011-07-27 12:59:15,119 INFO  [MediaServer] Serviio DLNA media streaming server v 0.5.2 (rev. 4e3210bd9ff3)
2011-07-27 12:59:15,119 INFO  [MediaServer] Petr Nejedly 2009-2011
2011-07-27 12:59:15,119 INFO  [MediaServer] http://www.serviio.org
2011-07-27 12:59:15,119 INFO  [MediaServer] Java 1.6.0_26-Sun Microsystems Inc.
2011-07-27 12:59:15,119 INFO  [MediaServer] OS Windows 7 x86 6.1
2011-07-27 12:59:15,119 INFO  [MediaServer] File encoding: windows-1252
2011-07-27 12:59:15,119 INFO  [MediaServer] ------------------------------------------------------------------------
2011-07-27 12:59:15,620 INFO  [RestletServer] Starting Restlet server exposed on localhost:23423
2011-07-27 12:59:15,920 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-07-27 12:59:20,727 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2011-07-27 12:59:21,328 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-07-27 12:59:21,578 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-07-27 12:59:21,758 INFO  [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-07-27 12:59:21,849 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-07-27 12:59:21,979 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-07-27 12:59:22,049 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-07-27 12:59:22,259 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2011-07-27 12:59:22,309 INFO  [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-07-27 12:59:22,610 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-07-27 12:59:23,100 INFO  [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-07-27 12:59:23,251 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-07-27 12:59:23,351 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-07-27 12:59:24,122 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-07-27 12:59:24,182 INFO  [WebServer] Socket buffer set to 65535 bytes
2011-07-27 12:59:24,332 INFO  [WebServer] WebServer starting on port 8895
2011-07-27 12:59:24,422 INFO  [Device] Created UPnP Device with UUID: 188c29e1-0312-318c-9700-401e6f0babaa, bound address: 10.1.110.28
2011-07-27 12:59:24,572 INFO  [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-07-27 12:59:24,613 INFO  [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-07-27 12:59:24,613 INFO  [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-07-27 12:59:24,613 INFO  [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-07-27 12:59:24,623 INFO  [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-07-27 12:59:24,623 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-07-27 12:59:24,623 INFO  [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1311767964623, LastAccessTime = 1311767964623, getTimeToLiveSeconds() = -1, createTime = 1311767964623 ]
2011-07-27 12:59:24,623 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-07-27 12:59:24,643 INFO  [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-07-27 12:59:24,643 INFO  [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-07-27 12:59:24,643 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-07-27 12:59:24,643 INFO  [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-07-27 12:59:24,643 INFO  [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-07-27 12:59:24,643 INFO  [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-07-27 12:59:24,643 INFO  [CompositeCacheConfigurator] Finished configuration in 30 ms.
2011-07-27 12:59:24,653 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-07-27 12:59:24,653 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-07-27 12:59:24,683 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2011-07-27 12:59:24,750 INFO  [RendererSearchSender] Searching for Renderer devices
2011-07-27 12:59:24,759 INFO  [EventDispatcher] Starting EventDispatcher
2011-07-27 12:59:51,849 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-07-27 12:59:51,859 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-07-27 13:18:42,960 INFO  [ServiioConsole] Starting Serviio Console
2011-07-27 13:18:43,071 INFO  [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-07-27 13:18:46,043 INFO  [Messages] Loaded console message bundle for locale: en
2011-07-27 13:18:46,987 INFO  [Messages] Loaded console message bundle for locale: de
2011-07-27 13:18:47,111 INFO  [UpdateChecker] Checking if a new version is available
2011-07-27 13:19:12,663 INFO  [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-07-27 13:19:13,374 INFO  [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: de
2011-07-27 13:38:27,902 INFO  [RendererManager] Stored a new renderer: uuid='fc5136a6-6a61-467b-88f4-860e3b5fb9a1', name = 'Sony', ipAddress='10.1.117.168', profile = '9'
2011-07-27 13:38:27,931 INFO  [WebServer] WebServer shutting down
2011-07-27 13:38:27,932 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-07-27 13:38:27,933 INFO  [EventDispatcher] Leaving EventDispatcher
2011-07-27 13:38:27,933 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-07-27 13:38:28,504 INFO  [Device] Updated bound IP address of Device with UUID: 188c29e1-0312-318c-9700-401e6f0babaa, bound address: 10.1.117.28
2011-07-27 13:38:28,514 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-07-27 13:38:28,544 INFO  [RendererSearchSender] Searching for Renderer devices
2011-07-27 13:38:28,554 INFO  [EventDispatcher] Starting EventDispatcher
2011-07-27 13:38:28,554 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Intel(R) PRO/100 VE-Netzwerkverbindung) and address 10.1.117.28, timeout = 0
2011-07-27 13:38:28,564 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-07-27 13:38:28,574 INFO  [WebServer] WebServer starting on port 8895
2011-07-27 13:38:30,707 INFO  [RendererExpirationChecker] Leaving RendererExpirationChecker
2011-07-27 13:40:33,959 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-07-27 13:40:34,135 INFO  [WebServer] WebServer shutting down
2011-07-27 13:40:34,135 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-07-27 13:40:34,136 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-07-27 13:40:34,136 INFO  [EventDispatcher] Leaving EventDispatcher
2011-07-27 13:40:35,308 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2011-07-27 13:40:35,308 INFO  [DatabaseManager] Shutting down database
2011-07-27 13:40:35,719 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-07-27 13:42:04,852 INFO  [ServiioConsole] Starting Serviio Console
2011-07-27 13:42:08,047 INFO  [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-07-27 13:42:17,119 WARN  [ServiioConsole] Cannot connect to the server to get DB initialization info
2011-07-27 13:42:24,175 WARN  [ServiioConsole] Cannot connect to server: Communication Error (1001) - Connection refused: connect
2011-07-27 13:42:24,223 INFO  [Messages] Loaded console message bundle for locale: en
2011-07-27 13:42:31,265 WARN  [ServiioConsole] Cannot connect to server: Communication Error (1001) - Connection refused: connect
2011-07-27 13:42:38,856 INFO  [ServiioConsole] Leaving Serviio Console
2011-07-27 13:43:18,466 INFO  [MediaServer] ------------------------------------------------------------------------
2011-07-27 13:43:18,467 INFO  [MediaServer] Serviio DLNA media streaming server v 0.5.2 (rev. 4e3210bd9ff3)
2011-07-27 13:43:18,467 INFO  [MediaServer] Petr Nejedly 2009-2011
2011-07-27 13:43:18,467 INFO  [MediaServer] http://www.serviio.org
2011-07-27 13:43:18,467 INFO  [MediaServer] Java 1.6.0_26-Sun Microsystems Inc.
2011-07-27 13:43:18,467 INFO  [MediaServer] OS Windows 7 x86 6.1
2011-07-27 13:43:18,467 INFO  [MediaServer] File encoding: windows-1252
2011-07-27 13:43:18,467 INFO  [MediaServer] ------------------------------------------------------------------------
2011-07-27 13:43:18,685 INFO  [RestletServer] Starting Restlet server exposed on localhost:23423
2011-07-27 13:43:18,780 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-07-27 13:43:23,491 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2011-07-27 13:43:24,127 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-07-27 13:43:24,371 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-07-27 13:43:24,548 INFO  [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-07-27 13:43:24,642 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-07-27 13:43:24,775 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-07-27 13:43:24,857 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-07-27 13:43:25,071 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2011-07-27 13:43:25,121 INFO  [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-07-27 13:43:25,429 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-07-27 13:43:25,940 INFO  [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-07-27 13:43:26,073 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-07-27 13:43:26,167 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-07-27 13:43:26,608 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-07-27 13:43:26,656 INFO  [WebServer] Socket buffer set to 65535 bytes
2011-07-27 13:43:26,844 INFO  [WebServer] WebServer starting on port 8895
2011-07-27 13:43:26,902 INFO  [Device] Created UPnP Device with UUID: 89970f24-d514-3c4f-af1c-197d54f2ebd0, bound address: 10.1.117.28
2011-07-27 13:43:27,046 INFO  [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-07-27 13:43:27,096 INFO  [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-07-27 13:43:27,100 INFO  [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-07-27 13:43:27,101 INFO  [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-07-27 13:43:27,102 INFO  [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-07-27 13:43:27,102 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-07-27 13:43:27,103 INFO  [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1311770607102, LastAccessTime = 1311770607102, getTimeToLiveSeconds() = -1, createTime = 1311770607102 ]
2011-07-27 13:43:27,105 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-07-27 13:43:27,141 INFO  [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-07-27 13:43:27,142 INFO  [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-07-27 13:43:27,142 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-07-27 13:43:27,142 INFO  [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-07-27 13:43:27,142 INFO  [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-07-27 13:43:27,142 INFO  [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-07-27 13:43:27,142 INFO  [CompositeCacheConfigurator] Finished configuration in 43 ms.
2011-07-27 13:43:27,154 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-07-27 13:43:27,155 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-07-27 13:43:27,199 INFO  [EventDispatcher] Starting EventDispatcher
2011-07-27 13:43:27,204 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2011-07-27 13:43:27,204 INFO  [RendererSearchSender] Searching for Renderer devices
2011-07-27 13:43:27,227 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Intel(R) PRO/100 VE-Netzwerkverbindung) and address 10.1.117.28, timeout = 0
2011-07-27 13:43:34,348 INFO  [RendererManager] Stored a new renderer: uuid='4ec8358e-788a-4e5c-9e69-f30918c178fe', name = 'Unrecognized device', ipAddress='10.1.117.28', profile = '1'
2011-07-27 13:43:52,993 INFO  [RendererManager] Stored a new renderer: uuid='45869313-bb12-4533-ab1d-f11e9f62957e', name = 'Windows Media Player', ipAddress='10.1.117.28', profile = '1'
2011-07-27 13:43:54,289 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-07-27 13:43:54,295 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-07-27 13:45:12,652 INFO  [ServiioConsole] Starting Serviio Console
2011-07-27 13:45:12,732 INFO  [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-07-27 13:45:13,831 INFO  [Messages] Loaded console message bundle for locale: en
2011-07-27 13:45:14,592 INFO  [Messages] Loaded console message bundle for locale: de
2011-07-27 13:45:14,712 INFO  [UpdateChecker] Checking if a new version is available
2011-07-27 13:45:34,650 INFO  [ServiioConsole] Leaving Serviio Console
2011-07-27 13:45:40,366 INFO  [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-07-27 13:45:41,209 INFO  [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: de
2011-07-27 13:47:58,024 INFO  [ServiioConsole] Leaving Serviio Console
2011-07-27 13:47:58,170 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-07-27 13:47:58,322 INFO  [WebServer] WebServer shutting down
2011-07-27 13:47:58,323 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-07-27 13:47:58,323 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-07-27 13:47:58,323 INFO  [EventDispatcher] Leaving EventDispatcher
2011-07-27 13:47:58,853 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2011-07-27 13:47:58,855 INFO  [DatabaseManager] Shutting down database
2011-07-27 13:47:59,148 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-07-27 13:51:05,709 INFO  [MediaServer] ------------------------------------------------------------------------
2011-07-27 13:51:05,710 INFO  [MediaServer] Serviio DLNA media streaming server v 0.5.2 (rev. 4e3210bd9ff3)
2011-07-27 13:51:05,710 INFO  [MediaServer] Petr Nejedly 2009-2011
2011-07-27 13:51:05,710 INFO  [MediaServer] http://www.serviio.org
2011-07-27 13:51:05,710 INFO  [MediaServer] Java 1.6.0_26-Sun Microsystems Inc.
2011-07-27 13:51:05,710 INFO  [MediaServer] OS Windows 7 x86 6.1
2011-07-27 13:51:05,710 INFO  [MediaServer] File encoding: windows-1252
2011-07-27 13:51:05,710 INFO  [MediaServer] ------------------------------------------------------------------------
2011-07-27 13:51:05,848 INFO  [RestletServer] Starting Restlet server exposed on localhost:23423
2011-07-27 13:51:05,911 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-07-27 13:51:07,642 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2011-07-27 13:51:08,143 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-07-27 13:51:08,373 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-07-27 13:51:08,512 INFO  [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-07-27 13:51:08,605 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-07-27 13:51:08,738 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-07-27 13:51:08,815 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-07-27 13:51:09,031 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2011-07-27 13:51:09,081 INFO  [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-07-27 13:51:09,581 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-07-27 13:51:10,137 INFO  [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-07-27 13:51:10,270 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-07-27 13:51:10,365 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-07-27 13:51:10,429 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-07-27 13:51:10,449 INFO  [WebServer] Socket buffer set to 65535 bytes
2011-07-27 13:51:10,529 INFO  [WebServer] WebServer starting on port 8895
2011-07-27 13:51:10,557 INFO  [Device] Created UPnP Device with UUID: 89970f24-d514-3c4f-af1c-197d54f2ebd0, bound address: 10.1.117.28
2011-07-27 13:51:10,656 INFO  [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-07-27 13:51:10,677 INFO  [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-07-27 13:51:10,684 INFO  [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-07-27 13:51:10,684 INFO  [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-07-27 13:51:10,685 INFO  [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-07-27 13:51:10,686 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-07-27 13:51:10,686 INFO  [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1311771070686, LastAccessTime = 1311771070686, getTimeToLiveSeconds() = -1, createTime = 1311771070686 ]
2011-07-27 13:51:10,688 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-07-27 13:51:10,708 INFO  [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-07-27 13:51:10,709 INFO  [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-07-27 13:51:10,709 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-07-27 13:51:10,709 INFO  [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-07-27 13:51:10,709 INFO  [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-07-27 13:51:10,709 INFO  [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-07-27 13:51:10,709 INFO  [CompositeCacheConfigurator] Finished configuration in 27 ms.
2011-07-27 13:51:10,728 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-07-27 13:51:10,822 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Intel(R) PRO/100 VE-Netzwerkverbindung) and address 10.1.117.28, timeout = 0
2011-07-27 13:51:11,367 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-07-27 13:51:11,368 INFO  [EventDispatcher] Starting EventDispatcher
2011-07-27 13:51:11,368 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2011-07-27 13:51:11,368 INFO  [RendererSearchSender] Searching for Renderer devices
2011-07-27 13:51:38,020 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-07-27 13:51:38,049 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-07-27 13:52:08,372 INFO  [ServiioConsole] Starting Serviio Console
2011-07-27 13:52:08,450 INFO  [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-07-27 13:52:09,456 INFO  [Messages] Loaded console message bundle for locale: en
2011-07-27 13:52:10,144 INFO  [Messages] Loaded console message bundle for locale: de
2011-07-27 13:52:10,263 INFO  [UpdateChecker] Checking if a new version is available
2011-07-27 13:52:25,118 INFO  [ServiioConsole] Leaving Serviio Console
2011-07-27 13:52:35,084 INFO  [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-07-27 13:52:35,919 INFO  [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: de
2011-07-27 13:52:47,997 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-07-27 13:52:48,195 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-07-27 13:52:48,202 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-07-27 13:53:25,645 INFO  [LibraryManager] Forcing metadata update for 'VIDEO' media files
2011-07-27 13:53:33,084 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-07-27 13:53:33,092 INFO  [WebServer] WebServer shutting down
2011-07-27 13:53:33,093 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-07-27 13:53:33,093 INFO  [EventDispatcher] Leaving EventDispatcher
2011-07-27 13:53:33,633 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2011-07-27 13:53:34,589 INFO  [RendererSearchSender] Searching for Renderer devices
2011-07-27 13:53:34,632 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Intel(R) PRO/100 VE-Netzwerkverbindung) and address 10.1.117.28, timeout = 0
2011-07-27 13:53:34,634 INFO  [EventDispatcher] Starting EventDispatcher
2011-07-27 13:53:34,635 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-07-27 13:53:34,635 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-07-27 13:53:34,635 INFO  [WebServer] WebServer starting on port 8895
2011-07-27 13:53:36,442 INFO  [RendererExpirationChecker] Leaving RendererExpirationChecker
2011-07-27 13:55:57,191 INFO  [RendererManager] Stored a new renderer: uuid='ccb02a5a-5139-4a4c-b701-c9472c8d8bec', name = 'Sony', ipAddress='10.1.117.168', profile = '9'
2011-07-27 13:55:57,197 INFO  [WebServer] WebServer shutting down
2011-07-27 13:55:57,197 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-07-27 13:55:57,197 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-07-27 13:55:57,198 INFO  [EventDispatcher] Leaving EventDispatcher
2011-07-27 13:55:57,780 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2011-07-27 13:55:57,790 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-07-27 13:55:57,790 INFO  [RendererSearchSender] Searching for Renderer devices
2011-07-27 13:55:57,810 INFO  [WebServer] WebServer starting on port 8895
2011-07-27 13:55:57,838 INFO  [EventDispatcher] Starting EventDispatcher
2011-07-27 13:55:57,838 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Intel(R) PRO/100 VE-Netzwerkverbindung) and address 10.1.117.28, timeout = 0
2011-07-27 13:55:57,848 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-07-27 13:56:04,447 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-07-27 13:56:04,658 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-07-27 13:56:04,668 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-07-27 13:58:38,201 INFO  [RendererManager] Stored a new renderer: uuid='137d545c-fc95-4dc9-bff8-2189213dc624', name = 'Unrecognized device', ipAddress='10.1.117.28', profile = '1'
Post Wed Jul 27, 2011 12:36 pm
Re: Can't find my serviio media server on the Sony Bravia TV
Its difficult to understand your log, IP address always change...
what are
10.1.117.28
192.168.2.100 ?
192.168.2.4 Sony ?
Suggest to fix all IP address
- Router 192.168.1.1 (look at the DHCP router configuration, DHCP area start from something like 192.168.1.20 to 192.168.1.255)
- PC with Serviio 192.168.1.2 on the Ethernet Interface used to stream (wired is preferred), if the PC use a second Ethernet interface (wifi,etc.), set the IP bound field on serviio console with the proper value 192.168.1.2.
- TV Sony 192.168.1.3
- other 192.168.1.4 .. 192.168.1.19
Device with automatic IP mecanism will have 192.168.1.20 to 192.168.1.255
All IP maks are 255.255.255.0 and DNS with 192.168.1.1(router)
fobatem
Post Wed Jul 27, 2011 1:16 pm
Hello Illico,
thx for your verry fast support.
I have changed all my network configs to them which you told me.
192.168.2.1 router Gateway and DHCP
192.168.2.2 Servio PC an I bound this adress at the console.
192.168.2.3 Bravia TV KDL-60E705
192.168.2.4 second PC.
But all changes have no effect.
In the console of serviio the TV isn't listed, so i have to add it manually.
Here is my new logfile:
2011-07-27 16:00:13,930 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-07-27 16:00:13,931 INFO  [WebServer] WebServer shutting down
2011-07-27 16:00:13,931 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-07-27 16:00:13,931 INFO  [EventDispatcher] Leaving EventDispatcher
2011-07-27 16:00:15,534 INFO  [RendererSearchSender] Searching for Renderer devices
2011-07-27 16:00:15,534 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-07-27 16:00:15,534 INFO  [WebServer] WebServer starting on port 8895
2011-07-27 16:00:15,605 INFO  [EventDispatcher] Starting EventDispatcher
2011-07-27 16:00:15,615 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-07-27 16:01:34,026 INFO  [RendererManager] Stored a new renderer: uuid='f105df9b-0cc4-4e2c-a336-a7356b9cb7c5', name = 'Sony', ipAddress='192.168.1.3', profile = '9'
2011-07-27 16:01:34,047 INFO  [WebServer] WebServer shutting down
2011-07-27 16:01:34,048 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-07-27 16:01:34,048 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-07-27 16:01:34,048 INFO  [EventDispatcher] Leaving EventDispatcher
2011-07-27 16:01:34,601 INFO  [Device] Updated bound IP address of Device with UUID: 89970f24-d514-3c4f-af1c-197d54f2ebd0, bound address: 192.168.1.2
2011-07-27 16:01:34,611 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-07-27 16:01:34,611 INFO  [RendererSearchSender] Searching for Renderer devices
2011-07-27 16:01:34,611 INFO  [WebServer] WebServer starting on port 8895
2011-07-27 16:01:34,664 INFO  [EventDispatcher] Starting EventDispatcher
2011-07-27 16:01:34,665 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Intel(R) PRO/100 VE-Netzwerkverbindung) and address 192.168.1.2, timeout = 0
2011-07-27 16:01:34,665 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-07-27 16:02:54,648 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-07-27 16:02:54,649 INFO  [WebServer] WebServer shutting down
2011-07-27 16:02:54,649 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-07-27 16:02:54,649 INFO  [EventDispatcher] Leaving EventDispatcher
2011-07-27 16:02:55,131 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2011-07-27 16:02:58,937 INFO  [RendererSearchSender] Searching for Renderer devices
2011-07-27 16:02:58,947 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-07-27 16:02:58,947 INFO  [WebServer] WebServer starting on port 8895
2011-07-27 16:02:58,995 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Intel(R) PRO/100 VE-Netzwerkverbindung) and address 192.168.1.2, timeout = 0
2011-07-27 16:02:58,995 INFO  [EventDispatcher] Starting EventDispatcher
2011-07-27 16:02:58,996 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-07-27 16:04:06,706 INFO  [ServiioConsole] Leaving Serviio Console
2011-07-27 16:04:16,177 INFO  [ServiioConsole] Starting Serviio Console
2011-07-27 16:04:16,252 INFO  [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-07-27 16:04:16,959 INFO  [Messages] Loaded console message bundle for locale: en
2011-07-27 16:04:17,676 INFO  [Messages] Loaded console message bundle for locale: de
2011-07-27 16:04:17,793 INFO  [UpdateChecker] Checking if a new version is available
2011-07-27 16:04:29,056 INFO  [ServiioConsole] Leaving Serviio Console
2011-07-27 16:04:37,223 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-07-27 16:04:37,224 INFO  [WebServer] WebServer shutting down
2011-07-27 16:04:37,224 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-07-27 16:04:37,224 INFO  [EventDispatcher] Leaving EventDispatcher
2011-07-27 16:04:37,706 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2011-07-27 16:04:39,038 INFO  [RendererSearchSender] Searching for Renderer devices
2011-07-27 16:04:39,038 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-07-27 16:04:39,038 INFO  [WebServer] WebServer starting on port 8895
2011-07-27 16:04:39,088 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Intel(R) PRO/100 VE-Netzwerkverbindung) and address 192.168.1.2, timeout = 0
2011-07-27 16:04:39,088 INFO  [EventDispatcher] Starting EventDispatcher
2011-07-27 16:04:39,089 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
Post Wed Jul 27, 2011 1:20 pm
fobatem wrote:...
Good start, but still have 10.1.117.28 in the log file, what is this device?
On the router Gateway DHCP, what are the options (IP range, start IP, end IP,etc)?
Do you have a firewall on your PC with serviio? Make sure you open TCP 8895 and UDP 1900 ports in firewall.
Clear the serviio console device list and restart serviio service.
fobatem
Post Wed Jul 27, 2011 1:28 pm
That was the ip Adress of my first network.
But the network did no longer exist.
The firewall of my win7 x86 pc is off for all 3 kinds of networks.
so the Port 8895 an udo1900 can pass through.
I cleared the Serviio console and restarted the Service but nothing changed!
Should i set up a new Windows7? But this thing i did early this morning.
fobatem
Post Wed Jul 27, 2011 1:36 pm
I forgot one thing to say.
I tried nearly 15 differential servers and i got no connection.
Post Wed Jul 27, 2011 2:09 pm
fobatem wrote:...I tried nearly 15 differential servers and i got no connection.
like PS3 Media Server, Windows Media Server ?
On sony menu:
http://support.sony-europe.com/tvhc/ima ... 705&s=SM16
Home --> Network --> Renderer
"Renderer Function" enable
"Renderer Access Control" to on
Home --> Network --> Renderer Set-up
"Automatic Access Permission" enable
Home --> Network --> Server Diagnostics
fobatem
Post Wed Jul 27, 2011 8:30 pm
Sorry for beeing late i had a meeting with the head of our firm.
Yes for example nero media, twonky, ps3, windowsmediaserver, wildserver .....
But the tv cant see anything.
Thax for that post i have all funktion enabled and disabled but nothing happened.
At the moment i enabled all like you wrote in that post bevore.
Thx for the massive support.
Maybe we can fix the problem i hope!
Nice evening, see you tomorrow!
Post Thu Jul 28, 2011 7:11 am
Could you try direct RJ45 connection between PC and TV. Check your cable connection too.
fobatem
Post Thu Jul 28, 2011 10:45 am
Good afternoon,
I tried it and it works very well!
The problem i had was definetly the switch!
Sony Bravia isn't able to connect with inmac isg-1008II Switch
For the final test i choose a cisco switch and it works perfeclty.
Thx a lot for the support.
I wish you a nice weekend!
Greetings Florian
