Setting up Serviio on my Synology DS110J NAS
Post Mon Feb 07, 2011 9:05 pm
Re: Setting up Serviio on my Synology DS110J NAS
It's weird as we're telling the JVM to have max heap memory 384MB (-Xmx384M). Maybe there are some other memory tuning options for this particular JVM.
mbnu99
Post Thu Jul 28, 2011 1:39 pm
I'm experiencing a similar issue with my Synology DS211 it appears when serviio is running java takes up 53% of the available 256mb memory, is this to be expected?
When library is refreshing it completely trashes the system from a CPU perspective and takes memory to 80% used, it's impossible to stream anything then. . . I've been unable to change the 5 minutes interval to anything else as when I change to, say, 240 minutes and click save the page eventually just comes up with the white cross in the big red circle. . . a nice feature to have would be to only update the library during user selectable hours. . . overnight would be good :D
Post Sat Jul 30, 2011 6:02 am
Read minimal spec on the web page. It can go up to 380MB, depending if you have some large images in the library.
99 minutes is the maximum I think
For now you can set up a cron job with a curl command to the REST API. Search the forum (third-party tools integration)
Previous
