Fastforward not working on LN32C550
goras
Post Fri Jul 29, 2011 6:05 pm
Actually FF works, but when I try to play avi/mkv's at 2x/4x/etc speed I get something like "function not available". If I reproduce the same file through the USB with a pendrive, 2x/4x/etc speed works fine.
Is this only for my TV or a Serviio general thing for all the Renders?
Can I make this work via Serviio the same way as through USB?
Thanks,
Post Fri Jul 29, 2011 6:39 pm
Re: Fastforward not working on LN32C550
This topic has ben covered many many many times on these forums please use the search box before posting in future.
goras wrote:Actually FF works, but when I try to play avi/mkv's at 2x/4x/etc speed I get something like "function not available". If I reproduce the same file through the USB with a pendrive, 2x/4x/etc speed works fine.
Is this only for my TV or a Serviio general thing for all the Renders? FFwd and RWD and done by pressing the < and > buttons on your remote and not the << and >> buttons.
Can I make this work via Serviio the same way as through USB? USB and DLNA are completely different and CAN NOT be compared.
Thanks,
goras
Post Sat Jul 30, 2011 6:00 pm
Thank you Cerberus.
So DLNA doesn't support the << and >> buttons?
Post Sat Jul 30, 2011 6:03 pm
goras wrote:Thank you Cerberus.
only as page up and down when browsing through the menus :)
