Roku transcoding profile?
hozedhead
Post Sat Jul 30, 2011 4:33 pm
Re: Roku transcoding profile?
Here's one more example:
Complete name                    : C:\Documents and Settings\All Users\Documents\TV Shows\The Pacific\The Pacific 08.avi
Format                           : AVI
Format/Info                      : Audio Video Interleave
File size                        : 550 MiB
Duration                         : 55mn 58s
Overall bit rate                 : 1 374 Kbps
Writing application              : transcode-1.0.2
Format                           : MPEG-4 Visual
Format profile                   : Advanced Simple@L5
Format settings, BVOP            : 2
Format settings, QPel            : No
Format settings, GMC             : No warppoints
Format settings, Matrix          : Default (H.263)
Codec ID                         : XVID
Codec ID/Hint                    : XviD
Duration                         : 55mn 58s
Bit rate                         : 1 231 Kbps
Width                            : 624 pixels
Height                           : 352 pixels
Frame rate                       : 23.976 fps
Bits/(Pixel*Frame)               : 0.234
Stream size                      : 493 MiB (90%)
Writing library                  : XviD 1.2.1 (UTC 2008-12-04)
Format                           : MPEG Audio
Format version                   : Version 1
Format profile                   : Layer 3
Mode                             : Joint stereo
Mode extension                   : MS Stereo
Codec ID                         : 55
Codec ID/Hint                    : MP3
Duration                         : 55mn 58s
Bit rate mode                    : Variable
Bit rate                         : 128 Kbps
Channel(s)                       : 2 channels
Stream size                      : 52.4 MiB (10%)
Alignment                        : Aligned on interleaves
Interleave, duration             : 24 ms (0.58 video frame)
Writing library                  : LAME3.96r
Encoding settings                : -m j -V 4 -q 3 -lowpass 17.5 --abr 128
served up like this:
Complete name                    : C:\Documents and Settings\owner\Local Settings\temp\plex-transcode-5bdf2b07-9b42-443e-834b-adb275ab08d4\media-00194.ts
Format                           : MPEG-TS
File size                        : 658 KiB
Duration                         : 5s 839ms
Overall bit rate                 : 903 Kbps
Menu ID                          : 1 (0x1)
Format profile                   : Baseline@L3.0
Format settings, CABAC           : No
Format settings, ReFrames        : 1 frame
Codec ID                         : 27
Duration                         : 3s 816ms
Width                            : 624 pixels
Height                           : 352 pixels
Frame rate mode                  : Variable
Menu ID                          : 1 (0x1)
Format                           : AAC
Format/Info                      : Advanced Audio Codec
Format version                   : Version 4
Format profile                   : LC
Muxing mode                      : ADTS
Codec ID                         : 15
Duration                         : 5s 845ms
Channel positions                : Front: L R
Delay relative to video          : -155ms
Menu
Menu ID                          : 1 (0x1)
Duration                         : 5s 839ms
List                             : 256 (0x100) (AVC) / 257 (0x101) (AAC)
Service name                     : Service01
Service provider                 : FFmpeg
Service type                     : digital television
Post Sat Jul 30, 2011 4:42 pm
exactly its transcoding it to mpegTS container with AVC video and AAC audio and not actualy on the fly streaming in MP4 video.
<Video targetContainer="mpegts" targetVCodec="avc" targetACodec="aac">
but i dont think zip has added AVC video support yet to serviio for this to work
hozedhead
Post Sat Jul 30, 2011 5:12 pm
2011-07-30 10:05:06,281 ERROR [XmlUtils] XML Profiles.xsd didn't pass validation, reason: cvc-enumeration-valid: Value 'avc' is not facet-valid with respect to enumeration '[mpeg2video, wmv2]'. It must be a value from the enumeration.
2011-07-30 10:05:06,281 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: org.serviio.profile.ProfilesDefinitionException: Profiles XML file is not valid (according to the schema). Check the log.
Yeah, you're right the server didn't load with the avc. Here's the roku profile that didn't work:
<Profile id="14" name="Roku" extendsProfileId="1">
                 <Matches container="avi" />
                 <Matches container="flv" />
                 <Matches container="wtv" />
               <Audio targetContainer="mp3" aBitrate="320">
                  <Matches container="lpcm" />
                  <Matches container="flac" />
                  <Matches container="ogg" />
                  <Matches container="mp4" />
Hopefully this will be addressed in a future update.
hozedhead
Post Sat Jul 30, 2011 5:26 pm
mp3 @320 works great, though. I'm curious, does the console have to be on for that to work? This morning I had the console off and tried to listen to some flac files and it stalled without playing them.
Post Sat Jul 30, 2011 5:47 pm
hozedhead wrote:mp3 @320 works great, though. I'm curious, does the console have to be on for that to work? This morning I had the console off and tried to listen to some flac files and it stalled without playing them.
Nope console can be off, it is purely just an interface to the service :)
Previous
Users browsing this forum: Bing [Bot] and 80 guests
