Proper Serviio Shutdown Routine using FreeNAS
LLoyd
Post Fri Jul 29, 2011 5:20 pm
I have Serviio running on FreeNAS.
Should I add a FreeNAS "Shutdown" script with the following command: "sh /serviio-0.5.2/bin/serviio.sh -stop" ...to properly shutdown the Serviio server or will FreeNaS properly shutdown the Serviio server when the user selects "Reboot" or "Shutdown" from the FreeNAS "System" menu?
Another question: How would I know (or how could I check) if FreeNAS shutdown the Serviio server properly? What log should I be looking at and what entries would tell me if the Serviio server shutdown "correctly"?
Currently, I have no script running on FreeNAS to properly shutdown the Serviio server. I just shutdown FreeNAS (using the FreeNAS web-based configuration utility) and it just terminates the Serviio server? I'm hoping that's good enough. Should I use the following command instead: "sh /serviio-0.5.2/bin/serviio.sh -stop"?
Thanks, Lloyd
Post Fri Jul 29, 2011 5:33 pm
Re: Proper Serviio Shutdown Routine using FreeNAS
i would say it would be fine without a shutdown script but then adding one wont hurt either.
Post Sat Jul 30, 2011 2:50 am
There is a hook that gets executed when Serviio process quits. This will not work if you kill the process with kill -9 for example or just shutdown the PC. The hook code basically sends notification to the network that Serviio is no longer available, clear any transcoded files and shuts down the database properly.
Nothing terrible happens if you just kill the process, only startup will be slightly slower due to the database check/fix.
LLoyd
Post Sat Jul 30, 2011 7:03 pm
zip,
What do you suggest I use for a FreeNAS "Shutdown" script to graceful shutdown your program?
Please tell me what would be best. Create a new script for shutdown and not not use the serviio.sh script, or use the command (below) and use a different parameter other than "-stop".
sh /serviio-0.5.2/bin/serviio.sh <fill in the blank of what I should use to shutdown your program gracefully>
Post Sun Jul 31, 2011 2:12 am
serviio.sh -stop is the proper way.
Users browsing this forum: Baidu [Spider] and 2 guests
