Samsung B Series .avi audio data not supported
kamalsyal
Post Sun Jul 31, 2011 4:59 pm
Hello, First of all many many thanks for creating the best media server software on the planet ! Its really simple and intuitive.
I have a Samsung B Series TV (LN52B750U1F) and have ripped some movies to .avi format using daniusoft dvd ripper. When I try to play this on my Samsung TV, I am able to see the video but the TV reports "Not Supported Audio Data".
I also have a Sony KDL-60EX700 and the file plays perfectly well on that. Here is some info on the file:
ffmpeg output:
C:\Users\Public\Videos>ffmpeg -i "alladin_1.avi"
686-mingw32-
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 0 / 0.16. 0
libavfilter 1.72. 0 / 1.72. 0
libswscale 0.12. 0 / 0.12. 0
Input #0, avi, from 'alladin_1.avi':
Duration: 00:37:18.96, start: 0.000000, bitrate: 7659 kb/s
Stream #0.0: Video: mpeg4, yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], 30 tbr, 30
tbn, 30 tbc
Stream #0.1: Audio: mp3, 48000 Hz, 2 channels, s16, 128 kb/s
GSpot returns the following data for the file:
GSpot Output for the .avi file
Serviio Console for the devices identified and their profiles (I had to change the Samsung profile from Generic DLNA to Samsung TV (B Series)
Hopefully this is a straight forward issue that can be resolved quickly. All of the movies that I have ripped into .avi format has this problem. MKVs work great !!
Thanks in advance for the support and for this wonderful software !!
Post Mon Aug 01, 2011 4:44 am
Re: Samsung B Series .avi audio data not supported
this is a normal divx video and should play. Must be the software you're using. You could set up a trasncoding of mp3 to ac3 to fix this, but it's a bit rubbish ;-/
kamalsyal
Post Mon Aug 01, 2011 2:58 pm
Thanks for the quick response Petr ! Could you point me to how I can setup the transcoding of mp3 to ac3 ? The software I use does not provide me the flexibility to change audio/video formats, although I will try to create like a .wmv and see if that plays !
Thanks again for the help !
