Synolgy 211j and Sony BX37
ryoo1257
Post Thu Aug 04, 2011 12:42 am
Hello to all at the forum,
After a disappointing discovery that my Sony BDP BX37 can only stream mpeg2 via DLNA with my 211j I discovered this site. My question before I dive in and try to install all this is:
1. will I be able to stream .m2ts(home videos) from my NAS thru the BX37 without reformating all file
2. can I install serviio on the NAS and have it work without a PC
Thank you for the help. Look forward to your suggestions.
Post Thu Aug 04, 2011 7:17 am
Re: Synolgy 211j and Sony BX37
ryoo1257 wrote:1. will I be able to stream .m2ts(home videos) from my NAS thru the BX37 without reformating all file
yes, .m2ts file could be delivered in native format from your NAS with serviio to your BX37 renderer.
ryoo1257 wrote:2. can I install serviio on the NAS and have it work without a PC
yes, point you to patter Howto : http://pcloadletter.co.uk/2011/02/07/se ... h-arm-cpu/
also read that
viewtopic.php?f=14&t=1204
viewtopic.php?f=14&t=1731
moderated: topic moved to NAS installation...
ryoo1257
Post Fri Aug 05, 2011 6:27 am
Thank you very much for your reply. OMG, so much to read. :( with work, 3 toddlers running around I'll be lucky if I can even start. BTW, my 211j already has some stuff on there, so am I to assume that when I start installing this stuff my data with get erased? Or will I be able to keep it there without any problems?
Post Fri Aug 05, 2011 10:11 am
ryoo1257 wrote:Thank you very much for your reply. OMG, so much to read. :( with work, 3 toddlers running around I'll be lucky if I can even start. BTW, my 211j already has some stuff on there, so am I to assume that when I start installing this stuff my data with get erased? Or will I be able to keep it there without any problems?
no data should be erased but patters will confirm this as he is teh NAS genie.
ryoo1257
Post Fri Aug 05, 2011 8:03 pm
this forum is great. such timely and concise replies, I love it. Patters if you could confirm the above, thanks!
ryoo1257
Post Wed Aug 10, 2011 4:13 am
Anyone can confirm the non-erasing of data if installing Serviio?
How's everything over there in the UK?
Post Wed Aug 10, 2011 4:21 am
ryoo1257 wrote:Anyone can confirm the non-erasing of data if installing Serviio?
problematic at the moment with the riot i live and work very close to them :(
i see no reason for the serviio install to erase any data from your NAS,( its a program not an OS ) but i would always recommend doing a backup before starting any project liek this :)
patters
Post Wed Aug 10, 2011 7:57 pm
I can confirm you can usually reinstall the DSM software from scratch preserving your data if you mess something up. However it might not always be possible. Apparently the installer does warn you with some red text if it is about to trash everything.
However installing Serviio isn't a destructive process if followed correctly.
