sony smp-n100 no compatible formats
What am I doing wrong?
falconmick wrote:Sony BD Player, there's a orange circle beside it's IP if that's any help
falconmick wrote:plus, why was ffmpeg using 50% of my pc... wouldnt the server be doing that?
I wasn't streaming
Illico wrote:This is probably the library update process (every 5 minute depends on console settings).
You can disable the automatic library update, and set manually when needed.
falconmick wrote:Illico wrote:This is probably the library update process (every 5 minute depends on console settings).
Ive changed the update to daily, and how long should 1-2tb of indexing take? my system ain't crap + I have no way of knowing when it is done... Plus, why is FFMPEG doing the indexing, it is a media library from what I knew.
