Panasonic TC-P42X3 can not play *.avi or divx video files
I was wondering if there was a way to have SERVIIO due the transcoding so that *.avi and divx file would play on that set?
CompleteName : \\4EVILSSERVER\Videos\16 Wishes.avi
Format : AVI
FileSize/String : 702 MiB
Duration/String : 1h 30mn
OverallBitRate/String : 1 089 Kbps
Encoded_Application : Nandub v1.0rc2
Encoded_Library/String : Nandub build 1852/release
ID/String : 0
Format : MPEG-4 Visual
Format_Profile : Advanced Simple@L5
Format_Settings_BVOP/String : 1
Format_Settings_QPel/String : No
Format_Settings_GMC/String : No warppoints
Format_Settings_Matrix/String : Default (H.263)
CodecID : XVID
CodecID/Hint : XviD
BitRate/String : 957 Kbps
Width/String : 624 pixels
Height/String : 352 pixels
DisplayAspectRatio/String : 16:9
FrameRate/String : 23.976 fps
ColorSpace : YUV
ChromaSubsampling : 4:2:0
BitDepth/String : 8 bits
ScanType/String : Progressive
Compression_Mode/String : Lossy
Bits-(Pixel*Frame) : 0.182
StreamSize/String : 617 MiB (88%)
Encoded_Library/String : XviD 1.2.1 (UTC 2008-12-04)
ID/String : 1
Format : MPEG Audio
Format_Version : Version 1
Format_Profile : Layer 3
Format_Settings_Mode : Joint stereo
Format_Settings_ModeExtension : MS Stereo
CodecID : 55
CodecID/Hint : MP3
BitRate_Mode/String : Variable
BitRate/String : 120 Kbps
Channel(s)/String : 2 channels
SamplingRate/String : 48.0 KHz
StreamSize/String : 77.1 MiB (11%)
Alignment/String : Aligned on interleaves
Interleave_Duration/String : 24 ms (0.58 video frame)
Interleave_Preload/String : 147 ms
Encoded_Library/String : LAME3.90.
Encoded_Library_Settings : -m j -V 4 -q 2 -lowpass 17.6 --abr 120j22barb wrote:C:\Program Files\Serviio\lib>ffmpeg.exe -i"d:\shares\Videos\4 boxes.avi"
j22barb wrote:Input #0, avi, from 'd:\shares\videos\4 boxes.avi':
Stream #0.0: Video: mpeg4, yuv420p, 624x352 [PAR 1:1 DAR 39:22], 23.98 tbr,23.98 tbn, 23.98 tbc
Stream #0.1: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
<Profile id="12" name="Panasonic Viera" extendsProfileId="1">
<ContentDirectoryMessageBuilder>org.serviio.upnp.service.contentdirectory.PanasonicDLNAMessageBuilder</ContentDirectoryMessageBuilder>
<MediaFormatProfiles>
<!-- Not supported by TC-P42X3 -->
<!-- <MediaFormatProfile mime-type="video/divx">AVI</MediaFormatProfile> -->
</MediaFormatProfiles>
<!-- remux DTS in MKV to AC3 -->
<Matches container="matroska" vCodec="h264" aCodec="dca" />
<!-- Remux all h264 video to MPEG-TS stream -->
<!-- Transcode all other formats not supported -->
<Matches container="asf" />
<Matches container="avi" />
<Audio targetContainer="mp3">
<Matches container="mp4" />
<Matches container="flac" />
<Matches container="ogg" />
</Audio>
</Profile>j22barb wrote:According to the techs at Panasonic the TC-P42X3 can not play *.avi or divx video files. only MKV, MPEG 2, Mpeg 4.
j22barb wrote: When I try to play 1080 movie it breaks up and pixilates.
