Stream .trp files to BDP-S370?
grolschie
Post Sun Aug 07, 2011 9:01 pm
The output from ffmpeg -i:
C:\Program Files\Serviio\lib>ffmpeg.exe -i "K:\PVR\955823405.trp"
  built on Jul 14 2011 22:35:52 with gcc 4.4.2
nfig
Input #0, mpegts, from 'K:\PVR\955823405.trp':
  Duration: 02:30:00.65, start: 62191.666589, bitrate: 9684 kb/s
  Program 897
      service_name    : SBS ONE
      service_provider: SBS
  Program 898
      service_name    : SBS TWO
  Program 899
      service_name    : SBS 3
  Program 900
      service_name    : SBS 4
  Program 901
      service_name    : SBS HD
    Stream #0.0[0x66]: Video: mpeg2video (Main), yuv420p, 1280x720 [PAR 1:1 DAR
16:9], 90000 kb/s, 50 fps, 50 tbr, 90k tbn, 100 tbc
    Stream #0.1[0x67](eng): Audio: mp2, 48000 Hz, stereo, s16, 192 kb/s
    Stream #0.2[0x29](eng): Subtitle: [6][0][0][0] / 0x0006
  Program 910
      service_name    : SBS Radio 1
  Program 911
      service_name    : SBS Radio 2
The codecs will vary depending on the channel, but most should be playable by the Sony BDP-S370 without transcoding i.e. are codecs that the device can play when told it's an .avi file. How can I configure Serviio to recognize these please?
Thanks in advance.
Post Sun Aug 07, 2011 9:51 pm
Re: Stream .trp files with 0.6 beta 2?
rename it to .ts
grolschie
Post Sun Aug 07, 2011 9:57 pm
Thanks zip. I have quite a few of these. Is it possible to manually add the .trp extension somewhere? Thanks.
Post Sun Aug 07, 2011 9:58 pm
no, but I can add it to the code for next version
grolschie
Post Sun Aug 07, 2011 10:03 pm
Brilliant. Thank you very much. :D
I have renamed a few to .ts for now and will test them. These are from a Hyundai AH3110 which is a DVB-T/DVB-S/DVB-S2 USB PVR. So the files will have various codecs and resolutions depending on the source.
grolschie
Post Sun Aug 07, 2011 10:15 pm
No go so far. The files appear in the list, but fail to play.
EDIT: The message on the player is: "The file is corrupt or unsupported".
The error log when adding the 3 files:
2011-08-08 09:59:54,281 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item 955823405.ts
2011-08-08 09:59:54,281 DEBUG [MediaItemDAOImpl] Media item 955823405.ts doesn't exist in DB yet
2011-08-08 09:59:54,296 DEBUG [LibraryAdditionsCheckerThread] File not in Library, will add it
2011-08-08 09:59:54,296 DEBUG [VideoExtractionStrategy] Extracting metadata of video file: K:\PVR\955823405.ts
2011-08-08 09:59:54,296 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: K:\PVR\955823405.ts
2011-08-08 09:59:54,296 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i K:\PVR\955823405.ts
2011-08-08 09:59:54,421 DEBUG [MediaItemDAOImpl] Getting file of media item 3104
2011-08-08 09:59:54,421 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3104) and extractor EMBEDDED
2011-08-08 09:59:54,515 DEBUG [MediaItemDAOImpl] Getting file of media item 3105
2011-08-08 09:59:54,531 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3105) and extractor EMBEDDED
2011-08-08 09:59:54,625 DEBUG [MediaItemDAOImpl] Getting file of media item 3106
2011-08-08 09:59:54,625 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3106) and extractor EMBEDDED
2011-08-08 09:59:54,750 DEBUG [MediaItemDAOImpl] Getting file of media item 3107
2011-08-08 09:59:54,750 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3107) and extractor EMBEDDED
2011-08-08 09:59:54,859 DEBUG [MediaItemDAOImpl] Getting file of media item 3108
2011-08-08 09:59:54,859 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3108) and extractor EMBEDDED
2011-08-08 09:59:54,953 DEBUG [MediaItemDAOImpl] Getting file of media item 3109
2011-08-08 09:59:54,953 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3109) and extractor EMBEDDED
2011-08-08 09:59:55,062 DEBUG [MediaItemDAOImpl] Getting file of media item 3110
2011-08-08 09:59:55,062 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3110) and extractor EMBEDDED
2011-08-08 09:59:55,171 DEBUG [MediaItemDAOImpl] Getting file of media item 3111
2011-08-08 09:59:55,171 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3111) and extractor EMBEDDED
2011-08-08 09:59:55,218 WARN  [VideoExtractionStrategy] Cannot find a valid timestamp in the transport stream packet, setting it to NONE
2011-08-08 09:59:55,234 DEBUG [LibraryManager] Metadata found via extractor EMBEDDED: VideoMetadata [title=955823405, filePath=K:\PVR\955823405.ts, fileSize=10895293652, audioBitrate=192, audioCodec=MP2, audioStreamIndex=1, bitrate=9684, channels=2, container=MPEG2TS, contentType=UNKNOWN, coverImage=null, duration=9000, episodeNumber=null, fps=50, frequency=48000, h264Level=null, h264Profile=null, height=720, seasonNumber=null, seriesName=null, timestampType=NONE, videoBitrate=90000, videoCodec=MPEG2, videoStreamIndex=0, width=1280]
2011-08-08 09:59:55,234 DEBUG [VideoService] Adding video into database: 955823405
2011-08-08 09:59:55,265 DEBUG [MediaItemDAOImpl] Getting file of media item 3112
2011-08-08 09:59:55,265 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3112) and extractor EMBEDDED
2011-08-08 09:59:55,375 DEBUG [MediaItemDAOImpl] Getting file of media item 3113
2011-08-08 09:59:55,375 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3113) and extractor EMBEDDED
2011-08-08 09:59:55,468 DEBUG [MediaItemDAOImpl] Getting file of media item 3114
2011-08-08 09:59:55,484 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3114) and extractor EMBEDDED
2011-08-08 09:59:55,578 DEBUG [MediaItemDAOImpl] Getting file of media item 3115
2011-08-08 09:59:55,593 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3115) and extractor EMBEDDED
2011-08-08 09:59:55,750 DEBUG [MediaItemDAOImpl] Getting file of media item 3116
2011-08-08 09:59:55,750 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3116) and extractor EMBEDDED
2011-08-08 09:59:55,843 DEBUG [GenreDAOImpl] Reading a Genre (name = Unknown)
2011-08-08 09:59:55,859 DEBUG [MediaItemDAOImpl] Getting file of media item 3117
2011-08-08 09:59:55,859 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3117) and extractor EMBEDDED
2011-08-08 09:59:55,875 DEBUG [GenreService] Genre Unknown found
2011-08-08 09:59:55,875 DEBUG [VideoDAOImpl] Creating a new Video (title = 955823405)
2011-08-08 09:59:55,953 DEBUG [MediaItemDAOImpl] Getting file of media item 3118
2011-08-08 09:59:55,953 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3118) and extractor EMBEDDED
2011-08-08 09:59:56,062 DEBUG [MediaItemDAOImpl] Getting file of media item 3119
2011-08-08 09:59:56,062 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3119) and extractor EMBEDDED
2011-08-08 09:59:56,156 DEBUG [MediaItemDAOImpl] Getting file of media item 3120
2011-08-08 09:59:56,187 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3120) and extractor EMBEDDED
2011-08-08 09:59:56,312 DEBUG [MediaItemDAOImpl] Getting file of media item 3121
2011-08-08 09:59:56,312 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3121) and extractor EMBEDDED
2011-08-08 09:59:56,312 DEBUG [PersonDAOImpl] Adding a Person Unknown to media item 4871 as DIRECTOR
2011-08-08 09:59:56,312 DEBUG [PersonDAOImpl] Reading a Person (name = Unknown)
2011-08-08 09:59:56,421 DEBUG [MediaItemDAOImpl] Getting file of media item 3122
2011-08-08 09:59:56,453 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3122) and extractor EMBEDDED
2011-08-08 09:59:56,453 DEBUG [PersonDAOImpl] Checking if person 357 has a role DIRECTOR for media item 4871
2011-08-08 09:59:56,546 DEBUG [MediaItemDAOImpl] Getting file of media item 3123
2011-08-08 09:59:56,562 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3123) and extractor EMBEDDED
2011-08-08 09:59:56,671 DEBUG [MediaItemDAOImpl] Getting file of media item 3124
2011-08-08 09:59:56,671 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3124) and extractor EMBEDDED
2011-08-08 09:59:56,687 DEBUG [PersonDAOImpl] Adding a Person Unknown to media item 4871 as PRODUCER
2011-08-08 09:59:56,687 DEBUG [PersonDAOImpl] Reading a Person (name = Unknown)
2011-08-08 09:59:56,687 DEBUG [PersonDAOImpl] Checking if person 357 has a role PRODUCER for media item 4871
2011-08-08 09:59:56,687 DEBUG [PersonDAOImpl] Adding a Person Unknown to media item 4871 as ACTOR
2011-08-08 09:59:56,687 DEBUG [PersonDAOImpl] Checking if person 357 has a role ACTOR for media item 4871
2011-08-08 09:59:56,703 DEBUG [MetadataDescriptorDAOImpl] Creating a new MetadataDescriptor (type = EMBEDDED, mediaItemId = 4871)
2011-08-08 09:59:56,750 INFO  [LibraryAdditionsCheckerThread] Added file '955823405.ts' (title: 955823405) to Library
2011-08-08 09:59:56,765 DEBUG [LibraryAdditionsCheckerThread] Found file '956792852.ts', checking if it's already in the Library
2011-08-08 09:59:56,765 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item 956792852.ts
2011-08-08 09:59:56,765 DEBUG [MediaItemDAOImpl] Media item 956792852.ts doesn't exist in DB yet
2011-08-08 09:59:56,765 DEBUG [LibraryAdditionsCheckerThread] File not in Library, will add it
2011-08-08 09:59:56,765 DEBUG [VideoExtractionStrategy] Extracting metadata of video file: K:\PVR\956792852.ts
2011-08-08 09:59:56,765 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: K:\PVR\956792852.ts
2011-08-08 09:59:56,765 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i K:\PVR\956792852.ts
2011-08-08 09:59:56,765 DEBUG [MediaItemDAOImpl] Getting file of media item 3125
2011-08-08 09:59:56,765 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3125) and extractor EMBEDDED
2011-08-08 09:59:56,921 DEBUG [MediaItemDAOImpl] Getting file of media item 3126
2011-08-08 09:59:56,937 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3126) and extractor EMBEDDED
2011-08-08 09:59:57,046 DEBUG [MediaItemDAOImpl] Getting file of media item 3127
2011-08-08 09:59:57,046 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3127) and extractor EMBEDDED
2011-08-08 09:59:57,062 WARN  [VideoExtractionStrategy] Cannot find a valid timestamp in the transport stream packet, setting it to NONE
2011-08-08 09:59:57,062 DEBUG [LibraryManager] Metadata found via extractor EMBEDDED: VideoMetadata [title=956792852, filePath=K:\PVR\956792852.ts, fileSize=67557732, audioBitrate=64, audioCodec=MP2, audioStreamIndex=1, bitrate=2036, channels=1, container=MPEG2TS, contentType=UNKNOWN, coverImage=null, duration=265, episodeNumber=null, fps=26.47, frequency=48000, h264Level=null, h264Profile=null, height=576, seasonNumber=null, seriesName=null, timestampType=NONE, videoBitrate=15000, videoCodec=MPEG2, videoStreamIndex=0, width=544]
2011-08-08 09:59:57,062 DEBUG [VideoService] Adding video into database: 956792852
2011-08-08 09:59:57,062 DEBUG [GenreDAOImpl] Reading a Genre (name = Unknown)
2011-08-08 09:59:57,062 DEBUG [GenreService] Genre Unknown found
2011-08-08 09:59:57,062 DEBUG [VideoDAOImpl] Creating a new Video (title = 956792852)
2011-08-08 09:59:57,078 DEBUG [PersonDAOImpl] Adding a Person Unknown to media item 4872 as DIRECTOR
2011-08-08 09:59:57,078 DEBUG [PersonDAOImpl] Reading a Person (name = Unknown)
2011-08-08 09:59:57,078 DEBUG [PersonDAOImpl] Checking if person 357 has a role DIRECTOR for media item 4872
2011-08-08 09:59:57,093 DEBUG [PersonDAOImpl] Adding a Person Unknown to media item 4872 as PRODUCER
2011-08-08 09:59:57,093 DEBUG [PersonDAOImpl] Reading a Person (name = Unknown)
2011-08-08 09:59:57,093 DEBUG [PersonDAOImpl] Checking if person 357 has a role PRODUCER for media item 4872
2011-08-08 09:59:57,093 DEBUG [PersonDAOImpl] Adding a Person Unknown to media item 4872 as ACTOR
2011-08-08 09:59:57,093 DEBUG [PersonDAOImpl] Checking if person 357 has a role ACTOR for media item 4872
2011-08-08 09:59:57,171 DEBUG [MediaItemDAOImpl] Getting file of media item 3128
2011-08-08 09:59:57,171 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3128) and extractor EMBEDDED
2011-08-08 09:59:57,187 DEBUG [MetadataDescriptorDAOImpl] Creating a new MetadataDescriptor (type = EMBEDDED, mediaItemId = 4872)
2011-08-08 09:59:57,187 INFO  [LibraryAdditionsCheckerThread] Added file '956792852.ts' (title: 956792852) to Library
2011-08-08 09:59:57,203 DEBUG [LibraryAdditionsCheckerThread] Found file '990351009.ts', checking if it's already in the Library
2011-08-08 09:59:57,203 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item 990351009.ts
2011-08-08 09:59:57,218 DEBUG [MediaItemDAOImpl] Media item 990351009.ts doesn't exist in DB yet
2011-08-08 09:59:57,218 DEBUG [LibraryAdditionsCheckerThread] File not in Library, will add it
2011-08-08 09:59:57,218 DEBUG [VideoExtractionStrategy] Extracting metadata of video file: K:\PVR\990351009.ts
2011-08-08 09:59:57,218 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: K:\PVR\990351009.ts
2011-08-08 09:59:57,218 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i K:\PVR\990351009.ts
2011-08-08 09:59:57,296 DEBUG [MediaItemDAOImpl] Getting file of media item 3129
2011-08-08 09:59:57,312 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3129) and extractor EMBEDDED
2011-08-08 09:59:57,421 DEBUG [MediaItemDAOImpl] Getting file of media item 3130
2011-08-08 09:59:57,421 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3130) and extractor EMBEDDED
2011-08-08 09:59:57,515 DEBUG [MediaItemDAOImpl] Getting file of media item 3131
2011-08-08 09:59:57,515 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3131) and extractor EMBEDDED
2011-08-08 09:59:57,687 DEBUG [MediaItemDAOImpl] Getting file of media item 3132
2011-08-08 09:59:57,687 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3132) and extractor EMBEDDED
2011-08-08 09:59:57,781 DEBUG [MediaItemDAOImpl] Getting file of media item 3133
2011-08-08 09:59:57,796 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3133) and extractor EMBEDDED
2011-08-08 09:59:57,875 WARN  [VideoExtractionStrategy] Cannot find a valid timestamp in the transport stream packet, setting it to NONE
2011-08-08 09:59:57,875 DEBUG [VideoExtractionStrategy] Retrieving H264 profile/level for file '990351009.ts'
2011-08-08 09:59:57,875 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve H264 header for file: K:\PVR\990351009.ts
2011-08-08 09:59:57,875 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i K:\PVR\990351009.ts -vframes 1 -vcodec copy -f h264 -an pipe:
2011-08-08 09:59:57,890 DEBUG [MediaItemDAOImpl] Getting file of media item 3134
2011-08-08 09:59:57,890 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3134) and extractor EMBEDDED
2011-08-08 09:59:58,031 DEBUG [MediaItemDAOImpl] Getting file of media item 3135
2011-08-08 09:59:58,031 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3135) and extractor EMBEDDED
2011-08-08 09:59:58,187 DEBUG [MediaItemDAOImpl] Getting file of media item 3136
2011-08-08 09:59:58,265 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3136) and extractor EMBEDDED
2011-08-08 09:59:58,312 WARN  [VideoExtractionStrategy] Couldn't resolve H264 profile/level/ref_frames for file '990351009.ts' because Sequence parameter set header was not recognized
2011-08-08 09:59:58,312 DEBUG [LibraryManager] Metadata found via extractor EMBEDDED: VideoMetadata [title=990351009, filePath=K:\PVR\990351009.ts, fileSize=4867069516, audioBitrate=null, audioCodec=AAC, audioStreamIndex=1, bitrate=4402, channels=2, container=MPEG2TS, contentType=UNKNOWN, coverImage=null, duration=8843, episodeNumber=null, fps=57.59, frequency=48000, h264Level=null, h264Profile=null, height=1080, seasonNumber=null, seriesName=null, timestampType=NONE, videoBitrate=null, videoCodec=H264, videoStreamIndex=0, width=1920]
2011-08-08 09:59:58,312 DEBUG [VideoService] Adding video into database: 990351009
2011-08-08 09:59:58,312 DEBUG [GenreDAOImpl] Reading a Genre (name = Unknown)
2011-08-08 09:59:58,312 DEBUG [GenreService] Genre Unknown found
2011-08-08 09:59:58,312 DEBUG [VideoDAOImpl] Creating a new Video (title = 990351009)
2011-08-08 09:59:58,328 DEBUG [PersonDAOImpl] Adding a Person Unknown to media item 4873 as DIRECTOR
2011-08-08 09:59:58,328 DEBUG [PersonDAOImpl] Reading a Person (name = Unknown)
2011-08-08 09:59:58,328 DEBUG [PersonDAOImpl] Checking if person 357 has a role DIRECTOR for media item 4873
2011-08-08 09:59:58,390 DEBUG [MediaItemDAOImpl] Getting file of media item 3137
2011-08-08 09:59:58,406 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3137) and extractor EMBEDDED
2011-08-08 09:59:58,406 DEBUG [PersonDAOImpl] Adding a Person Unknown to media item 4873 as PRODUCER
2011-08-08 09:59:58,406 DEBUG [PersonDAOImpl] Reading a Person (name = Unknown)
2011-08-08 09:59:58,406 DEBUG [PersonDAOImpl] Checking if person 357 has a role PRODUCER for media item 4873
2011-08-08 09:59:58,406 DEBUG [PersonDAOImpl] Adding a Person Unknown to media item 4873 as ACTOR
2011-08-08 09:59:58,406 DEBUG [PersonDAOImpl] Checking if person 357 has a role ACTOR for media item 4873
2011-08-08 09:59:58,421 DEBUG [MetadataDescriptorDAOImpl] Creating a new MetadataDescriptor (type = EMBEDDED, mediaItemId = 4873)
2011-08-08 09:59:58,421 INFO  [LibraryAdditionsCheckerThread] Added file '990351009.ts' (title: 990351009) to Library
The error log when playing the 3 files:
2011-08-08 10:04:53,921 DEBUG [VideoDeliveryEngine] Delivering file '955823405.ts' in native format
2011-08-08 10:04:53,921 DEBUG [MediaItemDAOImpl] Getting file of media item 4871
2011-08-08 10:04:53,921 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 4871) as read
2011-08-08 10:04:53,953 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2011-08-08 10:04:53,953 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 1024
2011-08-08 10:04:53,953 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-08-08 10:04:53,953 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mpeg,Content-Range: bytes 0-1023/10895293652,Content-Length: 1024,Date: Sun, 07 Aug 2011 22:04:53 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.6-SNAPSHOT,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_NA_ISO;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-08-08 10:04:56,375 DEBUG [WebServer] Incoming connection from /192.168.100.60:57672
2011-08-08 10:04:56,406 DEBUG [WebServer] Incoming connection from /192.168.100.60:57673
2011-08-08 10:04:56,468 DEBUG [ResourceTransportRequestHandler] HEAD /resource/4872/MEDIA_ITEM/MPEG_TS_SD_NA_ISO$0 HTTP/1.1, headers = [Host: 192.168.100.1:8895,Accept: */*,getcontentFeatures.dlna.org: 1,X-AV-Physical-Unit-Info: pa="Blu-ray Disc Player",X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="Blu-ray Disc Player"; mv="2.0"]]
2011-08-08 10:04:56,468 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.100.60
2011-08-08 10:04:56,468 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.100.60, Profile=Sony BD Player'
2011-08-08 10:04:56,484 DEBUG [ResourceTransportRequestHandler] Request for resource 4872 and type 'MEDIA_ITEM' received
2011-08-08 10:04:56,484 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 4872 (local)
2011-08-08 10:04:56,484 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 4872)
2011-08-08 10:04:56,484 DEBUG [VideoDAOImpl] Reading a Video (id = 4872)
2011-08-08 10:04:56,484 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 4872, format MPEG_TS_SD_NA_ISO and profile Sony BD Player
2011-08-08 10:04:56,484 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2011-08-08 10:04:56,484 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 67557732,Date: Sun, 07 Aug 2011 22:04:56 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.6-SNAPSHOT,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_NA_ISO;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-08-08 10:04:56,500 DEBUG [ResourceTransportRequestHandler] GET /resource/4872/MEDIA_ITEM/MPEG_TS_SD_NA_ISO$0 HTTP/1.1, headers = [Host: 192.168.100.1:8895,Accept: */*,Range: bytes=0-1023,getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="Blu-ray Disc Player",X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="Blu-ray Disc Player"; mv="2.0"]]
2011-08-08 10:04:56,500 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.100.60
2011-08-08 10:04:56,500 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.100.60, Profile=Sony BD Player'
2011-08-08 10:04:56,500 DEBUG [ResourceTransportRequestHandler] Request for resource 4872 and type 'MEDIA_ITEM' received
2011-08-08 10:04:56,500 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 4872 (local)
2011-08-08 10:04:56,500 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 4872)
2011-08-08 10:04:56,500 DEBUG [VideoDAOImpl] Reading a Video (id = 4872)
2011-08-08 10:04:56,500 DEBUG [VideoDeliveryEngine] Delivering item '4872' for client 'IPAddress=/192.168.100.60, Profile=Sony BD Player'
2011-08-08 10:04:56,500 DEBUG [VideoDeliveryEngine] Delivering file '956792852.ts' in native format
2011-08-08 10:04:56,500 DEBUG [MediaItemDAOImpl] Getting file of media item 4872
2011-08-08 10:04:56,500 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 4872) as read
2011-08-08 10:04:56,500 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.100.60:
2011-08-08 10:04:56,500 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2011-08-08 10:04:56,500 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 1024
2011-08-08 10:04:56,500 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-08-08 10:04:56,500 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mpeg,Content-Range: bytes 0-1023/67557732,Content-Length: 1024,Date: Sun, 07 Aug 2011 22:04:56 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.6-SNAPSHOT,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_NA_ISO;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-08-08 10:04:56,656 DEBUG [ContentDirectory] Browse() called for renderer Sony BD Player (profile 10) with parameters: objectID = V_F#FOL_R8, browseFlag = BrowseDirectChildren, filter = av:mediaClass,dc:title,dc:date,@childCount,upnp:class,res,res@resolution,res@protocolInfo,res@size,res@duration,res@bitrate,res@dlna:ifoFileURI, startIndex = 3, count = 10, sortCriteria =
2011-08-08 10:04:56,656 DEBUG [FolderDAOImpl] Getting number of sub-Folders in folder null
2011-08-08 10:04:56,656 DEBUG [VideoDAOImpl] Retrieving list of videos for folder 699 (from=3, count=10)
2011-08-08 10:04:56,671 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 'root'
2011-08-08 10:04:56,671 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2011-08-08 10:04:56,687 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-08-08 10:04:58,156 DEBUG [WebServer] Incoming connection from /192.168.100.60:57674
2011-08-08 10:04:58,250 DEBUG [ResourceTransportRequestHandler] HEAD /resource/4873/MEDIA_ITEM/AVC_TS_MP_HD_AAC_MULT5_ISO$1 HTTP/1.1, headers = [Host: 192.168.100.1:8895,Accept: */*,getcontentFeatures.dlna.org: 1,X-AV-Physical-Unit-Info: pa="Blu-ray Disc Player",X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="Blu-ray Disc Player"; mv="2.0"]]
2011-08-08 10:04:58,250 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.100.60
2011-08-08 10:04:58,250 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.100.60, Profile=Sony BD Player'
2011-08-08 10:04:58,250 DEBUG [ResourceTransportRequestHandler] Request for resource 4873 and type 'MEDIA_ITEM' received
2011-08-08 10:04:58,250 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 4873 (local)
2011-08-08 10:04:58,250 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 4873)
2011-08-08 10:04:58,250 DEBUG [VideoDAOImpl] Reading a Video (id = 4873)
2011-08-08 10:04:58,250 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 4873, format AVC_TS_MP_HD_AAC_MULT5_ISO and profile Sony BD Player
2011-08-08 10:04:58,250 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2011-08-08 10:04:58,250 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/vnd.dlna.mpeg-tts,Content-Length: 4867069516,Date: Sun, 07 Aug 2011 22:04:58 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.6-SNAPSHOT,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_NA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-08-08 10:04:58,265 DEBUG [ResourceTransportRequestHandler] GET /resource/4873/MEDIA_ITEM/AVC_TS_MP_HD_AAC_MULT5_ISO$1 HTTP/1.1, headers = [Host: 192.168.100.1:8895,Accept: */*,Range: bytes=0-1023,getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="Blu-ray Disc Player",X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="Blu-ray Disc Player"; mv="2.0"]]
2011-08-08 10:04:58,265 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.100.60
2011-08-08 10:04:58,265 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.100.60, Profile=Sony BD Player'
2011-08-08 10:04:58,265 DEBUG [ResourceTransportRequestHandler] Request for resource 4873 and type 'MEDIA_ITEM' received
2011-08-08 10:04:58,265 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 4873 (local)
2011-08-08 10:04:58,265 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 4873)
2011-08-08 10:04:58,265 DEBUG [VideoDAOImpl] Reading a Video (id = 4873)
2011-08-08 10:04:58,265 DEBUG [VideoDeliveryEngine] Delivering item '4873' for client 'IPAddress=/192.168.100.60, Profile=Sony BD Player'
2011-08-08 10:04:58,265 DEBUG [VideoDeliveryEngine] Delivering file '990351009.ts' in native format
2011-08-08 10:04:58,265 DEBUG [MediaItemDAOImpl] Getting file of media item 4873
2011-08-08 10:04:58,265 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 4873) as read
2011-08-08 10:04:58,265 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2011-08-08 10:04:58,265 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 1024
2011-08-08 10:04:58,265 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-08-08 10:04:58,265 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/vnd.dlna.mpeg-tts,Content-Range: bytes 0-1023/4867069516,Content-Length: 1024,Date: Sun, 07 Aug 2011 22:04:58 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.6-SNAPSHOT,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_NA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
Output of ffmpeg -i for the 3 files:
Input #0, mpegts, from 'K:\PVR\955823405.ts':
  Program 897
  Program 898
  Program 899
  Program 900
  Program 901
  Program 910
  Program 911
C:\Program Files\Serviio\lib>ffmpeg.exe -i "K:\PVR\956792852.ts"
nfig
[mpeg2video @ 018dc8e0] mpeg_decode_postinit() failure
    Last message repeated 8 times
[mpegts @ 017d9dc0] max_analyze_duration 5000000 reached at 5016000
Input #0, mpegts, from 'K:\PVR\956792852.ts':
  Duration: 00:04:25.36, start: 14152.641056, bitrate: 2036 kb/s
  Program 209
      service_name    : ERT
      service_provider: D2
    Stream #0.0[0x83d]: Video: mpeg2video (Main), yuv420p, 544x576 [PAR 24:17 DA
R 4:3], 15000 kb/s, 26.47 fps, 25 tbr, 90k tbn, 50 tbc
    Stream #0.1[0x8a1]: Audio: mp2, 48000 Hz, mono, s16, 64 kb/s
  Program 208
      service_name    : TGN
  Program 203
      service_name    : Al Anwar
  Program 205
      service_name    : Oman TV
  Program 204
      service_name    : Abu Dhabi
  Program 202
      service_name    : SUN TV
  Program 206
      service_name    : Kurdsat
  Program 212
      service_name    : Russia Today
  Program 210
      service_name    : TVRI
  Program 201
      service_name    : RTS Belgrade
  Program 211
      service_name    : DUNA
  Program 225
      service_name    : Bangkok FM94
  Program 226
      service_name    : Net 105.8
  Program 223
      service_name    : Emirates FM
  Program 224
      service_name    : Oman Radio
  Program 222
      service_name    : Suryan FM
  Program 228
      service_name    : KISS FM
  Program 227
      service_name    : In Direct Romania
  Program 231
      service_name    : UCB Radio
  Program 221
      service_name    : K Mart Radio 1
  Program 230
      service_name    : K Mart Radio 2
  Program 207
      service_name    : TurkPlus
  Program 232
      service_name    : Radio Beograd
C:\Program Files\Serviio\lib>ffmpeg.exe -i "K:\PVR\990351009.ts"
nfig
[h264 @ 018b9880] non-existing PPS referenced
[h264 @ 018b9880] non-existing PPS 0 referenced
[h264 @ 018b9880] decode_slice_header error
[h264 @ 018b9880] no frame!
[h264 @ 018b9880] mmco: unref short failure
[NULL @ 018c9f40] start time is not set in av_estimate_timings_from_pts
Seems stream 0 codec frame rate differs from container frame rate: 50.00 (50/1)
-> 50.00 (50/1)
Input #0, mpegts, from 'K:\PVR\990351009.ts':
  Duration: 02:27:23.25, start: 54925.746500, bitrate: 4402 kb/s
  Program 1200
      service_name    : TV ONE
      service_provider: TVNZ
    Stream #0.0[0x118]: Video: h264 (Main), yuv420p, 1920x1080 [PAR 1:1 DAR 16:9
], 57.59 fps, 50 tbr, 90k tbn, 50 tbc
    Stream #0.1[0x14a](eng): Audio: aac_latm, 48000 Hz, stereo, s16
    Stream #0.2[0x14f](ita): Audio: aac_latm, 48000 Hz, stereo, s16
    Stream #0.3[0x3ea]: Data: [11][0][0][0] / 0x000B
    Stream #0.4[0x3f2](eng): Subtitle: [6][0][0][0] / 0x0006
    Stream #0.5[0x447](eng): Subtitle: dvbsub (hearing impaired)
  Program 1201
      service_name    : TV2
  Program 1202
      service_name    : U
  Program 1203
      service_name    : TVNZ 7
  Program 1252
      service_name    : Homecast SSU
The ffmpeg seems to have issues with the last file.
grolschie
Post Tue Aug 09, 2011 9:26 pm
So will ffmpeg not be able to play these? Or does the profile for the Sony BDP-S370 need to be modified? Thanks in advance.
Post Tue Aug 09, 2011 9:41 pm
i don't see any errors so it should be playable. Might be the profile, ask in the Sony forum, it should work with 0.5.2 as well (with .ts extnsion)
grolschie
Post Tue Aug 09, 2011 10:05 pm
Thanks zip. No go with the .ts extension. Can this thread be moved to the Sony section please, or should I start a new thread?
Post Tue Aug 09, 2011 10:31 pm
I'll move it
grolschie
Post Tue Aug 09, 2011 10:38 pm
Many thanks. :-)
grolschie
Post Wed Aug 10, 2011 7:36 pm
Re: Stream .trp files?
Can anyone see why these .trp files, renamed to .ts files, would cause the "File is corrupt or unsupported" error on the BDP-S370 please?
pizzaguy541
Post Fri Aug 12, 2011 10:15 am
Re: Stream .trp files to BDP-S370?
You could try renaming the .trp files to a .mpg extension.
If that doesn't work, a freeware program named SUPER is said to work by using it to convert to another format that can be played.
SUPER can be found at this link: http://www.videohelp.com/tools/SUPER
grolschie
Post Sat Aug 13, 2011 12:20 am
Hi. Thanks for that. I tried renaming as .mpg now, and same problem. The files I will be trying to play are:
* 720p MPEG2 with stereo MPEG audio
* 544x576i MPEG2 with mono MPEG audio
* 720p AVC Level 4 with HE-AAC audio
* 1080i AVC Level 4.1 with Dolby Digital 6 channel
VLC doesn't seem to be able to play these. Nero Showtime seems to, but not the HE-AAC audio.
I will try as .avi. I think the player should be able to play these codecs, right? Maybe not the HE-AAC audio though?
I don't really want to transcode the whole lot. If they could be streamed, remuxed or partially transcoded on-the-fly, that would be really cool. Thanks.
UPDATE: renaming to .avi doesn't work either.
Users browsing this forum: Baidu [Spider] and 20 guests
