Panasonic viera G20. Connection to server failed
lalitswain
Post Tue Aug 09, 2011 9:18 pm
My Panny g20 can see serviio. But when click on the serviio it is telling connection to serer failed.
TV is connected to router by wire. and laptop is connected to router by wireless.
It was working fine with my virgin media router. But not working with the new netgear router provided by Orange. Please I need help :cry:
Thanks In advance
logs below.
2011-08-09 22:16:37,964 DEBUG [RepositoryDAOImpl] Marking Repository 1 as scanned with current timestamp
2011-08-09 22:16:58,307 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:2 from address /192.168.0.2:50051
2011-08-09 22:16:58,308 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:2 from address /192.168.0.2:50051
2011-08-09 22:17:14,610 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.0.2:50050
2011-08-09 22:17:14,611 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.0.2:50050
2011-08-09 22:17:14,629 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.0.2:50050
2011-08-09 22:17:14,629 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:2 from address /192.168.0.2:50051
2011-08-09 22:17:14,629 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.0.2:50050
2011-08-09 22:17:17,799 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface net3 (Intel(R) Wireless WiFi Link 4965AGN) and address 192.168.0.3, timeout = 0
2011-08-09 22:17:17,799 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device c5db91ac-54f5-3daa-b7ba-6fea634c26b1
2011-08-09 22:17:19,601 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:10
Post Tue Aug 09, 2011 9:29 pm
Re: Panasonic viera G20. Connection to server failed
check the bound ip for serviio is still correct
lalitswain
Post Tue Aug 09, 2011 9:34 pm
Thanks . But can you please help me how to do that ? I mean what/how to check ?
I can see 2 ip address below renderer profile which is showing red and amber color. and blank in network setting inbound ip address.
Post Tue Aug 09, 2011 9:44 pm
lalitswain wrote:Thanks . But can you please help me how to do that ? I mean what/how to check ?
ok so if the box is empty it should autodetect the ip. Can you find out what the IP of the pc running serviio and enter that in teh bound Ip box and save and restart serviio.
lalitswain
Post Tue Aug 09, 2011 9:51 pm
i did a ipconfig on the laptop. and entered 192.168.0.3 on the bound ip. saved it. restarted the server. But the same issue . :(
Below is the details of ipconfig.
C:\Users\Itika>ipconfig
Windows IP Configuration
Wireless LAN adapter Wireless Network Connection:
Connection-specific DNS Suffix . :
Link-local IPv6 Address . . . . . : fe80::6d0a:b447:5933:f85c%10
IPv4 Address. . . . . . . . . . . : 192.168.0.3
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.0.1
Ethernet adapter Local Area Connection:
Media State . . . . . . . . . . . : Media disconnected
Tunnel adapter Local Area Connection* 6:
Tunnel adapter Local Area Connection* 9:
Tunnel adapter Local Area Connection* 10:
Tunnel adapter Local Area Connection* 13:
Tunnel adapter Local Area Connection* 14:
Post Wed Aug 10, 2011 12:36 am
lalitswain wrote:i did a ipconfig on the laptop. and entered 192.168.0.3 on the bound ip. saved it. restarted the server. But the same issue . :(
restart the whole laptop and try again please.
lalitswain
Post Wed Aug 10, 2011 9:49 am
The issue was due to Firewall setting. It was blocking the request from the media server to access the folder.
The issue is now resolved. :) Thanks
Post Wed Aug 10, 2011 6:52 pm
good to hear you sorted your problem :)
Return to Panasonic
Users browsing this forum: Baidu [Spider] and 10 guests
