Cannot see MP3 files with Sony BDP S470
Cedric
Post Thu Aug 11, 2011 5:30 pm
I have installed serviio on linux (ubuntu 10.04), it's well recognized by my Sony BDP S470, I can see all the directories, and all video files, but I can't see MP3 files, it says 'no readable files' (i think it's the correct translation in english, in french : 'il n'y a pas de fichier lisibles')
I can't also read read an mkv file, it says the file is corrupted, I didn't make any change in the profile.xml.
I've tried mkvinfo on this file, there is no compression.
This is the result of ffmpeg -i on this file :
FFmpeg version SVN-r0.5.1-4:0.5.1-1ubuntu1.1, Copyright (c) 2000-2009 Fabrice Bellard, et al.
configuration: --extra-version=4:0.5.1-1ubuntu1.1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --disable-stripping --disable-vhook --enable-runtime-cpudetect --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --enable-shared --disable-static
libavutil 49.15. 0 / 49.15. 0
libavcodec 52.20. 1 / 52.20. 1
libavformat 52.31. 0 / 52.31. 0
libavdevice 52. 1. 0 / 52. 1. 0
libavfilter 0. 4. 0 / 0. 4. 0
libswscale 0. 7. 1 / 0. 7. 1
built on Mar 31 2011 18:53:20, gcc: 4.4.3
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (48000/1001) -> 24.00 (24/1)
Input #0, matroska, from 'lost-sotw.720p.mkv':
Duration: 01:34:54.68, start: 0.000000, bitrate: N/A
Stream #0.0(eng): Video: h264, yuv420p, 1280x720, PAR 1:1 DAR 16:9, 24 tbr, 1k tbn, 47.95 tbc
Stream #0.1(fre): Audio: dca, 48000 Hz, 5.1, s16
Thank you for helping (and apologize for my english level).
Post Fri Aug 12, 2011 6:50 am
Re: Cannot see MP3 files with Sony BDP S470
Topic moved to Sony section...
Cedric wrote:Hello,
Your are on Linux system, please read http://www.serviio.org/download
Use this http://download.serviio.org/opensource/ ... 303.tar.gz
You also need Lame MP3 Encode http://download.serviio.org/opensource/ ... 8-2.tar.gz
Do you select the proper section in the Sony Xbar Menu: Video for video, Music for Audio, Photo for Images (on the next 0.6 release this will be resolved)?
Cedric wrote:I can't also read read an mkv file, it says the file is corrupted, I didn't make any change in the profile.xml.
I've tried mkvinfo on this file, there is no compression.Thank you for helping (and apologize for my english level).
Could you post MediaInfo result (see signature link)?
Cedric
Post Sat Aug 13, 2011 7:26 am
I tried to install ffmpeg and lame with your source but nothing change ... I still have no files under my folder "music".
See joined file for mediainfo result on my mkv file :
medainfo_mkv.txt
(2.93 KiB) Downloaded 680 times
Users browsing this forum: Google [Bot] and 4 guests
