MTS (MPEG4) Files playable
Daku123
Post Sun Jun 20, 2010 3:45 pm
i need the support of MTS (MPEG4) Files from my Digicam.
Daku123
Post Sun Jun 20, 2010 5:54 pm
Re: MTS (MPEG4) Files playable
The Output from 'ffmpeg -i <mtsfilename>' is...
FFmpeg version SVN-r23012, Copyright (c) 2000-2010 the FFmpeg developers
built on May 3 2010 19:05:24 with gcc 3.4.5 (mingw-vista special r3)
erver --enable-memalign-hack --enable-libmp3lame --enable-w32threads --extra-ldf
lags=-L/static/lib --extra-cflags=-I/static/include
libavutil 50.15. 0 / 50.15. 0
libavcodec 52.66. 0 / 52.66. 0
libavformat 52.62. 0 / 52.62. 0
libavdevice 52. 2. 0 / 52. 2. 0
libswscale 0.10. 0 / 0.10. 0
[mpegts @ 003dcf60]MAX_READ_SIZE:5000000 reached
Seems stream 0 codec frame rate differs from container frame rate: 50.00 (50/1)
-> 50.00 (50/1)
Input #0, mpegts, from '<mtsfilename>':
Duration: 00:05:52.03, start: 0.366667, bitrate: 13954 kb/s
Program 1
Stream #0.0[0x1011]: Video: h264, yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], 50
fps, 50 tbr, 90k tbn, 50 tbc
Stream #0.1[0x1100]: Audio: ac3, 48000 Hz, stereo, s16, 192 kb/s
Post Sun Jun 20, 2010 6:52 pm
That should be supported by Serviio. Up to your player if it supports this file.
Daku123
Post Sun Jun 20, 2010 7:46 pm
I have a Sony TV with DLNA Client.
With another DNLA Server, the TV shows the .mts videos.
With Serviio, the TV show with Videos-->Folders--> <path to file> --> 'not elements available...'
Jpegs und mp3s works perfectly.
Supported media files
* Video: MPEG-1 (.mpg, .mpeg), MPEG-2 PS (.mpg, .mpeg, vob, mod), MPEG-2 TS (.ts, .m2ts), MPEG-4 (.mp4, m4v, mov), AVI (.avi, .divx), Windows Media Video (.wmv, .asf), Matroska (.mkv)
but no .mts file
Post Mon Jun 21, 2010 8:26 am
try to rename the file to .ts
Daku123
Post Tue Jun 22, 2010 5:39 am
No chance :(
.ts, .m4v or mp4
Post Tue Jun 22, 2010 9:04 am
What is your player? The file is definitely supported by Serviio. Also, check serviio.log to see if the file has been added to your library.
Daku123
Post Tue Jun 22, 2010 6:16 pm
The log-File shows only the images. :roll:
Can i view the database with the files?
The TV set is a Sony KDL-52V5800.
Post Tue Jun 22, 2010 11:01 pm
Try turning on detailed log, click Force refresh on Library tab in the console and let it work for a few minutes. Post the log afterwards.
Daku123
Post Fri Sep 17, 2010 7:22 am
Hi Zip,
thanks for the new 0.42 version.
In this version i can rename the .mts files to mp4, avi oder mpg and my Sony Bravia TV can play the files.
Can you implement the indexing of mts files?
Return to Feature requests
Users browsing this forum: No registered users and 94 guests
