Pioneer VSX-921
DD111
Post Mon Aug 15, 2011 12:25 am
Pioneer VSX-921
Hey all,
first of all I would like to thank you zip for your great work!
I am using Serviio with several other devices and bought a Pioneer VSX-921 A/V receiver.
When I try to access Serviio the receiver appends "(not authorized)" to the Serviio's server name.
What's interesting is that when I try to access by pressing ok on the remote control there is no new log entry written. In the forum I read something about a not supported search mode and that Serviio only supports browse mode. Propably that's the point?
The IP adress of the receiver is 192.168.1.107.
2011-08-15 02:18:33,101 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44331
2011-08-15 02:18:33,108 INFO  [MediaServer] ------------------------------------------------------------------------
2011-08-15 02:18:33,108 INFO  [MediaServer] Serviio DLNA media streaming server v 0.5.2 (rev. 4e3210bd9ff3)
2011-08-15 02:18:33,109 INFO  [MediaServer] Petr Nejedly 2009-2011
2011-08-15 02:18:33,109 INFO  [MediaServer] http://www.serviio.org
2011-08-15 02:18:33,109 INFO  [MediaServer] Java 1.6.0_26-Sun Microsystems Inc.
2011-08-15 02:18:33,109 INFO  [MediaServer] OS Windows 7 x86 6.1
2011-08-15 02:18:33,109 INFO  [MediaServer] File encoding: windows-1252
2011-08-15 02:18:33,109 INFO  [MediaServer] ------------------------------------------------------------------------
2011-08-15 02:18:33,251 INFO  [RestletServer] Starting Restlet server exposed on localhost:23423
2011-08-15 02:18:33,325 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-08-15 02:18:33,338 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2011-08-15 02:18:34,880 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2011-08-15 02:18:34,882 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2011-08-15 02:18:34,883 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2011-08-15 02:18:34,884 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2011-08-15 02:18:34,886 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.1.sql' has been run
2011-08-15 02:18:34,887 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.2.sql' has been run
2011-08-15 02:18:34,888 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.sql' has been run
2011-08-15 02:18:34,889 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.1.sql' has been run
2011-08-15 02:18:35,863 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2011-08-15 02:18:35,910 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 1
2011-08-15 02:18:36,385 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-08-15 02:18:36,386 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 2
2011-08-15 02:18:36,874 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-08-15 02:18:36,876 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 3
2011-08-15 02:18:37,083 INFO  [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-08-15 02:18:37,084 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 4
2011-08-15 02:18:37,141 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-08-15 02:18:37,142 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 5
2011-08-15 02:18:37,221 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-08-15 02:18:37,223 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 6
2011-08-15 02:18:37,270 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-08-15 02:18:37,271 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 7
2011-08-15 02:18:37,449 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2011-08-15 02:18:37,450 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 8
2011-08-15 02:18:37,488 INFO  [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-08-15 02:18:37,490 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 9
2011-08-15 02:18:37,802 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-08-15 02:18:37,803 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 10
2011-08-15 02:18:38,232 INFO  [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-08-15 02:18:38,234 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 12
2011-08-15 02:18:38,326 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-08-15 02:18:38,328 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 13
2011-08-15 02:18:38,413 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-08-15 02:18:38,478 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe
2011-08-15 02:18:38,483 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe
2011-08-15 02:18:38,635 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-08-15 02:18:38,642 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2011-08-15 02:18:39,165 INFO  [WebServer] Socket buffer set to 65535 bytes
2011-08-15 02:18:39,385 INFO  [WebServer] WebServer starting on port 8895
2011-08-15 02:18:44,811 INFO  [Device] Created UPnP Device with UUID: 057e814f-d039-3103-87b8-24793c5a6859, bound address: 192.168.1.121
2011-08-15 02:18:44,928 INFO  [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-08-15 02:18:44,961 INFO  [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-08-15 02:18:44,994 INFO  [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-08-15 02:18:44,995 INFO  [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-08-15 02:18:44,997 INFO  [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-08-15 02:18:44,998 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-08-15 02:18:44,998 INFO  [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1313367524998, LastAccessTime = 1313367524998, getTimeToLiveSeconds() = -1, createTime = 1313367524998 ]
2011-08-15 02:18:45,002 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-08-15 02:18:45,033 INFO  [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-08-15 02:18:45,033 INFO  [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-08-15 02:18:45,034 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-08-15 02:18:45,034 INFO  [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-08-15 02:18:45,034 INFO  [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-08-15 02:18:45,034 INFO  [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-08-15 02:18:45,034 INFO  [CompositeCacheConfigurator] Finished configuration in 69 ms.
2011-08-15 02:18:45,037 DEBUG [DiscoveryManager] UPNP device 057e814f-d039-3103-87b8-24793c5a6859 (192.168.1.121) is available
2011-08-15 02:18:45,043 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-08-15 02:18:45,047 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-08-15 02:18:45,048 INFO  [EventDispatcher] Starting EventDispatcher
2011-08-15 02:18:45,100 INFO  [RendererSearchSender] Searching for Renderer devices
2011-08-15 02:18:45,100 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2011-08-15 02:18:45,262 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Realtek RTL8168B/8111B-Familie-PCI-E-Gigabit-Ethernet-NIC (NDIS 6.20)) and address 192.168.1.121, timeout = 0
2011-08-15 02:18:51,177 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Realtek RTL8168B/8111B-Familie-PCI-E-Gigabit-Ethernet-NIC (NDIS 6.20)) and address 192.168.1.121, timeout = 0
2011-08-15 02:18:51,192 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 057e814f-d039-3103-87b8-24793c5a6859
2011-08-15 02:18:51,311 DEBUG [WebServer] Incoming connection from /192.168.1.141:5731
2011-08-15 02:18:51,337 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 057e814f-d039-3103-87b8-24793c5a6859 from 192.168.1.141 (headers = [Host: 192.168.1.121:8895,User-Agent: Mediabolic-IMHTTP/1.8.225])
2011-08-15 02:18:51,337 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.141
2011-08-15 02:18:51,376 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.141
2011-08-15 02:18:51,925 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2011-08-15 02:18:52,863 DEBUG [RendererSearchSender] Multicasting SSDP M-SEARCH using interface eth3 (Realtek RTL8168B/8111B-Familie-PCI-E-Gigabit-Ethernet-NIC (NDIS 6.20)) and address 192.168.1.121, timeout = 0
2011-08-15 02:18:52,864 DEBUG [RendererSearchSender] Sending 1 'm-search' messages
2011-08-15 02:18:52,865 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.121:58877
2011-08-15 02:18:52,874 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.121:58877
2011-08-15 02:18:52,875 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.121:58877
2011-08-15 02:18:53,015 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:10
2011-08-15 02:18:58,865 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2011-08-15 02:19:12,463 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Realtek RTL8168B/8111B-Familie-PCI-E-Gigabit-Ethernet-NIC (NDIS 6.20)) and address 192.168.1.121, timeout = 0
2011-08-15 02:19:12,464 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 057e814f-d039-3103-87b8-24793c5a6859
2011-08-15 02:19:14,264 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:10
2011-08-15 02:19:32,965 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Realtek RTL8168B/8111B-Familie-PCI-E-Gigabit-Ethernet-NIC (NDIS 6.20)) and address 192.168.1.121, timeout = 0
2011-08-15 02:19:32,966 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 057e814f-d039-3103-87b8-24793c5a6859
2011-08-15 02:19:33,591 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:ContentDirectory:1 from address /192.168.1.107:4996
2011-08-15 02:19:33,592 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:microsoft.com:service:X_MS_MediaReceiverRegistrar:1 from address /192.168.1.107:4996
2011-08-15 02:19:33,593 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.107:4996
2011-08-15 02:19:33,593 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANIPConnection:1 from address /192.168.1.107:4996
2011-08-15 02:19:33,594 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-wifialliance-org:device:WFADevice:1 from address /192.168.1.107:4996
2011-08-15 02:19:33,594 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.107:4996
2011-08-15 02:19:34,430 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:ContentDirectory:1 from address /192.168.1.107:4996
2011-08-15 02:19:34,431 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.107:4996
2011-08-15 02:19:34,443 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:microsoft.com:service:X_MS_MediaReceiverRegistrar:1 from address /192.168.1.107:4996
2011-08-15 02:19:34,444 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.107:4996
2011-08-15 02:19:34,445 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANIPConnection:1 from address /192.168.1.107:4996
2011-08-15 02:19:34,446 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-wifialliance-org:device:WFADevice:1 from address /192.168.1.107:4996
2011-08-15 02:19:34,750 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:ContentDirectory:1 from address /192.168.1.107:4996
2011-08-15 02:19:34,751 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.107:4996
2011-08-15 02:19:34,752 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:microsoft.com:service:X_MS_MediaReceiverRegistrar:1 from address /192.168.1.107:4996
2011-08-15 02:19:34,753 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.107:4996
2011-08-15 02:19:34,754 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANIPConnection:1 from address /192.168.1.107:4996
2011-08-15 02:19:34,756 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-wifialliance-org:device:WFADevice:1 from address /192.168.1.107:4996
2011-08-15 02:19:34,767 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:21
2011-08-15 02:19:35,057 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:ContentDirectory:1 from address /192.168.1.107:4996
2011-08-15 02:19:35,058 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.107:4996
2011-08-15 02:19:35,058 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:microsoft.com:service:X_MS_MediaReceiverRegistrar:1 from address /192.168.1.107:4996
2011-08-15 02:19:35,059 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANIPConnection:1 from address /192.168.1.107:4996
2011-08-15 02:19:35,059 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.107:4996
2011-08-15 02:19:35,060 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-wifialliance-org:device:WFADevice:1 from address /192.168.1.107:4996
2011-08-15 02:19:35,170 DEBUG [WebServer] Incoming connection from /192.168.1.107:1025
2011-08-15 02:19:35,170 DEBUG [WebServer] Incoming connection from /192.168.1.107:1026
2011-08-15 02:19:35,171 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 057e814f-d039-3103-87b8-24793c5a6859 from 192.168.1.107 (headers = [Host: 192.168.1.121:8895,Connection: close,User-Agent: Mozilla/4.0 (compatible),Accept: */*])
2011-08-15 02:19:35,171 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.107
2011-08-15 02:19:35,172 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 057e814f-d039-3103-87b8-24793c5a6859 from 192.168.1.107 (headers = [Host: 192.168.1.121:8895,Connection: close,User-Agent: Mozilla/4.0 (compatible),Accept: */*])
2011-08-15 02:19:35,173 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.107
2011-08-15 02:19:35,177 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.107
2011-08-15 02:19:35,178 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.107
2011-08-15 02:19:35,184 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2011-08-15 02:19:35,268 DEBUG [WebServer] Incoming connection from /192.168.1.107:1027
2011-08-15 02:19:35,269 DEBUG [ServiceEventSubscriptionRequestHandler] ServiceEvent subscription request received for service ContentDirectory
2011-08-15 02:19:35,270 DEBUG [ServiceEventSubscriptionRequestHandler] Event subscription registered (uuid=be8055bd-675d-4da2-84dd-1415aef7ab45) for service urn:upnp-org:serviceId:ContentDirectory reporting to http://192.168.1.107:1900/
2011-08-15 02:19:35,603 DEBUG [EventDispatcher] Sending event notification #0 for subscription be8055bd-675d-4da2-84dd-1415aef7ab45 to endpoint http://192.168.1.107:1900/
2011-08-15 02:19:35,662 DEBUG [RequestExecutor] Sending HTTP request to 192.168.1.107:1900
2011-08-15 02:19:35,741 DEBUG [EventDispatcher] Event notification sent and received successfully
2011-08-15 02:19:35,820 DEBUG [WebServer] Incoming connection from /192.168.1.107:1028
2011-08-15 02:19:36,207 DEBUG [WebServer] Incoming connection from /192.168.1.107:1029
2011-08-15 02:19:36,587 DEBUG [WebServer] Incoming connection from /192.168.1.107:1030
2011-08-15 02:19:36,969 DEBUG [WebServer] Incoming connection from /192.168.1.107:1031
2011-08-15 02:19:37,348 DEBUG [RendererManager] Adding renderer Renderer [uuid=5f9ec1b3-ed59-79bb-4530-00e036ee183b, ipAddress=192.168.1.107, name=VSX-921/SYXCN5, profileId=1, manuallyAdded=false] to list of active renderers
2011-08-15 02:19:37,351 DEBUG [WebServer] Incoming connection from /192.168.1.107:1032
2011-08-15 02:19:37,404 DEBUG [WebServer] Incoming connection from /192.168.1.107:1033
2011-08-15 02:19:37,405 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSearchCapabilities"' from 192.168.1.107:
2011-08-15 02:19:37,406 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.107
2011-08-15 02:19:38,173 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-08-15 02:19:38,183 DEBUG [WebServer] Incoming connection from /192.168.1.107:1041
2011-08-15 02:19:38,184 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities"' from 192.168.1.107:
2011-08-15 02:19:38,184 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.107
2011-08-15 02:19:38,390 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-08-15 02:21:01,191 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Realtek RTL8168B/8111B-Familie-PCI-E-Gigabit-Ethernet-NIC (NDIS 6.20)) and address 192.168.1.121, timeout = 0
2011-08-15 02:21:01,192 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 057e814f-d039-3103-87b8-24793c5a6859
2011-08-15 02:21:02,992 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:04
2011-08-15 02:22:13,826 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Realtek RTL8168B/8111B-Familie-PCI-E-Gigabit-Ethernet-NIC (NDIS 6.20)) and address 192.168.1.121, timeout = 0
2011-08-15 02:22:13,827 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 057e814f-d039-3103-87b8-24793c5a6859
2011-08-15 02:22:15,628 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:06
2011-08-15 02:23:20,722 DEBUG [WebServer] Incoming connection from /192.168.1.107:1052
2011-08-15 02:23:20,723 DEBUG [ServiceEventSubscriptionRequestHandler] ServiceEvent renewal request received for service ContentDirectory and subscription uuid:be8055bd-675d-4da2-84dd-1415aef7ab45
2011-08-15 02:23:20,723 DEBUG [ServiceEventSubscriptionRequestHandler] Event subscription renewed for service urn:upnp-org:serviceId:ContentDirectory and subscription be8055bd-675d-4da2-84dd-1415aef7ab45
2011-08-15 02:23:28,678 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Realtek RTL8168B/8111B-Familie-PCI-E-Gigabit-Ethernet-NIC (NDIS 6.20)) and address 192.168.1.121, timeout = 0
2011-08-15 02:23:28,679 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 057e814f-d039-3103-87b8-24793c5a6859
2011-08-15 02:23:30,480 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:01
2011-08-15 02:24:38,158 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Realtek RTL8168B/8111B-Familie-PCI-E-Gigabit-Ethernet-NIC (NDIS 6.20)) and address 192.168.1.121, timeout = 0
2011-08-15 02:24:38,159 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 057e814f-d039-3103-87b8-24793c5a6859
2011-08-15 02:24:39,959 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:28
Thank you very much for any hints regarding this topic.
Cheers from Vienna!
Post Mon Aug 15, 2011 8:52 am
Re: Pioneer VSX-921
Looks like most A/V receivers use the same UPnP software, as the same problem was with Denon and I believe it's been fixed in 0.6
DD111
Post Mon Aug 15, 2011 9:47 am
Re: Pioneer VSX-921
Thanks for the information! Now I am looking forward to 0.6 ;)
Return to User experiences
