Metadatas encoding (��) Probleme on DS710+
mcjeff2002
Post Tue Aug 16, 2011 12:11 pm
Hello, as you can see , I have a litle probleme of encoding with serviio 5.2 on DS710+ :
2011-08-07 11:36:16,688 WARN [LibraryManager] Cannot read metadata of file /volume1/Videos/Series/Cougar Town/Saison 1/15 La mauvaise ��ducation.m4v via extractor EMBEDDED. Mes
2011-08-07 11:36:16,731 WARN [LibraryManager] Cannot read metadata of file /volume1/Videos/Series/Cougar Town/Saison 1/12 Une relation trop s��rieuse.m4v via extractor EMBEDDED
2011-08-07 11:36:16,773 WARN [LibraryManager] Cannot read metadata of file /volume1/Videos/Series/Cougar Town/Saison 1/21 Dr��les de drames.m4v via extractor EMBEDDED. Message:
2011-08-07 11:36:17,43
all characteres with accent are replace by ?? !
I put UTF8 in Java option but that change nothing .
# Setup Serviio specific properties
JAVA_OPTS=”-Djava.net.preferIPv4Stack=true -Dderby.system.home=$SERVIIO_HOME/library -Dserviio.home=$SERVIIO_HOME -Dserviio.remoteHost=192.168.1.100 -Dfile.encoding=UTF-8″
I didn’t found solution on internet
I run on DS710+ on DSM 3.1.
Thanks for your reply !
Post Tue Aug 16, 2011 12:33 pm
Re: Metadatas encoding (��) Probleme on DS710+
trying to find solution here: viewtopic.php?f=5&t=2972
mcjeff2002
Post Thu Aug 18, 2011 1:33 pm
Thank ZIP.
It works for me now !!!
I write a litle tutorial (more clear)
http://www.jfpblog.fr/index.php?post/20 ... ogy-DSM3.1
Jeff
patters
Post Sun Aug 21, 2011 9:45 pm
Hi Jeff, you forgot one small step in your tutorial. You can't run localedef properly without first doing this:
mkdir /usr/lib/locale
mcjeff2002
Post Mon Aug 22, 2011 5:29 pm
Corrected,
Thank you Patters !
Jeff
