Panasonic Viera TXP42VT20E and serviio
spellcaster
Post Wed Aug 17, 2011 11:57 am
I recently bought the TV and trying to stream movies to it through my computer. The serviio cannot play many .avi and .divx files. The .mkv files are played but they stop after every 5 sec or just behave like that they are being buffered and then played and buffered again. Need your help!!
This one is for .avi
C:\Program\Serviio\lib>ffmpeg.exe -i "C:\Documents and Settings\Ägaren\Mina doku
ment\Vuze Downloads\Thundercats - 103 - Ramlak Rising [Oj]\Thundercats - 103 - R
amlak Rising [Oj].avi"
686-mingw32-
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 0 / 0.16. 0
libavfilter 1.72. 0 / 1.72. 0
libswscale 0.12. 0 / 0.12. 0
Seems stream 0 codec frame rate differs from container frame rate: 2997.00 (2997
/1) -> 29.97 (30000/1001)
Input #0, avi, from 'C:\Documents and Settings\─garen\Mina dokument\Vuze Downloa
ds\Thundercats - 103 - Ramlak Rising [Oj]\Thundercats - 103 - Ramlak Rising [Oj]
.avi':
Duration: 00:21:56.44, start: 0.000000, bitrate: 1120 kb/s
Stream #0.0: Video: mpeg4, yuv420p, 720x420 [PAR 1:1 DAR 12:7], 29.97 fps, 2
9.97 tbr, 29.97 tbn, 2997 tbc
Stream #0.1: Audio: mp3, 44100 Hz, 2 channels, s16, 128 kb/s
And this one is for .mkv
ment\Vuze Downloads\Blitz.2011.1080p.MKV.AC3.Eng.NL.Subs.DMT\Blitz.2011.1080p.MK
V.AC3.Eng.NL.Subs.DMT.mkv"
686-mingw32-
[matroska,webm @ 0163ce80] Estimating duration from bitrate, this may be inaccur
ate
Seems stream 0 codec frame rate differs from container frame rate: 48.00 (48/1)
-> 24.00 (48/2)
Input #0, matroska,webm, from 'C:\Documents and Settings\─garen\Mina dokument\Vu
ze Downloads\Blitz.2011.1080p.MKV.AC3.Eng.NL.Subs.DMT\Blitz.2011.1080p.MKV.AC3.E
ng.NL.Subs.DMT.mkv':
Duration: 01:37:01.02, start: 0.000000, bitrate: 640 kb/s
Stream #0.0(eng): Video: h264, yuv420p, 1920x816, PAR 1:1 DAR 40:17, 24 fps,
24 tbr, 1k tbn, 48 tbc
Stream #0.1(eng): Audio: ac3, 48000 Hz, 5.1, s16, 640 kb/s
title : DD5.1
Stream #0.2(dut): Subtitle: [0][0][0][0] / 0x0000
title : Nederlands SRT
Stream #0.3(eng): Subtitle: [0][0][0][0] / 0x0000
title : Engels
I have got similar problems with mpeg-4 format. I can provide details if needed. Secondly when I try to play .mkv my free hard disk starts reducing and sometimes it takes more than 7-8 GB.
It may have a little extra info than needed. But I will be thankful for being patient.
(32.15 KiB) Downloaded 671 times
Post Wed Sep 07, 2011 3:56 pm
Re: Panasonic Viera TXP42VT20E and serviio
spellcaster wrote:Hi, I recently bought the TV and trying to stream movies to it through my computer.
What is the connexion used, hardwire, wifi?
spellcaster wrote:The serviio cannot play many .avi and .divx files.
I suppose you select the proper Panasonic Viera profile, you could read that:
viewtopic.php?f=13&t=3152
spellcaster wrote:The .mkv files are played but they stop after every 5 sec or just behave like that they are being buffered and then played and buffered again. Need your help!!
Probably a network issue.
Return to Panasonic
