Samsung C dosen`t recognize serviio???
Devil Dante
Post Tue Aug 16, 2011 7:35 pm
i`ve got a big problem! I`ve only rebootet my PC and now it seems, that my Samsung UE40C7700 dosen`t recognize serviio as Media-Device! If I try to Use the Media-Player of the TV there is displayed only a message that no device is connected!
Post Wed Aug 17, 2011 8:56 am
Re: Samsung C dosen`t recognize serviio???
search the forum and read the FAQ
Devil Dante
Post Thu Aug 18, 2011 11:14 am
I`ve already tried everything I could find! Bound-Ip-Adresse, Restart serviio and disabled Win7 MediaSharing...
Post Thu Aug 18, 2011 11:45 am
Post your serviio.log file.
And the IP addresses of the TV and the Computer running serviio.
Also what is the brand and model of your router.
Did you recently install any software or drivers?
Devil Dante
Post Thu Aug 18, 2011 12:57 pm
IP addresses:
TV: 192.168.72.20
PC: 192.168.72.26
Router: AVM FritzBox 3370
I`ve nothing changed on the PC! The only thing what`s possible is that the TV auto-updated his Software! But I`m not sure if he really did!
(52.01 KiB) Downloaded 849 times
Post Thu Aug 18, 2011 2:56 pm
IP addresses:
TV: 192.168.72.20
PC: 192.168.72.26
IP address from the serviio.log is 192.168.178.26 I also found in the log that the computer that is running serviio is changing it's IP address. I would recommend that you change the TV and the Interface that you are using on the computer to a static IP Address
[DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Intel(R) 82579V Gigabit Network Connection) and address 192.168.178.26, timeout = 0
Found other device renderers
Stored a new renderer: uuid='ca8198f2-20f3-4179-a4f1-6254debdfb7a', name = 'Unrecognized device', ipAddress='192.168.178.10', profile = '1'
2011-07-27 16:46:25,722 INFO  [RendererManager] Stored a new renderer: uuid='472f00ab-94ba-4929-8b69-a43aa0ae6957', name = 'Windows Media Player', ipAddress='192.168.178.23', profile = '1'
MotoTom
Post Tue Sep 13, 2011 10:49 pm
After running perfectly for a couple of months, I have the same problem. When I press the MEDIA.P button on my remote I now get a message "No external storage device found. Check the connection status." The only thing new is that I moved my office desktop back home.
I have assigned a static IP address (10.10.10.10). My server PC is 10.10.10.100. When I do a network check on the Samsung UN46C6300, I am able to connect to the internet (4 green check marks). I have set the bound IP Address to 10.10.10.10.
My log file is too big to attach (1.3mb).
Any guidance/help is greatly appreciated.
Post Wed Sep 14, 2011 9:42 am
what's the IPO of the PC running serviio? you have to put that in the Bound IP address field.
Post Wed Sep 14, 2011 11:56 am
moltra wrote:IP addresses:
TV: 192.168.72.20
PC: 192.168.72.26
he has 4 network card really!!! that look like VMware or some virtual lan stufff to me and thats what causing the issue serviio cant get the actual ip only a virtual one.
MotoTom wrote:After running perfectly for a couple of months, I have the same problem. When I press the MEDIA.P button on my remote I now get a message "No external storage device found. Check the connection status." The only thing new is that I moved my office desktop back home.
Erm yer set bound IP to the of the computer and NOT the TV. - 10.10.10.100
MotoTom
Post Wed Sep 14, 2011 9:08 pm
Fascinating.
For some reason, the logs showed that Serviio was set to localhost (127.0.0.1) on both my desktop and on my netbook (server).
After putting the computer IP address in the Bound IP Address block ( :oops: ) and restarting Serviio on both machines, they showed up on the Samsung TV,
All is well.
Many thanks.
Visbusy
Post Wed Sep 28, 2011 11:41 am
I am having this problem also, it seems it only works for a while after restarting PC, Router and blue-ray player (Sometimes). It constantly drops out and/or is not recognised, I have put IP of the PC in bound IP address, even tried forwarding serviios ports in firewall. PC and Blu-ray are static. I am using latest update. Whats the difference between stopping server in the console and stopping the actual service ?
I am using:
Avast
Belkin Surf router
Win XP
Samsung BD-C5900
PC: 192.168.2.3
BR: 192.168.2.2
I have attached the log file (If it is the one in c:\program files\serviio\log\serviio.log)
Logfile
(164.91 KiB) Downloaded 779 times
Post Wed Sep 28, 2011 11:04 pm
Please dont hijack old posts
Your issue isnt the same as OP as in he would not detect at all all your is detecting but then loosing connection. first thing i would do i disable the DLNA function of your router as this is the most lieklything to be causing the issue.
mods: can we split this thread please.
Visbusy
Post Thu Sep 29, 2011 10:53 pm
Sorry, thought it was similar.
Thanks for your help - I believe my router (Belkin Surf) doesnt have a DLNA function though ?
Post Thu Sep 29, 2011 10:55 pm
Visbusy wrote:Hi,
yer it does :) " media server " its one of the tryings to be everything router that always cause issues
Visbusy
Post Thu Oct 13, 2011 12:40 am
So it could be the router ? (still cant find the media centre bit in it) Could you recommend another router ?
Post Thu Oct 13, 2011 6:44 am
i have posted this before but i will do it again for you cause i feel generious.
Virgin internet Compatible. ( RJ45 Connection )
http://www.netgear.co.uk/home/products/ ... R4000.aspx <-- best router i have ever used :) HINT HINT
BT internet Compatible. ( ADSL/RJ11 Connection )
http://www.netgear.co.uk/home/products/ ... D3700.aspx <-- million times better than the home hub.
Users browsing this forum: Baidu [Spider] and 8 guests
