crippled content directory on Philips ND2500 (audio only)
Hominidae
Post Fri Aug 19, 2011 8:25 pm
Hi folks,
at first start I'd like to say hello and thank you for that fine piece of software...keep up the good work!
I started to use v0.52 with my Panasonic Viera TV, which appears to get along fine with serviio-server.
Today I discovered that with my other player, a Philips NP2500 (audio only), there is a problem.
This device does not have a profile (yet) within serviio, so I registered it with the default, standard DLNA profile.
With this profile, the content directory / tree displays the first top-level (Artist) on the device, nothing more.
Under that, all my music gets listed as far as I can tell and it plays fine.
However, I'd like to see the other top-level entries activated as well.
..what can I do to fix this?
BTW: I tried my google foo, but failed miserably :roll:
best regards,
Hominidae
Post Sun Aug 21, 2011 8:05 pm
Re: crippled content directory on Philips ND2500 (audio only
if you disable the artists folder in the serviio console is a different folder displayed, if yes then it would seem like the device will only allow 1 top level folder.
Post Mon Aug 22, 2011 10:28 am
or it might be related to the bug we saw on LG devices and should be fixed in 0.6
Post Mon Aug 22, 2011 6:55 pm
zip wrote:or it might be related to the bug we saw on LG devices and should be fixed in 0.6
yep that was my guess but i was taking baby steps to be sure :)
Hominidae
Post Mon Aug 22, 2011 7:09 pm
Cerberus wrote:if you disable the artists folder in the serviio console is a different folder displayed, if yes then it would seem like the device will only allow 1 top level folder.
thanks for the reply...
I will test what you suggested as soon as I can get back to the console...but I can confirm that the device
shows several toplevel folders with other servers just fine (like twonky, mediatomb, minidlna, ps3ms).
I just want to host only one server for all my devices and serviio works best with my TV so far...
Post Mon Aug 22, 2011 7:13 pm
yes we have a feeling it a bug in serviio that ZIP repaired for the new version currently under beta testing status ( 0.6 )
Return to Philips
