Movie Posters on Logitech Revue
aperry
Post Sat Aug 20, 2011 6:27 pm
Re: Movie Posters on Logitech Revue
First, thanks for the great software! I have a Logitech Revue and I have a similar problem. I'm running the Honeycomb beta on the Revue, FWIW. The media player has two main ways to navigate movies: by "folder" and by "videos". The idea is that the Revue indexes all of the media files on the DLNA server and then shows them all to you if you select "videos". There's a great search feature that allows you to type the name of the movie and it very quickly filters the list (on the fly). In this "videos" mode you can see movie art images, however the Serviio doesn't work with "videos" mode. For some reason the Revue can't index the files with Serviio so there is no list of videos in this mode. However it works great with Twonky.
Below is the output from AV Media Controller for the Twonky and from Serviio. if there are any tips for adding a new Serviio profile to get this "videos" mode and the resulting images, that would be awesome! Thanks!
From Twonky:
poperties:
upnp:class - object.item.videoItem.movie
dc:title - Gnomeo & Juliet (2011)
dc:date - 2011-05-21
upnp:genre - Unknown
upnp:album - Gnomeo & Juliet (2011)
upnp:albumArtURI - http://192.168.1.140:9000/disk/defaulta ... le=160x160
Restricted - True
Media Class - object.item.videoItem.movie
Object ID - 0$3$35$49R526
Parent ID - 0$3$35$49
Resource #1:
contentUri - http://192.168.1.140:9000/disk/DLNA-PNM ... 28I526.mkv
duration - 1:23:51
protocolInfo - http-get:*:video/x-matroska:DLNA.ORG_PN=MKV;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=01700000000000000000000000000000
size - 2854213732
From Serviio:
properties
dc:title - Gnomeo & Juliet (2011).mkv
upnp:icon - http://192.168.1.140:8895/resource/752/COVER_IMAGE
upnp:genre - Animation
dc:desciption - Garden gnomes Gnomeo (voice of McAvoy) and Juliet (voice of Blunt) have as many obstacles to overcome as their quasi namesakes when they are caught up in a feud between neighbors. But with plastic pink flamingos and lawnmower races in the mix, can this young couple find lasting happiness?
upnp:rating - Unknown
Restricted - True
Object ID - V_F#FOL_R1$F458$MI598
Parent ID - V_F#FOL_R1$F458$MI598
Resource #1
ContentUri - http://192.168.1.140:8895/resource/598/ ... MATROSKA$0
bitrate - 56000
duration - 1:23:51
protocolInfo - http-get:*:video/x-matroska:DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000
resolution - 1280x688
size - 2854213732
Resource #2
contentUri - http://192.168.1.140:8895/resource/752/COVER_IMAGE
protocolInfo - http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000
resolution - 107x160
jamgold
Post Sat Dec 10, 2011 10:15 pm
I would love to get this working with the new Logitech Revue sw as well (it got pushed to all devices this week I think).
Previous
Return to User experiences
