How can I transcode the frame rate with Serviio ?
wilddog1806
Post Fri Aug 19, 2011 10:13 am
Hi all,
I installed Serviio on a Synology DS211+ (1,6 GHz Marvell Kirkwood, 512MB DDR3 Ram) and it works good so far. The only problem that i have is that I can't view videos with 23,97fps on my Client, because the Client I stream to (or my old TV) need videos with a frame rate of 25fps.
Now I need a configuration that'S transcode or convert the videos to 25fps with Serviio. How can I do this ?
Post Mon Aug 22, 2011 9:54 am
Re: How can I transcode the frame rate with Serviio ?
you can't. It would also play your video faster. You might find a tool to do it offline on the net.
Users browsing this forum: Baidu [Spider] and 7 guests
