Sony BDP-S580 (force transcoding)
sam_1421
Post Tue Aug 23, 2011 3:47 am
I'm looking for a good profile for my BDP-S580. I tried the BDP-S370 profile with no luck ... in fact, with any profile I tried, there are always the same files not working ... but I know they aren't corrupted or something, because PlayOn was playing them fine.
Is there a way I could force transcoding for ALL files? I would use TVMOBiLi when I can, and when I need transcoding, I would use Serviio.
Sam
Post Tue Aug 23, 2011 4:46 am
Re: Sony BDP-S580 (force transcoding)
sam_1421
Post Tue Aug 23, 2011 5:05 am
Here is the result (for one of the files I can't play) :
C:\Program Files (x86)\Serviio\lib>ffmpeg.exe -i "L:\Series\South Park\S01\south
 park 1x01.avi"
686-mingw32-
  libavutil     50.36. 0 / 50.36. 0
  libavcore      0.16. 0 /  0.16. 0
  libavcodec    52.108. 0 / 52.108. 0
  libavformat   52.92. 0 / 52.92. 0
  libavdevice   52. 2. 3 / 52. 2. 3
  libavfilter    1.72. 0 /  1.72. 0
  libswscale     0.12. 0 /  0.12. 0
Seems stream 0 codec frame rate differs from container frame rate: 30000.00 (300
00/1) -> 25.00 (25/1)
Input #0, avi, from 'L:\Series\South Park\S01\south park 1x01.avi':
  Duration: 00:24:09.48, start: 0.000000, bitrate: 561 kb/s
    Stream #0.0: Video: mpeg4, yuv420p, 512x400 [PAR 1:1 DAR 32:25], 25 fps, 25
tbr, 25 tbn, 30k tbc
      title           : NeoVideo92CF
    Stream #0.1: Audio: mp3, 48000 Hz, 2 channels, s16, 96 kb/s
      title           : NeoSound92CF0
skachr
Post Mon Aug 29, 2011 12:16 pm
Have you tried Serviio version 0.52, with the new comprehensive profile for Sony BDP?
It works for me with avi, mp4, and mkv.
dougkirkendoll
Post Mon Aug 29, 2011 5:19 pm
I have a Sony BD-370. My issue is AVI Divx will not play. I get the message corrupted file. I suspend Serviio is configured to remux or just pass through AVI Divx, but the play (US) will not play DIVX. It does work with XVID. I am trying to change settings on default BD profile to force transcribe of AVI containters that are encoded with DIVX.
patters
Post Tue Sep 13, 2011 6:43 pm
Could just be a bad file. Have you tried playing it from a USB memory stick plugged into the front panel (which would rule out DLNA being a problem if it doesn't play)?
