Re: Web UI in Restful Ajax
i'm using the latest version (0.5.2) available on serviio.org.
i will try to additional parameter once i get home from work
zip wrote:Elfish wrote:doesn't work on my server
http://127.0.0.1:23423/rest/application
seems to work.
w3m is asking if i wanted to download "application"
however trying to access
http://192.168.1.105:23423/rest/application
doesn't work on my local machine and my remote machine
the ip is 100% correct since i'm sshing to it.
Are you using beta 2 or something before that? If 0.5.2, then make sure to bind the rest API to the external Ip address by passing this on the server side:
williMeier wrote:yes. tried with chrome, ie 8, firefox portable, opera.
are there any logfiles?
Elfish wrote:hi just set the ip according to zip's additional parameter
i'm now able to access
from my laptop
patters wrote:Would Zip have to integrate it into the project?
patters wrote:Any chance of a 0.6 beta version with the online feeds tab in the Library section?
patters wrote:One small observation is that the scroll bars in the Add local... library function don't render on iPad (Safari Mobile). They're fine on the full Mac Safari browser though, so it could be a browser issue.
patters wrote:For customizing - I notice that the statique/styles folder is empty in the jar file. Would styles defined here replace those in your code? It would be nice to be able to edit it without picking the code apart.
kairoh wrote:I should become a beta tester first, Zip please?
kairoh wrote:In 0.1, every CSS were inside the html, so this folder had no meaning.
I've made a new version - 0.2 - which allows CSS customization.
I've renamed this folder from statique/styles to www/styles.
All you have to do is to create and update a /www/styles/serviio-webui.css file in you classpath.
For further info, see the wiki. Have fun!
zip wrote:kairoh wrote:I should become a beta tester first, Zip please?
Done
zip wrote:patters wrote:Would Zip have to integrate it into the project?
Yes.
patters wrote:Since I'm conscious that some Synology units only have 128MB of RAM, would it be ok to launch the jvm for the Web UI with a really low memory size (like 50MB or something)? Or should I leave it on the default of 384MB and let Linux swap the unused stuff to disk?
patters wrote:Did you have a chance to update the WebUI to offer the Online Sources tab in the Library view?
patters wrote:Any idea why it might be ignoring {serviio folder}/config/www/styles/serviio-webui.css?
patters wrote:It seems that the italic text is being specified in the HTML rather than the stylesheet. Could that be a style too?
patters wrote:Also, how would I change the text in the buttons themselves. I can't see how.
Users browsing this forum: Baidu [Spider] and 141 guests
