Readynas installation?
yupsolo
Post Fri Aug 19, 2011 5:23 pm
Anyone working on installing it on a Netgear Readynas ultra (x86)?
thx for sharing
yupsolo
Post Tue Aug 23, 2011 5:53 pm
Re: Readynas installation?
no one!?
Post Tue Aug 23, 2011 6:56 pm
What operating system are you using on it?
yupsolo
Post Thu Aug 25, 2011 1:43 pm
like other NASes:
Linux
Post Thu Aug 25, 2011 1:47 pm
You'll need :
java 6 (looks like it should work: http://www.readynas.com/forum/viewtopic ... 35&t=45891)
FFmpeg (you can either compile it yourself, or possibly download, googled this: http://www.readynas.com/forum/viewtopic ... 48&t=52993)
and then you should be ready to go, just use a startup script (you might find and answer here: viewtopic.php?f=17&t=71)
If you manage, please share with the rest on these forums.
yupsolo
Post Thu Aug 25, 2011 2:29 pm
Many thanx for your help!
I'll try this tonight.
I hope my low linux skills will do the job!
Post Thu Aug 25, 2011 7:45 pm
yupsolo wrote:like other NASes:
Linux
not true some run BSD and some even run a version of windows server and others run custom OS.
yupsolo
Post Fri Aug 26, 2011 11:52 am
Did I wrote:
Like ALL other NASes???
yes true.
yupsolo
Post Tue Aug 30, 2011 6:49 pm
I must say that my linux skills are too low for this project.
I really wanted to do it but after many hours and countless readings:
I GIVE UP.
Same thing for PMS... (ps3 media server for readynas)
Sad to see that the're no true media transcoder addons for readynas.
morz
Post Sun Oct 23, 2011 8:41 am
The missing piece for me was the (incomplete) FFMPEG library: The link posted above only came with a crippled FFMPEG that e.g. wasn't able to remux my MKVs to M2TS for streaming to my Sony BDP Blu Ray Player.
Here's a full FFMPEG version:
http://www.readynas.com/contributed/sup ... eg_1.2.bin
(got it from this page: http://www.readynas.com/forum/viewtopic ... 48&t=45661)
mdfire
Post Mon Oct 31, 2011 1:08 pm
Hi, first post and just started using Serviio today to stream to my Sony Bravia 2011 TV. I have it working perfectly streaming from a PC, but what I really want is stream from my Readynas Duo. Did the original poster ever resolve this? Is it possible to install Serviio onto the Readynas Duo? Ps I have zero linux skills!
Scouser
Post Mon Dec 05, 2011 12:03 am
Also a Newbie.
I would really like to get Serviio up on my ReadyNAS Pro 6 4.2.19.
But the main problem is that the OS runs a version of etch (Debian) which has no backports of Java 6.
If anyone has sucessfully got serviio up and running on recent ReadyNAS devices, please do let us know how you did it.
Scouser
Post Mon Dec 05, 2011 12:26 am
Literally 5 minutes after posting that last message I found this:
http://www.readynas.com/forum/viewtopic ... 36&t=57017
Which gives very good install instructs to install Sun Java 6 JRE on x86 ReadyNAS devices.
I dont know if there is a solution if your ReadyNAS is not x86 based.
I am almost there. ....
After setting up /etc/init.d/serviiod and /etc/default/serviio, I cant figure out how to set the DISPLAY variable in my SSH session on the NAS so that it tunnels back to my Mac. I guess I have to get X up and running on the Mac, start up an xterm and SSH into the nas from there so that X11 tunneling works back to the Mac. Anyone care to help me out with this?
Basically I just want to start serviio-console.sh but when I do, I get diagnostic that signifies that my DISPLAY variabe is not set. Usual PLAF message comlaints fro Java.
