Sorry guys, I'm in a mess again!
hexeta
Post Thu Aug 25, 2011 12:50 pm
Following a loss of service from TalkTalk, I've found my Router (Speedtouch 585 v6) has suffered total amnesia.
It reverted to the standard SSID "Speedtouch A96E54" or some such and there was no record of connected devices.
I've managed to re-name the Standard SSID to the one I had before, but the router has re-named it "Hexeta 2 (Hexeta)"
Using the TV Connection check, I get the following:-
Method: Wireless Built in
Wireless Device: OK
SSID: Hexeta
Signal Strength: (Shows a full bar graph)
Security: WPA-PSK (Tkip)
IP Address Setting: Auto
IP Address: 192.168.1.64
Subnet mask: 225.225.225.0
Default Gateway: 192:168:1:254
Primary DNS: 192:168:1:254
2nd DNS: 0.0.0.0
Mac Address: OO:AO:96:55:D5:D7
Proxy: Not Used.
However the TV cannot access the server.
Doing a "Server Diagnostics" check, shows two entries:-
"Succeeded - 1 Failed - 1"
Details as follows:-
The "Succeeded" Entry:
Server is accessible.
Server Geoff-PC1:ADMIN (Note, I have already Re-named this to "Geoffs-Vista-PC", but the TV has not seen it.)
UDN: UUID: d753f352-705d-4afa-b0c2-d0ae3250d...
IP Address: 192.168.1.65
MAC Address: 00:15:af:86:da:31
TCP Port: 2869
The "Failed" Entry:
Server Name Unknown (192.168.1.65)
UDN: uuid:d:19c78b-bb57-3238-a2e7-a907bb7...
MAC Address: Info Not Available
TCP Port: 8895
TV still cannot access either the PC or Serviio.
Can you sort me out? :cry:
Edit: I also notice that the "Wireless access point" is configured to "Allow multicast from Broadband Network:"....not sure what that means, or if it was there before! :shock:
Edit, Edit!: Further grubbing around uncovers that my network is set to "Public", I can see how to change this to "Private", but googling it, suggests that doing so will make Permanent changes to my firewall settings :shock:
What do I do? :roll:
Post Thu Aug 25, 2011 3:57 pm
Re: Sorry guys, I'm in a mess again!
Can you rename your serviio.log file and then restart serviio and paste the new log on here.
hexeta
Post Thu Aug 25, 2011 4:39 pm
Hi moltra, had the devil's own job starting Serviio again after stopping it so that I could re-name the log file.
You can probably see that from the new log posted below.
Still unable to connect TV to Serviio, the icon is greyed out on the TV, strangely, the Icon for my PC is "active", but though the TV can "see" the folder structure and the file titles, the thumbnails are just generic and it cannot connect saying check settings.
LOG FILE.
2011-08-25 17:26:09,162 INFO [ServiioConsole] Starting Serviio Console
2011-08-25 17:26:09,202 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-08-25 17:26:16,477 WARN [ServiioConsole] Cannot connect to the server to get DB initialization info
2011-08-25 17:26:23,487 WARN [ServiioConsole] Cannot connect to server: Communication Error (1001) - Connection refused: connect
2011-08-25 17:26:23,497 INFO [Messages] Loaded console message bundle for locale: en
2011-08-25 17:26:30,497 WARN [ServiioConsole] Cannot connect to server: Communication Error (1001) - Connection refused: connect
2011-08-25 17:26:34,939 INFO [ServiioConsole] Leaving Serviio Console
2011-08-25 17:26:38,543 INFO [ServiioConsole] Leaving Serviio Console
2011-08-25 17:26:55,762 INFO [ServiioConsole] Starting Serviio Console
2011-08-25 17:26:55,802 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-08-25 17:27:03,084 WARN [ServiioConsole] Cannot connect to the server to get DB initialization info
2011-08-25 17:27:10,095 WARN [ServiioConsole] Cannot connect to server: Communication Error (1001) - Connection refused: connect
2011-08-25 17:27:10,101 INFO [Messages] Loaded console message bundle for locale: en
2011-08-25 17:27:17,105 WARN [ServiioConsole] Cannot connect to server: Communication Error (1001) - Connection refused: connect
2011-08-25 17:27:20,975 INFO [ServiioConsole] Leaving Serviio Console
2011-08-25 17:27:56,595 INFO [ServiioConsole] Starting Serviio Console
2011-08-25 17:27:56,634 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-08-25 17:28:03,913 WARN [ServiioConsole] Cannot connect to the server to get DB initialization info
2011-08-25 17:28:10,923 WARN [ServiioConsole] Cannot connect to server: Communication Error (1001) - Connection refused: connect
2011-08-25 17:28:10,930 INFO [Messages] Loaded console message bundle for locale: en
2011-08-25 17:28:17,933 WARN [ServiioConsole] Cannot connect to server: Communication Error (1001) - Connection refused: connect
2011-08-25 17:28:21,747 INFO [ServiioConsole] Leaving Serviio Console
2011-08-25 17:28:59,785 INFO [ServiioConsole] Leaving Serviio Console
2011-08-25 17:29:03,223 INFO [ServiioConsole] Leaving Serviio Console
2011-08-25 17:30:32,752 INFO [ServiioConsole] Starting Serviio Console
2011-08-25 17:30:32,793 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-08-25 17:30:40,173 WARN [ServiioConsole] Cannot connect to the server to get DB initialization info
2011-08-25 17:30:41,482 INFO [ServiioConsole] Leaving Serviio Console
2011-08-25 17:30:46,971 INFO [ServiioConsole] Leaving Serviio Console
2011-08-25 17:30:47,183 WARN [ServiioConsole] Cannot connect to server: Communication Error (1001) - Connection refused: connect
2011-08-25 17:30:47,189 INFO [Messages] Loaded console message bundle for locale: en
2011-08-25 17:30:54,195 WARN [ServiioConsole] Cannot connect to server: Communication Error (1001) - Connection refused: connect
2011-08-25 17:30:56,125 INFO [ServiioConsole] Leaving Serviio Console
2011-08-25 17:31:03,979 INFO [ServiioConsole] Leaving Serviio Console
2011-08-25 17:31:05,811 INFO [MediaServer] ------------------------------------------------------------------------
2011-08-25 17:31:05,811 INFO [MediaServer] Serviio DLNA media streaming server v 0.5.2 (rev. 4e3210bd9ff3)
2011-08-25 17:31:05,811 INFO [MediaServer] Petr Nejedly 2009-2011
2011-08-25 17:31:05,811 INFO [MediaServer] http://www.serviio.org
2011-08-25 17:31:05,811 INFO [MediaServer] Java 1.6.0_26-Sun Microsystems Inc.
2011-08-25 17:31:05,811 INFO [MediaServer] OS Windows Vista x86 6.0
2011-08-25 17:31:05,811 INFO [MediaServer] File encoding: windows-1252
2011-08-25 17:31:05,889 INFO [RestletServer] Starting Restlet server exposed on localhost:23423
2011-08-25 17:31:05,921 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-08-25 17:31:07,916 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2011-08-25 17:31:08,091 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-08-25 17:31:08,177 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-08-25 17:31:08,227 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-08-25 17:31:08,264 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-08-25 17:31:08,315 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-08-25 17:31:08,347 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-08-25 17:31:08,428 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2011-08-25 17:31:08,450 INFO [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-08-25 17:31:08,612 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-08-25 17:31:08,846 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-08-25 17:31:08,910 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-08-25 17:31:08,955 INFO [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-08-25 17:31:09,185 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-08-25 17:31:09,226 INFO [WebServer] Socket buffer set to 65535 bytes
2011-08-25 17:31:09,286 INFO [WebServer] WebServer starting on port 8895
2011-08-25 17:31:09,517 INFO [Device] Created UPnP Device with UUID: dc19c78b-bb57-3238-a2e7-a9070bb7e5b8, bound address: 192.168.1.65
2011-08-25 17:31:09,557 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-08-25 17:31:09,568 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-08-25 17:31:09,570 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-08-25 17:31:09,570 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-08-25 17:31:09,571 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-08-25 17:31:09,571 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-08-25 17:31:09,571 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1314289869571, LastAccessTime = 1314289869571, getTimeToLiveSeconds() = -1, createTime = 1314289869571 ]
2011-08-25 17:31:09,573 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-08-25 17:31:09,581 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-08-25 17:31:09,582 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-08-25 17:31:09,582 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-08-25 17:31:09,582 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-08-25 17:31:09,582 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-08-25 17:31:09,582 INFO [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-08-25 17:31:09,582 INFO [CompositeCacheConfigurator] Finished configuration in 13 ms.
2011-08-25 17:31:09,583 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-08-25 17:31:09,584 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-08-25 17:31:09,587 INFO [RendererSearchSender] Searching for Renderer devices
2011-08-25 17:31:09,587 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2011-08-25 17:31:09,589 INFO [EventDispatcher] Starting EventDispatcher
2011-08-25 17:31:09,609 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net2 (802.11n Network Adapter) and address 192.168.1.65, timeout = 0
2011-08-25 17:31:20,793 INFO [ServiioConsole] Leaving Serviio Console
2011-08-25 17:31:35,835 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-08-25 17:31:35,839 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-08-25 17:31:56,420 INFO [MediaServer] Serviio server instance is already running
2011-08-25 17:32:21,752 INFO [ServiioConsole] Starting Serviio Console
2011-08-25 17:32:21,794 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-08-25 17:32:22,460 INFO [Messages] Loaded console message bundle for locale: en
2011-08-25 17:32:23,198 INFO [Messages] Loaded console message bundle for locale: en
2011-08-25 17:32:23,308 INFO [UpdateChecker] Checking if a new version is available
2011-08-25 17:32:28,457 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-08-25 17:32:28,699 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
Post Thu Aug 25, 2011 5:01 pm
Subnet mask is strange, may be 255.255.255.0
Post Thu Aug 25, 2011 5:30 pm
you are right the subnet probably should be 255.255.255.0 and I am use to seeing the gateway the same as the router IP. Mine is 192.168.2.1 for router and gateway.
Serviio is using 192.168.1.65 so it should be ok for the TV to see it.
hexeta
Post Thu Aug 25, 2011 5:36 pm
Sorry Illico, You are right, my mistake, 255:255:255.
My sloppy reading!
Can't understand why TV cannot see PC especially since :-
"Network Setup>View Network Status>Check Connection" results in "OK" for Wireless device, Local Access, and Internet Access.
I can access Youtube, so that confirms "Wireless Device" and "Internet Access" are working, just local that's the problem.
Got to be something in my Router settings I suppose, 'cos that is all that has been altered!
hexeta
Post Thu Aug 25, 2011 5:41 pm
moltra wrote:you are right the subnet probably should be 255.255.255.0 and I am use to seeing the gateway the same as the router IP. Mine is 192.168.2.1 for router and gateway.
Don't understand, mine reports:- Default Gateway and Primary DNS as being the same (192:168:1:254)
Is the "Primary DNS" the Router?
Either way, I still can't get TV to see PC!
Post Thu Aug 25, 2011 6:09 pm
Make sure that the ports are open on your computer.
My device doesn't see Serviio
This could be caused by you having multiple IP addresses on the machine and Serviio binding to a wrong one. Insert IP address of the machine running Serviio into 'Bound IP address' field in Network Settings section in the console or pass system variable serviio.boundAddr including the IP address when starting the server.
Also make sure that TCP port 8895 and UDP 1900 are open in your firewall.
If you are on a Linux based OS, make sure you set up multicast routes properly.
If on Windows, you can push Serviio service down in starting order.
Also see if there is a UPNP setting on your router. some need it check and some need it unchecked.
hexeta
Post Thu Aug 25, 2011 7:05 pm
The "Games and Application Sharing" page of my Router says:-
Use UPnP: Yes
Use Extended Security: No
There is a table below, and that just says "No games or applications assigned"
The "Wireless Access Point" config page has a box ticked which I can't say I've seen before, it says "Allow multicast from Broadband Network" ???
Also, in Windows, under "Set Network Location" there are two radio buttons, one for "Public" and one for "Private", "Public" has been selected....could this be part of the problem?
Post Thu Aug 25, 2011 7:39 pm
sounds like the router is " fubar " to me.
hexeta
Post Thu Aug 25, 2011 8:11 pm
Cerberus wrote:sounds like the router is " fubar " to me.
How so? :o
I'm using it now, and the TV can also access the net with it.
The only thing that don't seem to work with it is the local link.
The TV can't see either the PC, or Serviio.
Just typing this has lit up another bulb in my head! :lol:
I'm just going to look at the console to see if the correct addresses are being sought!
Post Thu Aug 25, 2011 8:36 pm
How so? :o
yer that would make sense sound like the multicasting/UPNP function arent working, either they have failed as i suspect as router reset itself or they are just not configured correctly.
hexeta
Post Thu Aug 25, 2011 9:07 pm
Sorry for the delay.....I got sidetracked!
The IP addresses of both TV and PC are correct and fixed.
Seems that Bill Gates has bowled me a Googly though, windows network and sharing centre it seems defaults to "Public" in order to protect my files from snooping when I drag the whole shooting match down to Costa Coffee, and plug it in to their power supply...as you do!
Changing it to "Private" has unlocked both PC, and Serviio...all working fine again......till the next time!!
Ah well, I've learned a little more, to go with the miniscule amount I already think I know!! :roll:
Thanks again, all of you, good to know youre there when I panic! :mrgreen:
Post Fri Aug 26, 2011 11:41 am
Glad you could get it working. Yes we will be here if you need us again.
hexeta
Post Fri Aug 26, 2011 12:05 pm
moltra wrote:Glad you could get it working. Yes we will be here if you need us again.
Oh! rest assured that will certainly be the case!! :mrgreen:
I'm just trying to coax this creaking installation of Vista to last until Serviio v6 before I have to resort to re-installing from a 2009 image! :shock:
I don't have disks because I'm operating it under a volume licence from the college where I used to do a bit of teaching - "Computer literacy"....case of the blind being led by the partially sighted! :lol:
I really must try to back-up more frequently! :(
