Samsung Smart TV D550 is seen by Serviio, but not viceversa
ninjavz
Post Thu Aug 25, 2011 10:37 pm
I just bought 8 Samsung SmarTV UN32D550 TVs for a clinic. And I have the problem that the TVs cannot see the Serviio PC. On the other hand, Serviio sees and recognizes the TVs correctly as C/D Series.
I have tried TVersity too, there I can see and connect to the server but I cannot play MP3 or videos even though I see the files on the TV.
So any ideas on what is happening on the Serviio problem?
Regards,
Post Thu Aug 25, 2011 10:51 pm
Re: Samsung Smart TV D550 is seen by Serviio, but not viceve
ninjavz wrote:Hi,
Regards,
using serviio for this is a breach of the licence, as it is for PERSONAL use only and not comercial.
Post Fri Aug 26, 2011 8:49 am
Cerberus wrote:using serviio for this is a breach of the licence, as it is for PERSONAL use only and not comercial.
That is not correct, anyone can use it.
ninjavz
Post Fri Aug 26, 2011 2:01 pm
I am not charging for that, it is only for educational purposes as we have our own videos on breastfeeding, diaper changing, bathing techniques, etc. which we would like the patients to be able to see on demand.
Thanks for the update Zip. So any thoughts about the problem I have?
Post Fri Aug 26, 2011 2:12 pm
the usual, firewall, bound address, etc. post detailed log
ninjavz
Post Fri Aug 26, 2011 4:53 pm
The firewall was OK.
So I changed BOUND IP ADDRESS which was empty by default to my IP and it worked.
Isn't it supposed to use the current IP when default? It should be working both ways, shouldn't it?
Post Fri Aug 26, 2011 5:01 pm
It's trying to work out the current network card, but if more are active then it's a hit and miss.
