HD MKV and BDP-BX37 Issues
A3M0N
Post Tue Aug 23, 2011 8:04 pm
I'm new to DLNA and to Serviio. I have a few MKV files that are HD and they won't play on my Sony BDP-BX37. AVI files are transcoded or remuxed (not sure) just fine, just these files won't play. The BluRay player lists the files, but when selected says that they are corrupted or unplayable.
The specs:
Unique ID                        :
172525137416823360226382099617011384949
(0x81CB2201375B38C891DA3DF6730EC275)
Complete name                    : /home/mythuser/Azureus
Downloads/Thundercats.2011.S01E01.Omens.Pt.1.720p.WEB-Reaperza/Thundercats.2011.S01E01.Omens.Pt.1.720p.WEB-DL.AAC2.0.H264-Reaperza.mkv
Format                           : Matroska
File size                        : 663 MiB
Duration                         : 22mn 37s
Overall bit rate                 : 4 093 Kbps
Encoded date                     : UTC 2011-08-08 21:30:42
Writing application              : mkvmerge v4.0.0 ('The Stars were
mine') built on Jun  6 2010 16:18:42
Writing library                  : libebml v1.0.0 + libmatroska v1.0.0
Format profile                   : High@L3.1
Format settings, CABAC           : No
Format settings, ReFrames        : 2 frames
Codec ID                         : V_MPEG4/ISO/AVC
Duration                         : 22mn 37s
Width                            : 1 280 pixels
Height                           : 720 pixels
Frame rate                       : 23.976 fps
Language                         : English
Color primaries                  : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics         : BT.709-5, BT.1361
Matrix coefficients              : BT.709-5, BT.1361, IEC 61966-2-4
709, SMPTE RP177
Format                           : AAC
Format/Info                      : Advanced Audio Codec
Format profile                   : LC
Codec ID                         : A_AAC
Duration                         : 22mn 37s
Channel(s)                       : 2 channels
Channel positions                : Front: L R
Language                         : English
Any ideas? And mods, please move this if it belongs in the transcoding section more than in the Sony section.
Thanks!
Post Tue Aug 23, 2011 8:20 pm
Re: HD MKV and BDP-BX37 Issues
file looks fine to me but i suspect it has header compression and that why they are not working, do a quick search of these forum there are a few posts on how to fix this.
edit - corrected by bad typos :(
A3M0N
Post Tue Aug 23, 2011 10:23 pm
Thanks, I'll do some searching on that.
A3M0N
Post Sat Aug 27, 2011 9:10 pm
Ok, I used mkvtoolnix (linux) to remux with no compression. I still get the same error about the file being corrupted or non playable. Do you know of any other tools or ideas?
Post Sat Aug 27, 2011 9:15 pm
not sure about the version of MkvMerge that was used. You might do some search on that as well.
A3M0N
Post Tue Aug 30, 2011 11:10 pm
I've done some research and experimentation and I think its the codec thats the issue. I reencoded the file (same resolution) with avidemux as xvid in an avi and it plays just fine. Now, how do I go about editing the profile to transcode the file to say xvid in a different container. I've been trying to get it work, but everything I try just ends up crashing Serviio.
Thanks!
Post Wed Aug 31, 2011 6:41 am
A3M0N wrote:...Now, how do I go about editing the profile to transcode the file to say xvid in a different container...
Serviio only support two target Video Codec:
targetVCodec - name of video codec to transcode into or omit this attribute to keep the video stream as it is;
possible values: mpeg2video (MPEG2), wmv2 (WMV9)
Are you sure this is the AVC codec used in your mkv source file the problem?
Try with TsMuxer tools to remux the video and audio codec into a different container like *.ts (transport stream)
A3M0N
Post Thu Sep 01, 2011 2:09 am
Ok, I remuxed it with tsmuxer into mpeg-ts (.ts) and it did just fine. What I can't figure out is the profile for the Sony BDPlayer seems to already be trying to remux it, and it says corrupt or unsupported. Maybe I'm reading the config file wrong.
Post Thu Sep 01, 2011 7:33 am
You could also try with latest ffmpeg release build (replace the one in serviio lib folder)
A3M0N
Post Sat Sep 03, 2011 5:18 pm
I'm running on a linux system, so I'll check to see if there are any updates available to me.
