Samsung Smart TV D Series seeing Serviio, but no files
ayall
Post Thu Aug 25, 2011 5:18 am
I just got a Samsung Smart TV (D7000 series), and my research has lead me to conclude that Serviio is the best option to get the gigz of video/music/pics from my iMac to my All Share Smart TV.
I installed Serviio, opened it with the console, and added a folder with a few pics(jpg) & vids(avi) to test it out.
Serviio appears on my Samsung Smart TV All-share program, but the files are not showing up.
Any ideas where I might be going wrong here?
I'll keep Serviio open, maybe it's just taking a really long time to load the content?
Post Thu Aug 25, 2011 12:20 pm
Re: Samsung Smart TV D Series seeing Serviio, but no files
depending on how many files you have shared with serviio, it could take a while to show up. This has been improved in the new 0.6 beta that is in testing now. Can you post your seviio.log file and we will look it over and see if there is anything indication of something not set up correctly.
Post Thu Aug 25, 2011 7:36 pm
it can take up to 24 hours to build the library for the first time, Although i have heard of it taking 48 hours on very slow systems but that is rare.
Post Thu Aug 25, 2011 9:30 pm
Cerberus wrote:it can take up to 24 hours to build the library for the first time, Although i have heard of it taking 48 hours on very slow systems but that is rare.
I would have thought on the recent (0.5 and higher) versions it should be able to browse library as it's being indexed. If not it's a serious bug.
Post Thu Aug 25, 2011 10:23 pm
nah its the samsung software being picky.
ayall
Post Fri Aug 26, 2011 3:05 am
hi all... thanks for the replies.
it actually ended up trinkling in... i think i was just over-zealous and impatient. :D
i do have some questions which have probably been asked though;
Does anyone know if there is a limit to the number of files?
I see 30 pages of 10 videos (about 300 out of the 1000's I have serviio point to) on my TV... and the 300 files picked seem completely random.
Not sure if this is a setting, serviio limitation, or a Samsung limitation.
thanks again for the replies.
Post Fri Aug 26, 2011 3:18 am
ayall wrote:hi all... thanks for the replies.
yes there is a limit sadly of 1000 videos (101 pages)
ayall
Post Fri Aug 26, 2011 3:24 am
only 1000? what a shame.... I guess i'll need to keep my video collection in check; i've already started trimming some of the lower quality cams & crappy one-timers.
i do experience one other problem, which is sometimes serviio sometimes says "loading" and even cuts out completely for a few seconds. (during a movie, this can be frustrating).
any pages on this site you can suggest i visit which give tips for best reception between my imac & samsung smart tv?
i'm also wondering if maybe i need to invest in a newer linksys router?
if so, any suggestions of best quality?
Thanks again!
Post Fri Aug 26, 2011 3:29 am
As a network engineer my networking devices are hugely important to me so i would recommend the 2 devices below, you get what you pay for.
Virgin internet Compatible. ( RJ45 Connection )
http://www.netgear.co.uk/home/products/ ... R4000.aspx <-- best router i have ever used :) HINT HINT
BT internet Compatible. ( ADSL/RJ11 Connection )
http://www.netgear.co.uk/home/products/ ... D3700.aspx <-- million times better than the home hub.
i do test my devices hard and have managed to drop the routers here but that was when running 2 streams and torrents at same time, but that is more like i killed the network card in the pc than the router though, anyways my point is be careful not to push the pc running serviio to hard or u will suffer drop out even with best equiptment.
ayall
Post Fri Aug 26, 2011 3:39 am
^what's the difference between Virgin & BT?
i was just looking at my Linksys/Cisco Wireless-G Model: WRT54G2 V1outer, i bought it about years ago... definitely time for an upgrade.
i don't mind spending bank to get a quality product, so your suggestions are well
I use a mac, not a PC, to run serviio so i'm not overly worried about pushing to far, but i do want to be cautious.
any tips on getting best results?
Post Fri Aug 26, 2011 3:52 am
ayall wrote:^what's the difference between Virgin & BT?
1. Difference is the connection on the router as stated in brackets :) so depending on your ISP you would need one or other of them.
2. OS has nothing to do with it, its how good the network card is. ( wireless N or gb wired )
ayall
Post Sun Aug 28, 2011 2:06 am
I have comcast, cable as my ISP. based on what i have now, technically use their POS modem too, but i have no idea what RJ45 or RJ11 mean.
I do pay them an additional $10/mo. for their modem, so if it's a wise investment for me to upgrade that, i'd very much like to do so.
As for my network card, which would be my current seems like it's wireless-g, so i'm assuming a type "n" is a step up, so i'll go searching for one of those.
Post Mon Aug 29, 2011 11:54 am
modem and router are two different things so even with a new router you still have to connect you modem as well.
sadly im in the uk and not the USA so i cant for certain say what connection the comcast modem uses but i would suspect its an RJ45 ( network ) connection.
