Testing with Samsung LN46A750
roadhouse
Post Thu Nov 05, 2009 2:08 am
I've been able to use PC Share Manager with my Samsung LN46A750 TV quite well. I have not been able to get any HD movies to stream (.mkv or .mp4) and hope Serviio will be able to help. After installing Serviio, I am currently unable to stream any video. When I browse my media selection for any file I get "Not Supported File Format". I can stop Serviio and start PC Share Manager and watch the movie fine. I have done no "extra" config outside selecting the Samsung WiseLink in the gui. Any help would be greatly appreciated. Thank you so much.
Post Thu Nov 05, 2009 9:56 am
Re: Testing with Samsung LN46A750
HI,
that's strange, I would have thought this TV will be compatible with my B650... Anyway, can you try installing Intel UPnP tools (link in my signature) and running Device Spy? It should list all your UPnP device and among them yout TV (in my case the TV is listed 2x). Expand the TV's tree and find service: urn:upnp-org:serviceId:ConnectionManager:1. Expand that and double click on GetProtocolInfo(...). CLick on Invoke and paste here (or attach a file) of the result in field Sink.
Thanks,
Petr
roadhouse
Post Fri Nov 06, 2009 12:26 am
I was right there with you thinking that since your TV worked; mine would be a snap; but no such luck.. yet.
I downloaded the new version of Serviio today and installed it. I tried the same movie with the same results; File Format not supported. I installed the Intel UpNp tools; however my TV does not show up automatically. I tried to rescan a few times; (even with the TV actively browsing the serviio menus) but no luck. When I tried to manually add the device I could not find the correct interface I guess. I have the TV set to a static ip; however from the detailed logs on serviio it appears that the port number changes often. I tried multiple ports with the ip however nothing I could think of was working. I tried the following format for the device add: (http://XXX.XXX.XXX.20:port) Any idea why the TV would not show up? I did see serviio in there along with my router and VUZE (on another file server on the network). Thanks again for all your help; it is greatly appreciated.
Post Fri Nov 06, 2009 10:13 am
I have an idea. The Samsung TV's have a list of allowed devices, on mine it's in: Menu (on remote control) -> Application -> Home NetworkCentre -> Media. Does the IP of your PC (where you have UPnP tools) appear in the list? If not, try installing the Samsung Share Manager on the PC, allow the TV to be connected to it (in the SW's user interface somewhere), hopefully it'll add the PC into the TV's list.
roadhouse
Post Sat Nov 07, 2009 2:37 am
I checked the TV (menu, applications:) I dont have that menu for allowed devices. On my version of PC Share Manager (1.5) the device list is set on the PC Share Manager itself (the server). (when I check the properties of the PC Share Manager in the DeviceSpy, it says that it is WiseLinkPro version 1.0) I do have the TV enabled and allowed for communication. I have the uPnP tools installed on the same machine as my PC Share Manager software. I have a movie playing through PC Share Manager, and ran the DeviceSpy hoping that I could see the TV; but no luck. I tried manually adding it again; but I haven't figured out the connection url. I'm hoping to get a packet sniffer on here this weekend and try to see if I can sniff out the url through some fun packet logs. Do you think it would be worthwhile for me to ask Samsung what the connection URL would be? Is there another way to figure it out? thanks again for all your help; it is greatly appreciated.
Post Sat Nov 07, 2009 11:01 am
You can also try Device Sniffer from the Intel tools. Try searching for root devices. If it finds your TV, get LOCATION url (should be the device description) and use it when manually adding device in Device Spy.
roadhouse
Post Wed Nov 11, 2009 3:16 am
Device Sniffer doesn't show my TV even when I'm streaming one with PC Share Manager. I have not been able to sniff out the device URL yet; but if/when I do; I will post with the update. If you have any other ideas, please let me know. Thanks again for all the help.
Post Wed Nov 11, 2009 10:31 am
can you try to do the same (Device Spy) but for your Samsung Share manager? The result will be in the other field (Source).
roadhouse
Post Wed Nov 11, 2009 11:02 pm
I was able to get the information from the PC Share Manager app. Let me know if an attachment is easier to read.
Thanks again.
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=01500000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=01500000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO_T;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=01500000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=01500000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_KO_T;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=01500000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_KO_ISO;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=01500000000000000000000000000000,http-get:*:audio/L16;rate=44100;channels=1:DLNA.ORG_PN=LPCM;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=01500000000000000000000000000000,http-get:*:audio/L16;rate=44100;channels=2:DLNA.ORG_PN=LPCM;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=01500000000000000000000000000000,http-get:*:audio/L16;rate=48000;channels=1:DLNA.ORG_PN=LPCM;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=01500000000000000000000000000000,http-get:*:audio/L16;rate=48000;channels=2:DLNA.ORG_PN=LPCM;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=01500000000000000000000000000000,http-get:*:audio/mpeg:DLNA.ORG_PN=MP3;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=01500000000000000000000000000000,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=00D00000000000000000000000000000,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_MED;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=00D00000000000000000000000000000,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=00D00000000000000000000000000000
Post Wed Nov 11, 2009 11:26 pm
Hmm, it's the same as on mine. Could you turn on debug logging (see my signature), restart Serviio, try to play a movie and then post here the log (attachment pls).
roadhouse
Post Thu Nov 12, 2009 4:27 pm
My TV has an ip of 192.168.61.20.
Serviio is installed on 192.168.61.51
I have Vuze installed on 192.168.61.15 (although the server side is turned off in the app)
I can see the request coming in; but I get "not surpport file format" on the TV.
Thanks again for all your help.
I tried to upload the log; but I could not find a file extension that would be accepted.
I tried, .log, .txt, .file, .rename, .jgp (said the image file was invalid) and .ini.
What did I miss?
Here is the log.
09:58:12,171 DEBUG [ContentDirectory] Browse() called with parameters: objectID = 0, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 0, count = 50, sortCriteria =
09:58:12,171 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
09:58:12,453 DEBUG [DiscoverySearchResponder] Received a valid M-SEARCH message for search type upnp:rootdevice from address /192.168.61.15:1151
09:58:12,453 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s)
09:58:18,203 DEBUG [WebServer] Incoming connection from /192.168.61.20:4414
09:58:18,203 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"
09:58:18,203 DEBUG [ContentDirectory] Browse() called with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
09:58:18,203 DEBUG [VideoDAOImpl] Retrieving number of video initials
09:58:18,218 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
09:58:18,218 DEBUG [WebServer] Incoming connection from /192.168.61.20:4415
09:58:18,218 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"
09:58:18,234 DEBUG [ContentDirectory] Browse() called with parameters: objectID = V, browseFlag = BrowseMetadata, filter = @parentID, startIndex = 0, count = 0, sortCriteria =
09:58:18,234 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
09:58:18,234 DEBUG [WebServer] Incoming connection from /192.168.61.20:4416
09:58:18,234 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"
09:58:18,234 DEBUG [ContentDirectory] Browse() called with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 0, count = 50, sortCriteria =
09:58:18,234 DEBUG [VideoDAOImpl] Retrieving number of video initials
09:58:18,234 DEBUG [VideoDAOImpl] Retrieving number of videos of type 2
09:58:18,265 DEBUG [SeriesDAOImpl] Retrieving number of series
09:58:18,265 DEBUG [FolderDAOImpl] Retrieving number of leaf folders
09:58:18,281 DEBUG [VideoDAOImpl] Retrieving number of 10 last viewed videos
09:58:18,281 DEBUG [GenreDAOImpl] Retrieving number of genres for VIDEO
09:58:18,296 DEBUG [PersonDAOImpl] Retrieving number of person initials for role ACTOR
09:58:18,328 DEBUG [PersonDAOImpl] Retrieving number of person initials for role DIRECTOR
09:58:18,328 DEBUG [PersonDAOImpl] Retrieving number of person initials for role PRODUCER
09:58:18,343 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
09:58:21,109 DEBUG [WebServer] Incoming connection from /192.168.61.20:4417
09:58:21,109 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"
09:58:21,125 DEBUG [ContentDirectory] Browse() called with parameters: objectID = V_M, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
09:58:21,125 DEBUG [VideoDAOImpl] Retrieving list of videos of type 2 (from=0, count=1)
09:58:21,125 DEBUG [GenreDAOImpl] Reading a Genre (id = 7)
09:58:21,140 DEBUG [PersonDAOImpl] Retrieving list of persons with role ACTOR for MediaItem 722
09:58:21,156 DEBUG [PersonDAOImpl] Retrieving list of persons with role DIRECTOR for MediaItem 722
09:58:21,156 DEBUG [PersonDAOImpl] Retrieving list of persons with role PRODUCER for MediaItem 722
09:58:21,171 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 789)
09:58:21,203 DEBUG [VideoDAOImpl] Retrieving number of videos of type 2
09:58:21,203 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
09:58:21,203 DEBUG [WebServer] Incoming connection from /192.168.61.20:4418
09:58:21,203 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"
09:58:21,203 DEBUG [ContentDirectory] Browse() called with parameters: objectID = V_M, browseFlag = BrowseMetadata, filter = @parentID, startIndex = 0, count = 0, sortCriteria =
09:58:21,218 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
09:58:21,218 DEBUG [WebServer] Incoming connection from /192.168.61.20:4419
09:58:21,218 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"
09:58:21,218 DEBUG [ContentDirectory] Browse() called with parameters: objectID = V_M, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 0, count = 50, sortCriteria =
09:58:21,218 DEBUG [VideoDAOImpl] Retrieving list of videos of type 2 (from=0, count=50)
09:58:21,390 DEBUG [VideoDAOImpl] Retrieving number of videos of type 2
09:58:21,437 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
09:58:21,484 DEBUG [WebServer] Incoming connection from /192.168.61.20:4420
09:58:21,484 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"
09:58:21,484 DEBUG [ContentDirectory] Browse() called with parameters: objectID = V_M, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 50, count = 50, sortCriteria =
09:58:21,484 DEBUG [VideoDAOImpl] Retrieving list of videos of type 2 (from=50, count=50)
09:58:21,500 DEBUG [GenreDAOImpl] Reading a Genre (id = 10)
09:58:21,593 DEBUG [VideoDAOImpl] Retrieving number of videos of type 2
09:58:21,609 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
09:58:21,640 DEBUG [WebServer] Incoming connection from /192.168.61.20:4421
09:58:21,640 DEBUG [ResourceTransportRequestHandler] GET /resource/789/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.61.51:8895, ACCEPT-LANGUAGE: en-us, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Interactive, ]
09:58:21,640 DEBUG [ResourceTransportRequestHandler] Request for resource 789 and type 'COVER_IMAGE' received
09:58:21,640 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 789)
09:58:21,640 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 789
09:58:21,640 DEBUG [ResourceTransportRequestHandler] Sending file back
09:58:21,640 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: image/jpeg, Content-Length: 4527, Cache-control: no-cache, Pragma: no-cache, Server: Windows XP UPnP/1.0 Serviio 0.1.1, contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000, transferMode.dlna.org: Interactive, ]
09:58:21,656 DEBUG [WebServer] Incoming connection from /192.168.61.20:4422
09:58:21,656 DEBUG [ResourceTransportRequestHandler] GET /resource/790/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.61.51:8895, ACCEPT-LANGUAGE: en-us, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Interactive, ]
09:58:21,656 DEBUG [ResourceTransportRequestHandler] Request for resource 790 and type 'COVER_IMAGE' received
09:58:21,656 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 790)
09:58:21,656 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 790
09:58:21,656 DEBUG [ResourceTransportRequestHandler] Sending file back
09:58:21,656 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: image/jpeg, Content-Length: 3119, Cache-control: no-cache, Pragma: no-cache, Server: Windows XP UPnP/1.0 Serviio 0.1.1, contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000, transferMode.dlna.org: Interactive, ]
09:58:22,812 DEBUG [WebServer] Incoming connection from /192.168.61.20:4423
09:58:22,812 DEBUG [ResourceTransportRequestHandler] GET /resource/791/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.61.51:8895, ACCEPT-LANGUAGE: en-us, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Interactive, ]
09:58:22,812 DEBUG [ResourceTransportRequestHandler] Request for resource 791 and type 'COVER_IMAGE' received
09:58:22,812 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 791)
09:58:22,812 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 791
09:58:22,812 DEBUG [ResourceTransportRequestHandler] Sending file back
09:58:22,812 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: image/jpeg, Content-Length: 6022, Cache-control: no-cache, Pragma: no-cache, Server: Windows XP UPnP/1.0 Serviio 0.1.1, contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000, transferMode.dlna.org: Interactive, ]
09:58:23,671 DEBUG [WebServer] Incoming connection from /192.168.61.20:4424
09:58:23,671 DEBUG [ResourceTransportRequestHandler] GET /resource/792/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.61.51:8895, ACCEPT-LANGUAGE: en-us, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Interactive, ]
09:58:23,671 DEBUG [ResourceTransportRequestHandler] Request for resource 792 and type 'COVER_IMAGE' received
09:58:23,671 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 792)
09:58:23,671 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 792
09:58:23,671 DEBUG [ResourceTransportRequestHandler] Sending file back
09:58:23,671 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: image/jpeg, Content-Length: 2913, Cache-control: no-cache, Pragma: no-cache, Server: Windows XP UPnP/1.0 Serviio 0.1.1, contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000, transferMode.dlna.org: Interactive, ]
09:58:24,312 DEBUG [WebServer] Incoming connection from /192.168.61.20:4425
09:58:24,312 DEBUG [ResourceTransportRequestHandler] GET /resource/793/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.61.51:8895, ACCEPT-LANGUAGE: en-us, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Interactive, ]
09:58:24,312 DEBUG [ResourceTransportRequestHandler] Request for resource 793 and type 'COVER_IMAGE' received
09:58:24,312 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 793)
09:58:24,312 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 793
09:58:24,312 DEBUG [ResourceTransportRequestHandler] Sending file back
09:58:24,312 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: image/jpeg, Content-Length: 6219, Cache-control: no-cache, Pragma: no-cache, Server: Windows XP UPnP/1.0 Serviio 0.1.1, contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000, transferMode.dlna.org: Interactive, ]
09:58:24,875 DEBUG [WebServer] Incoming connection from /192.168.61.20:4426
09:58:24,875 DEBUG [ResourceTransportRequestHandler] GET /resource/794/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.61.51:8895, ACCEPT-LANGUAGE: en-us, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Interactive, ]
09:58:24,890 DEBUG [ResourceTransportRequestHandler] Request for resource 794 and type 'COVER_IMAGE' received
09:58:24,890 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 794)
09:58:24,890 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 794
09:58:24,890 DEBUG [ResourceTransportRequestHandler] Sending file back
09:58:24,890 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: image/jpeg, Content-Length: 5699, Cache-control: no-cache, Pragma: no-cache, Server: Windows XP UPnP/1.0 Serviio 0.1.1, contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000, transferMode.dlna.org: Interactive, ]
09:58:25,750 DEBUG [WebServer] Incoming connection from /192.168.61.20:4427
09:58:25,750 DEBUG [ResourceTransportRequestHandler] GET /resource/795/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.61.51:8895, ACCEPT-LANGUAGE: en-us, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Interactive, ]
09:58:25,750 DEBUG [ResourceTransportRequestHandler] Request for resource 795 and type 'COVER_IMAGE' received
09:58:25,750 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 795)
09:58:25,750 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 795
09:58:25,750 DEBUG [ResourceTransportRequestHandler] Sending file back
09:58:25,750 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: image/jpeg, Content-Length: 5804, Cache-control: no-cache, Pragma: no-cache, Server: Windows XP UPnP/1.0 Serviio 0.1.1, contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000, transferMode.dlna.org: Interactive, ]
09:58:26,859 DEBUG [WebServer] Incoming connection from /192.168.61.20:4428
09:58:26,859 DEBUG [ResourceTransportRequestHandler] GET /resource/796/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.61.51:8895, ACCEPT-LANGUAGE: en-us, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Interactive, ]
09:58:26,859 DEBUG [ResourceTransportRequestHandler] Request for resource 796 and type 'COVER_IMAGE' received
09:58:26,859 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 796)
09:58:26,859 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 796
09:58:26,859 DEBUG [ResourceTransportRequestHandler] Sending file back
09:58:26,859 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: image/jpeg, Content-Length: 5713, Cache-control: no-cache, Pragma: no-cache, Server: Windows XP UPnP/1.0 Serviio 0.1.1, contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000, transferMode.dlna.org: Interactive, ]
09:58:28,406 DEBUG [WebServer] Incoming connection from /192.168.61.20:4429
09:58:28,406 DEBUG [ResourceTransportRequestHandler] GET /resource/797/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.61.51:8895, ACCEPT-LANGUAGE: en-us, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Interactive, ]
09:58:28,406 DEBUG [ResourceTransportRequestHandler] Request for resource 797 and type 'COVER_IMAGE' received
09:58:28,406 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 797)
09:58:28,406 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 797
09:58:28,406 DEBUG [ResourceTransportRequestHandler] Sending file back
09:58:28,406 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: image/jpeg, Content-Length: 4482, Cache-control: no-cache, Pragma: no-cache, Server: Windows XP UPnP/1.0 Serviio 0.1.1, contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000, transferMode.dlna.org: Interactive, ]
09:58:29,078 DEBUG [WebServer] Incoming connection from /192.168.61.20:4430
09:58:29,078 DEBUG [ResourceTransportRequestHandler] GET /resource/798/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.61.51:8895, ACCEPT-LANGUAGE: en-us, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Interactive, ]
09:58:29,078 DEBUG [ResourceTransportRequestHandler] Request for resource 798 and type 'COVER_IMAGE' received
09:58:29,078 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 798)
09:58:29,078 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 798
09:58:29,078 DEBUG [ResourceTransportRequestHandler] Sending file back
09:58:29,078 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: image/jpeg, Content-Length: 7121, Cache-control: no-cache, Pragma: no-cache, Server: Windows XP UPnP/1.0 Serviio 0.1.1, contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000, transferMode.dlna.org: Interactive, ]
09:58:29,718 DEBUG [WebServer] Incoming connection from /192.168.61.20:4431
09:58:29,718 DEBUG [ResourceTransportRequestHandler] GET /resource/799/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.61.51:8895, ACCEPT-LANGUAGE: en-us, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Interactive, ]
09:58:29,718 DEBUG [ResourceTransportRequestHandler] Request for resource 799 and type 'COVER_IMAGE' received
09:58:29,718 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 799)
09:58:29,718 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 799
09:58:29,718 DEBUG [ResourceTransportRequestHandler] Sending file back
09:58:29,718 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: image/jpeg, Content-Length: 4694, Cache-control: no-cache, Pragma: no-cache, Server: Windows XP UPnP/1.0 Serviio 0.1.1, contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000, transferMode.dlna.org: Interactive, ]
09:58:30,250 DEBUG [WebServer] Incoming connection from /192.168.61.20:4432
09:58:30,250 DEBUG [ResourceTransportRequestHandler] GET /resource/800/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.61.51:8895, ACCEPT-LANGUAGE: en-us, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Interactive, ]
09:58:30,250 DEBUG [ResourceTransportRequestHandler] Request for resource 800 and type 'COVER_IMAGE' received
09:58:30,250 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 800)
09:58:30,250 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 800
09:58:30,250 DEBUG [ResourceTransportRequestHandler] Sending file back
09:58:30,250 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: image/jpeg, Content-Length: 4126, Cache-control: no-cache, Pragma: no-cache, Server: Windows XP UPnP/1.0 Serviio 0.1.1, contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000, transferMode.dlna.org: Interactive, ]
09:58:30,828 DEBUG [WebServer] Incoming connection from /192.168.61.20:4433
09:58:30,828 DEBUG [ResourceTransportRequestHandler] GET /resource/851/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.61.51:8895, ACCEPT-LANGUAGE: en-us, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Interactive, ]
09:58:30,828 DEBUG [ResourceTransportRequestHandler] Request for resource 851 and type 'COVER_IMAGE' received
09:58:30,828 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 851)
09:58:30,828 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 851
09:58:30,828 DEBUG [ResourceTransportRequestHandler] Sending file back
09:58:30,828 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: image/jpeg, Content-Length: 5245, Cache-control: no-cache, Pragma: no-cache, Server: Windows XP UPnP/1.0 Serviio 0.1.1, contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000, transferMode.dlna.org: Interactive, ]
09:58:31,453 DEBUG [WebServer] Incoming connection from /192.168.61.20:4434
09:58:31,453 DEBUG [ResourceTransportRequestHandler] GET /resource/847/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.61.51:8895, ACCEPT-LANGUAGE: en-us, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Interactive, ]
09:58:31,453 DEBUG [ResourceTransportRequestHandler] Request for resource 847 and type 'COVER_IMAGE' received
09:58:31,453 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 847)
09:58:31,453 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 847
09:58:31,453 DEBUG [ResourceTransportRequestHandler] Sending file back
09:58:31,453 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: image/jpeg, Content-Length: 4156, Cache-control: no-cache, Pragma: no-cache, Server: Windows XP UPnP/1.0 Serviio 0.1.1, contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000, transferMode.dlna.org: Interactive, ]
09:58:32,125 DEBUG [WebServer] Incoming connection from /192.168.61.20:4435
09:58:32,140 DEBUG [ResourceTransportRequestHandler] GET /resource/802/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.61.51:8895, ACCEPT-LANGUAGE: en-us, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Interactive, ]
09:58:32,140 DEBUG [ResourceTransportRequestHandler] Request for resource 802 and type 'COVER_IMAGE' received
09:58:32,140 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 802)
09:58:32,140 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 802
09:58:32,140 DEBUG [ResourceTransportRequestHandler] Sending file back
09:58:32,140 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: image/jpeg, Content-Length: 2664, Cache-control: no-cache, Pragma: no-cache, Server: Windows XP UPnP/1.0 Serviio 0.1.1, contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000, transferMode.dlna.org: Interactive, ]
09:58:32,953 DEBUG [WebServer] Incoming connection from /192.168.61.20:4436
09:58:32,953 DEBUG [ResourceTransportRequestHandler] GET /resource/803/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.61.51:8895, ACCEPT-LANGUAGE: en-us, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Interactive, ]
09:58:32,953 DEBUG [ResourceTransportRequestHandler] Request for resource 803 and type 'COVER_IMAGE' received
09:58:32,953 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 803)
09:58:32,953 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 803
09:58:32,953 DEBUG [ResourceTransportRequestHandler] Sending file back
09:58:32,953 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: image/jpeg, Content-Length: 4331, Cache-control: no-cache, Pragma: no-cache, Server: Windows XP UPnP/1.0 Serviio 0.1.1, contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000, transferMode.dlna.org: Interactive, ]
09:58:33,765 DEBUG [WebServer] Incoming connection from /192.168.61.20:4437
09:58:33,765 DEBUG [ResourceTransportRequestHandler] GET /resource/804/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.61.51:8895, ACCEPT-LANGUAGE: en-us, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Interactive, ]
09:58:33,765 DEBUG [ResourceTransportRequestHandler] Request for resource 804 and type 'COVER_IMAGE' received
09:58:33,765 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 804)
09:58:33,765 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 804
09:58:33,765 DEBUG [ResourceTransportRequestHandler] Sending file back
09:58:33,765 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: image/jpeg, Content-Length: 5099, Cache-control: no-cache, Pragma: no-cache, Server: Windows XP UPnP/1.0 Serviio 0.1.1, contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000, transferMode.dlna.org: Interactive, ]
09:58:34,359 DEBUG [WebServer] Incoming connection from /192.168.61.20:4438
09:58:34,359 DEBUG [ResourceTransportRequestHandler] GET /resource/805/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.61.51:8895, ACCEPT-LANGUAGE: en-us, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Interactive, ]
09:58:34,359 DEBUG [ResourceTransportRequestHandler] Request for resource 805 and type 'COVER_IMAGE' received
09:58:34,359 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 805)
09:58:34,359 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 805
09:58:34,359 DEBUG [ResourceTransportRequestHandler] Sending file back
09:58:34,359 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: image/jpeg, Content-Length: 1903, Cache-control: no-cache, Pragma: no-cache, Server: Windows XP UPnP/1.0 Serviio 0.1.1, contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000, transferMode.dlna.org: Interactive, ]
09:58:35,078 DEBUG [WebServer] Incoming connection from /192.168.61.20:4439
09:58:35,078 DEBUG [ResourceTransportRequestHandler] GET /resource/806/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.61.51:8895, ACCEPT-LANGUAGE: en-us, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Interactive, ]
09:58:35,078 DEBUG [ResourceTransportRequestHandler] Request for resource 806 and type 'COVER_IMAGE' received
09:58:35,078 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 806)
09:58:35,078 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 806
09:58:35,078 DEBUG [ResourceTransportRequestHandler] Sending file back
09:58:35,078 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: image/jpeg, Content-Length: 5755, Cache-control: no-cache, Pragma: no-cache, Server: Windows XP UPnP/1.0 Serviio 0.1.1, contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000, transferMode.dlna.org: Interactive, ]
09:58:35,812 DEBUG [WebServer] Incoming connection from /192.168.61.20:3075
09:58:35,812 DEBUG [ResourceTransportRequestHandler] GET /resource/848/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.61.51:8895, ACCEPT-LANGUAGE: en-us, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Interactive, ]
09:58:35,812 DEBUG [ResourceTransportRequestHandler] Request for resource 848 and type 'COVER_IMAGE' received
09:58:35,812 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 848)
09:58:35,812 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 848
09:58:35,812 DEBUG [ResourceTransportRequestHandler] Sending file back
09:58:35,812 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: image/jpeg, Content-Length: 5678, Cache-control: no-cache, Pragma: no-cache, Server: Windows XP UPnP/1.0 Serviio 0.1.1, contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000, transferMode.dlna.org: Interactive, ]
09:58:36,609 DEBUG [WebServer] Incoming connection from /192.168.61.20:3076
09:58:36,609 DEBUG [ResourceTransportRequestHandler] GET /resource/807/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.61.51:8895, ACCEPT-LANGUAGE: en-us, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Interactive, ]
09:58:36,609 DEBUG [ResourceTransportRequestHandler] Request for resource 807 and type 'COVER_IMAGE' received
09:58:36,609 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 807)
09:58:36,609 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 807
09:58:36,609 DEBUG [ResourceTransportRequestHandler] Sending file back
09:58:36,609 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: image/jpeg, Content-Length: 5316, Cache-control: no-cache, Pragma: no-cache, Server: Windows XP UPnP/1.0 Serviio 0.1.1, contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000, transferMode.dlna.org: Interactive, ]
09:58:37,359 DEBUG [WebServer] Incoming connection from /192.168.61.20:3077
09:58:37,359 DEBUG [ResourceTransportRequestHandler] GET /resource/810/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.61.51:8895, ACCEPT-LANGUAGE: en-us, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Interactive, ]
09:58:37,359 DEBUG [ResourceTransportRequestHandler] Request for resource 810 and type 'COVER_IMAGE' received
09:58:37,359 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 810)
09:58:37,359 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 810
09:58:37,359 DEBUG [ResourceTransportRequestHandler] Sending file back
09:58:37,359 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: image/jpeg, Content-Length: 7060, Cache-control: no-cache, Pragma: no-cache, Server: Windows XP UPnP/1.0 Serviio 0.1.1, contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000, transferMode.dlna.org: Interactive, ]
09:58:38,046 DEBUG [WebServer] Incoming connection from /192.168.61.20:3078
09:58:38,046 DEBUG [ResourceTransportRequestHandler] GET /resource/808/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.61.51:8895, ACCEPT-LANGUAGE: en-us, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Interactive, ]
09:58:38,046 DEBUG [ResourceTransportRequestHandler] Request for resource 808 and type 'COVER_IMAGE' received
09:58:38,046 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 808)
09:58:38,046 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 808
09:58:38,046 DEBUG [ResourceTransportRequestHandler] Sending file back
09:58:38,046 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: image/jpeg, Content-Length: 2808, Cache-control: no-cache, Pragma: no-cache, Server: Windows XP UPnP/1.0 Serviio 0.1.1, contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000, transferMode.dlna.org: Interactive, ]
09:58:38,687 DEBUG [WebServer] Incoming connection from /192.168.61.20:3079
09:58:38,687 DEBUG [ResourceTransportRequestHandler] GET /resource/809/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.61.51:8895, ACCEPT-LANGUAGE: en-us, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Interactive, ]
09:58:38,687 DEBUG [ResourceTransportRequestHandler] Request for resource 809 and type 'COVER_IMAGE' received
09:58:38,687 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 809)
09:58:38,687 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 809
09:58:38,687 DEBUG [ResourceTransportRequestHandler] Sending file back
09:58:38,687 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: image/jpeg, Content-Length: 4458, Cache-control: no-cache, Pragma: no-cache, Server: Windows XP UPnP/1.0 Serviio 0.1.1, contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000, transferMode.dlna.org: Interactive, ]
09:58:39,343 DEBUG [WebServer] Incoming connection from /192.168.61.20:3080
09:58:39,343 DEBUG [ResourceTransportRequestHandler] GET /resource/811/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.61.51:8895, ACCEPT-LANGUAGE: en-us, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Interactive, ]
09:58:39,343 DEBUG [ResourceTransportRequestHandler] Request for resource 811 and type 'COVER_IMAGE' received
09:58:39,343 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 811)
09:58:39,343 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 811
09:58:39,343 DEBUG [ResourceTransportRequestHandler] Sending file back
09:58:39,343 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: image/jpeg, Content-Length: 2750, Cache-control: no-cache, Pragma: no-cache, Server: Windows XP UPnP/1.0 Serviio 0.1.1, contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000, transferMode.dlna.org: Interactive, ]
09:58:40,109 DEBUG [WebServer] Incoming connection from /192.168.61.20:3081
09:58:40,109 DEBUG [ResourceTransportRequestHandler] GET /resource/849/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.61.51:8895, ACCEPT-LANGUAGE: en-us, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Interactive, ]
09:58:40,109 DEBUG [ResourceTransportRequestHandler] Request for resource 849 and type 'COVER_IMAGE' received
09:58:40,109 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 849)
09:58:40,109 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 849
09:58:40,109 DEBUG [ResourceTransportRequestHandler] Sending file back
09:58:40,109 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: image/jpeg, Content-Length: 7009, Cache-control: no-cache, Pragma: no-cache, Server: Windows XP UPnP/1.0 Serviio 0.1.1, contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000, transferMode.dlna.org: Interactive, ]
09:58:41,093 DEBUG [WebServer] Incoming connection from /192.168.61.20:3082
09:58:41,093 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"
09:58:41,093 DEBUG [ContentDirectory] Browse() called with parameters: objectID = V_M, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 23, count = 1, sortCriteria =
09:58:41,093 DEBUG [VideoDAOImpl] Retrieving list of videos of type 2 (from=23, count=1)
09:58:41,093 DEBUG [GenreDAOImpl] Reading a Genre (id = 10)
09:58:41,093 DEBUG [PersonDAOImpl] Retrieving list of persons with role ACTOR for MediaItem 742
09:58:41,093 DEBUG [PersonDAOImpl] Retrieving list of persons with role DIRECTOR for MediaItem 742
09:58:41,093 DEBUG [PersonDAOImpl] Retrieving list of persons with role PRODUCER for MediaItem 742
09:58:41,093 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 809)
09:58:41,187 DEBUG [VideoDAOImpl] Retrieving number of videos of type 2
09:58:41,187 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
09:58:41,218 DEBUG [WebServer] Incoming connection from /192.168.61.20:3083
09:58:41,218 DEBUG [ResourceTransportRequestHandler] HEAD /resource/742/MEDIA_ITEM/AVI HTTP/1.0, headers = [getCaptionInfo.sec: 1, ]
09:58:41,218 DEBUG [ResourceTransportRequestHandler] Request for resource 742 and type 'MEDIA_ITEM' received
09:58:41,218 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 742)
09:58:41,234 DEBUG [VideoDAOImpl] Reading a Video (id = 742)
09:58:41,234 DEBUG [MediaResourceRetrievalStrategy] Delivering file friday-pfa.avi in its original format
09:58:41,234 DEBUG [MediaItemDAOImpl] Getting file of media item 742
09:58:41,234 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 742) as read
09:58:41,328 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 742)
09:58:41,328 DEBUG [MediaItemDAOImpl] Getting file of media item 742
09:58:41,328 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
09:58:41,328 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: video/x-msvideo, Content-Length: 728576000, Cache-control: no-cache, Pragma: no-cache, Server: Windows XP UPnP/1.0 Serviio 0.1.1, transferMode.dlna.org: Streaming, ]
09:58:41,343 DEBUG [WebServer] Incoming connection from /192.168.61.20:3420
09:58:41,343 DEBUG [ResourceTransportRequestHandler] HEAD /resource/742/MEDIA_ITEM/AVI HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1, Host: 192.168.61.51:8895, ]
09:58:41,343 DEBUG [ResourceTransportRequestHandler] Request for resource 742 and type 'MEDIA_ITEM' received
09:58:41,343 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 742)
09:58:41,343 DEBUG [VideoDAOImpl] Reading a Video (id = 742)
09:58:41,343 DEBUG [MediaResourceRetrievalStrategy] Delivering file friday-pfa.avi in its original format
09:58:41,343 DEBUG [MediaItemDAOImpl] Getting file of media item 742
09:58:41,343 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 742) as read
09:58:41,343 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
09:58:41,343 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: video/x-msvideo, Content-Length: 728576000, Cache-control: no-cache, Pragma: no-cache, Server: Windows XP UPnP/1.0 Serviio 0.1.1, contentFeatures.dlna.org: DLNA.ORG_PN=AVI;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000, transferMode.dlna.org: Streaming, ]
09:58:44,500 DEBUG [WebServer] Incoming connection from /192.168.61.20:3084
09:58:44,500 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"
09:58:44,500 DEBUG [ContentDirectory] Browse() called with parameters: objectID = V_M, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 24, count = 1, sortCriteria =
09:58:44,500 DEBUG [VideoDAOImpl] Retrieving list of videos of type 2 (from=24, count=1)
09:58:44,500 DEBUG [GenreDAOImpl] Reading a Genre (id = 10)
09:58:44,500 DEBUG [PersonDAOImpl] Retrieving list of persons with role ACTOR for MediaItem 744
09:58:44,500 DEBUG [PersonDAOImpl] Retrieving list of persons with role DIRECTOR for MediaItem 744
09:58:44,515 DEBUG [PersonDAOImpl] Retrieving list of persons with role PRODUCER for MediaItem 744
09:58:44,515 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 811)
09:58:44,515 DEBUG [VideoDAOImpl] Retrieving number of videos of type 2
09:58:44,515 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
09:58:44,578 DEBUG [WebServer] Incoming connection from /192.168.61.20:3085
09:58:44,578 DEBUG [ResourceTransportRequestHandler] HEAD /resource/744/MEDIA_ITEM/AVI HTTP/1.0, headers = [getCaptionInfo.sec: 1, ]
09:58:44,578 DEBUG [ResourceTransportRequestHandler] Request for resource 744 and type 'MEDIA_ITEM' received
09:58:44,578 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 744)
09:58:44,578 DEBUG [VideoDAOImpl] Reading a Video (id = 744)
09:58:44,578 DEBUG [MediaResourceRetrievalStrategy] Delivering file grandtrino.avi in its original format
09:58:44,578 DEBUG [MediaItemDAOImpl] Getting file of media item 744
09:58:44,593 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 744) as read
09:58:44,593 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 744)
09:58:44,593 DEBUG [MediaItemDAOImpl] Getting file of media item 744
09:58:44,593 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
09:58:44,593 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: video/x-msvideo, Content-Length: 1410324930, Cache-control: no-cache, Pragma: no-cache, Server: Windows XP UPnP/1.0 Serviio 0.1.1, transferMode.dlna.org: Streaming, ]
09:58:44,593 DEBUG [WebServer] Incoming connection from /192.168.61.20:3746
09:58:44,593 DEBUG [ResourceTransportRequestHandler] HEAD /resource/744/MEDIA_ITEM/AVI HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1, Host: 192.168.61.51:8895, ]
09:58:44,593 DEBUG [ResourceTransportRequestHandler] Request for resource 744 and type 'MEDIA_ITEM' received
09:58:44,593 DEBUG [VideoDAOImpl] Reading a Video (id = 744)
09:58:44,593 DEBUG [MediaResourceRetrievalStrategy] Delivering file grandtrino.avi in its original format
09:58:44,593 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: video/x-msvideo, Content-Length: 1410324930, Cache-control: no-cache, Pragma: no-cache, Server: Windows XP UPnP/1.0 Serviio 0.1.1, contentFeatures.dlna.org: DLNA.ORG_PN=AVI;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000, transferMode.dlna.org: Streaming, ]
09:58:47,703 DEBUG [WebServer] Incoming connection from /192.168.61.20:3086
09:58:47,703 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"
09:58:47,703 DEBUG [ContentDirectory] Browse() called with parameters: objectID = V_M, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 25, count = 1, sortCriteria =
09:58:47,703 DEBUG [VideoDAOImpl] Retrieving list of videos of type 2 (from=25, count=1)
09:58:47,718 DEBUG [GenreDAOImpl] Reading a Genre (id = 9)
09:58:47,718 DEBUG [PersonDAOImpl] Retrieving list of persons with role ACTOR for MediaItem 782
09:58:47,718 DEBUG [PersonDAOImpl] Retrieving list of persons with role DIRECTOR for MediaItem 782
09:58:47,718 DEBUG [PersonDAOImpl] Retrieving list of persons with role PRODUCER for MediaItem 782
09:58:47,718 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 849)
09:58:47,718 DEBUG [VideoDAOImpl] Retrieving number of videos of type 2
09:58:47,718 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
09:58:47,796 DEBUG [WebServer] Incoming connection from /192.168.61.20:3087
09:58:47,796 DEBUG [ResourceTransportRequestHandler] HEAD /resource/782/MEDIA_ITEM/AVI HTTP/1.0, headers = [getCaptionInfo.sec: 1, ]
09:58:47,796 DEBUG [ResourceTransportRequestHandler] Request for resource 782 and type 'MEDIA_ITEM' received
09:58:47,796 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 782)
09:58:47,796 DEBUG [VideoDAOImpl] Reading a Video (id = 782)
09:58:47,796 DEBUG [MediaResourceRetrievalStrategy] Delivering file The Hangover.avi in its original format
09:58:47,796 DEBUG [MediaItemDAOImpl] Getting file of media item 782
09:58:47,796 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 782) as read
09:58:47,796 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
09:58:47,796 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: video/x-msvideo, Content-Length: 1369276416, Cache-control: no-cache, Pragma: no-cache, Server: Windows XP UPnP/1.0 Serviio 0.1.1, transferMode.dlna.org: Streaming, ]
09:58:47,812 DEBUG [WebServer] Incoming connection from /192.168.61.20:4774
09:58:47,812 DEBUG [ResourceTransportRequestHandler] HEAD /resource/782/MEDIA_ITEM/AVI HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1, Host: 192.168.61.51:8895, ]
09:58:47,812 DEBUG [ResourceTransportRequestHandler] Request for resource 782 and type 'MEDIA_ITEM' received
09:58:47,812 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 782)
09:58:47,812 DEBUG [VideoDAOImpl] Reading a Video (id = 782)
09:58:47,812 DEBUG [MediaResourceRetrievalStrategy] Delivering file The Hangover.avi in its original format
09:58:47,812 DEBUG [MediaItemDAOImpl] Getting file of media item 782
09:58:47,812 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 782) as read
09:58:47,812 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
09:58:47,812 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: video/x-msvideo, Content-Length: 1369276416, Cache-control: no-cache, Pragma: no-cache, Server: Windows XP UPnP/1.0 Serviio 0.1.1, contentFeatures.dlna.org: DLNA.ORG_PN=AVI;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000, transferMode.dlna.org: Streaming, ]
09:58:50,921 DEBUG [WebServer] Incoming connection from /192.168.61.20:3088
09:58:50,921 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"
09:58:50,921 DEBUG [ContentDirectory] Browse() called with parameters: objectID = V_M, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 26, count = 1, sortCriteria =
09:58:50,921 DEBUG [VideoDAOImpl] Retrieving list of videos of type 2 (from=26, count=1)
09:58:50,937 DEBUG [GenreDAOImpl] Reading a Genre (id = 10)
09:58:50,937 DEBUG [PersonDAOImpl] Retrieving list of persons with role ACTOR for MediaItem 745
09:58:50,937 DEBUG [PersonDAOImpl] Retrieving list of persons with role DIRECTOR for MediaItem 745
09:58:50,937 DEBUG [PersonDAOImpl] Retrieving list of persons with role PRODUCER for MediaItem 745
09:58:50,937 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 812)
09:58:50,937 DEBUG [VideoDAOImpl] Retrieving number of videos of type 2
09:58:50,937 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
09:58:51,015 DEBUG [WebServer] Incoming connection from /192.168.61.20:3089
09:58:51,015 DEBUG [ResourceTransportRequestHandler] HEAD /resource/745/MEDIA_ITEM/AVI HTTP/1.0, headers = [getCaptionInfo.sec: 1, ]
09:58:51,015 DEBUG [ResourceTransportRequestHandler] Request for resource 745 and type 'MEDIA_ITEM' received
09:58:51,015 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 745)
09:58:51,015 DEBUG [VideoDAOImpl] Reading a Video (id = 745)
09:58:51,015 DEBUG [MediaResourceRetrievalStrategy] Delivering file HauntinginConn.avi in its original format
09:58:51,015 DEBUG [MediaItemDAOImpl] Getting file of media item 745
09:58:51,015 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 745) as read
09:58:51,015 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
09:58:51,015 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: video/x-msvideo, Content-Length: 734189568, Cache-control: no-cache, Pragma: no-cache, Server: Windows XP UPnP/1.0 Serviio 0.1.1, transferMode.dlna.org: Streaming, ]
09:58:51,015 DEBUG [WebServer] Incoming connection from /192.168.61.20:2911
09:58:51,015 DEBUG [ResourceTransportRequestHandler] HEAD /resource/745/MEDIA_ITEM/AVI HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1, Host: 192.168.61.51:8895, ]
09:58:51,031 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 745) as read
09:58:51,031 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
09:58:51,031 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: video/x-msvideo, Content-Length: 734189568, Cache-control: no-cache, Pragma: no-cache, Server: Windows XP UPnP/1.0 Serviio 0.1.1, contentFeatures.dlna.org: DLNA.ORG_PN=AVI;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000, transferMode.dlna.org: Streaming, ]
09:58:54,140 DEBUG [WebServer] Incoming connection from /192.168.61.20:3090
09:58:54,140 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"
09:58:54,140 DEBUG [ContentDirectory] Browse() called with parameters: objectID = V_M, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 27, count = 1, sortCriteria =
09:58:54,156 DEBUG [VideoDAOImpl] Retrieving number of videos of type 2
09:58:54,156 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
09:58:54,218 DEBUG [WebServer] Incoming connection from /192.168.61.20:3091
09:58:54,218 DEBUG [ResourceTransportRequestHandler] HEAD /resource/747/MEDIA_ITEM/AVI HTTP/1.0, headers = [getCaptionInfo.sec: 1, ]
09:58:54,218 DEBUG [ResourceTransportRequestHandler] Request for resource 747 and type 'MEDIA_ITEM' received
09:58:54,218 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 747)
09:58:54,218 DEBUG [VideoDAOImpl] Reading a Video (id = 747)
09:58:54,218 DEBUG [MediaResourceRetrievalStrategy] Delivering file Hellboy[2004][Director's.Cut]DvDrip-aXXo.avi in its original format
09:58:54,218 DEBUG [MediaItemDAOImpl] Getting file of media item 747
09:58:54,218 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 747) as read
09:58:54,234 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
09:58:54,234 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: video/x-msvideo, Content-Length: 839532544, Cache-control: no-cache, Pragma: no-cache, Server: Windows XP UPnP/1.0 Serviio 0.1.1, transferMode.dlna.org: Streaming, ]
09:58:54,234 DEBUG [WebServer] Incoming connection from /192.168.61.20:1878
09:58:54,234 DEBUG [ResourceTransportRequestHandler] HEAD /resource/747/MEDIA_ITEM/AVI HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1, Host: 192.168.61.51:8895, ]
09:58:54,234 DEBUG [ResourceTransportRequestHandler] Request for resource 747 and type 'MEDIA_ITEM' received
09:58:54,234 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 747)
09:58:54,234 DEBUG [VideoDAOImpl] Reading a Video (id = 747)
09:58:54,234 DEBUG [MediaResourceRetrievalStrategy] Delivering file Hellboy[2004][Director's.Cut]DvDrip-aXXo.avi in its original format
09:58:54,234 DEBUG [MediaItemDAOImpl] Getting file of media item 747
09:58:54,234 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 747) as read
09:58:54,234 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: video/x-msvideo, Content-Length: 839532544, Cache-control: no-cache, Pragma: no-cache, Server: Windows XP UPnP/1.0 Serviio 0.1.1, contentFeatures.dlna.org: DLNA.ORG_PN=AVI;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000, transferMode.dlna.org: Streaming, ]
09:58:56,953 DEBUG [WebServer] Incoming connection from /192.168.61.20:3092
09:58:56,953 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"
09:58:56,968 DEBUG [ContentDirectory] Browse() called with parameters: objectID = V_M, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 28, count = 1, sortCriteria =
09:58:56,968 DEBUG [VideoDAOImpl] Retrieving number of videos of type 2
09:58:56,968 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
09:58:56,984 DEBUG [WebServer] Incoming connection from /192.168.61.20:3093
09:58:56,984 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"
09:58:56,984 DEBUG [ContentDirectory] Browse() called with parameters: objectID = V_M, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 29, count = 1, sortCriteria =
09:58:57,000 DEBUG [VideoDAOImpl] Retrieving number of videos of type 2
09:58:57,000 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
09:58:57,093 DEBUG [WebServer] Incoming connection from /192.168.61.20:3094
09:58:57,093 DEBUG [ResourceTransportRequestHandler] GET /resource/812/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.61.51:8895, ACCEPT-LANGUAGE: en-us, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Interactive, ]
09:58:57,093 DEBUG [ResourceTransportRequestHandler] Request for resource 812 and type 'COVER_IMAGE' received
09:58:57,093 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 812)
09:58:57,093 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 812
09:58:57,093 DEBUG [ResourceTransportRequestHandler] Sending file back
09:58:57,093 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: image/jpeg, Content-Length: 2603, Cache-control: no-cache, Pragma: no-cache, Server: Windows XP UPnP/1.0 Serviio 0.1.1, contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000, transferMode.dlna.org: Interactive, ]
09:58:57,109 DEBUG [WebServer] Incoming connection from /192.168.61.20:3095
09:58:57,109 DEBUG [ResourceTransportRequestHandler] GET /resource/814/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.61.51:8895, ACCEPT-LANGUAGE: en-us, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Interactive, ]
09:58:57,109 DEBUG [ResourceTransportRequestHandler] Request for resource 814 and type 'COVER_IMAGE' received
09:58:57,109 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 814)
09:58:57,109 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 814
09:58:57,109 DEBUG [ResourceTransportRequestHandler] Sending file back
09:58:57,109 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: image/jpeg, Content-Length: 5930, Cache-control: no-cache, Pragma: no-cache, Server: Windows XP UPnP/1.0 Serviio 0.1.1, contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000, transferMode.dlna.org: Interactive, ]
09:58:57,109 DEBUG [WebServer] Incoming connection from /192.168.61.20:3096
09:58:57,109 DEBUG [ResourceTransportRequestHandler] GET /resource/813/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.61.51:8895, ACCEPT-LANGUAGE: en-us, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Interactive, ]
09:58:57,109 DEBUG [ResourceTransportRequestHandler] Request for resource 813 and type 'COVER_IMAGE' received
09:58:57,109 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 813)
09:58:57,109 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 813
09:58:57,109 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: image/jpeg, Content-Length: 2937, Cache-control: no-cache, Pragma: no-cache, Server: Windows XP UPnP/1.0 Serviio 0.1.1, contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000, transferMode.dlna.org: Interactive, ]
09:58:57,125 DEBUG [WebServer] Incoming connection from /192.168.61.20:3097
09:58:57,125 DEBUG [ResourceTransportRequestHandler] GET /resource/815/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.61.51:8895, ACCEPT-LANGUAGE: en-us, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Interactive, ]
09:58:57,125 DEBUG [ResourceTransportRequestHandler] Request for resource 815 and type 'COVER_IMAGE' received
09:58:57,125 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 815)
09:58:57,125 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 815
09:58:57,125 DEBUG [ResourceTransportRequestHandler] Sending file back
09:58:57,125 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: image/jpeg, Content-Length: 5645, Cache-control: no-cache, Pragma: no-cache, Server: Windows XP UPnP/1.0 Serviio 0.1.1, contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000, transferMode.dlna.org: Interactive, ]
09:58:59,218 DEBUG [WebServer] Incoming connection from /192.168.61.20:3098
09:58:59,218 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"
09:58:59,234 DEBUG [ContentDirectory] Browse() called with parameters: objectID = V_M, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 27, count = 1, sortCriteria =
09:58:59,234 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
09:58:59,250 DEBUG [WebServer] Incoming connection from /192.168.61.20:3099
09:58:59,250 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"
09:58:59,250 DEBUG [ContentDirectory] Browse() called with parameters: objectID = V_M, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 27, count = 1, sortCriteria =
09:58:59,250 DEBUG [VideoDAOImpl] Retrieving number of videos of type 2
09:58:59,250 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
09:59:12,453 DEBUG [DiscoverySearchResponder] Received a valid M-SEARCH message for search type upnp:rootdevice from address /192.168.61.15:1151
09:59:12,453 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s)
09:59:13,968 DEBUG [DiscoveryManager] UPNP device b8a5cd30-0b33-33da-8284-eb7466e95bc8 is unavailable
09:59:13,968 DEBUG [WebServer] Socket closed
09:59:13,968 INFO [WebServer] WebServer shutting down
09:59:13,968 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP byebye
09:59:13,968 INFO [DiscoverySearchListener] Leaving DiscoverySearchListener
09:59:13,968 INFO [DatabaseManager] Shutting down database
09:59:13,968 DEBUG [DBConnectionPool] Closed connection for pool Serviio DB Pool
09:59:14,390 INFO [EventDispatcher] Leaving EventDispatcher
09:59:14,437 DEBUG [DatabaseManager] DB shutdown returned: Derby system shutdown.
Post Thu Nov 12, 2009 4:46 pm
Re: Testing with Samsung LN46A750
HI,
I'll look into this. icansee you only tried playing AVi files, do the other formats (mpeg2, mp4, mkv) give you the same error? Also is this video only problem or you can't play any music either?
roadhouse
Post Thu Nov 12, 2009 10:01 pm
I get the same results when I try to play an mkv or an mp4. (i have not been able to get those format to play through PC Share Manger either) I have been able to get those AVIs to play trough PC Share Manager.
I was able to play an mp3 file fine; no luck for a .flac file.
....would be very cool if we could get a visualizer to stream while the music was playing.
Would be great if it could accept the same viewers that a winamp would take.
Thanks again and great work.
Post Fri Nov 13, 2009 11:10 am
I'm not sure if it's something with the way I send the stream to the TV or just a different mine-type for the AVI's. COuld you tyr to play a MPEG2 file? It could be a VOB file from a DVD for example.
roadhouse
Post Fri Nov 13, 2009 2:01 pm
I was able to get a VOB file to play fine; but no luck with the mkv or mp4. File Format Not Supported. MPEg-2 normally plays through PC Share Managaer as well. thanks again
Post Fri Nov 13, 2009 2:44 pm
Ok, so you basically cannot play the MP4/MKV files that are not playable with the PC Share manager, right? If this is the case I can't help you, because the TV probably doesn't support these formats. My B650 at leat has mp4 listed in the supported formats (yours doesn't) and MKV is not DLNA format, but my TV still supports it.
Regarding AVI, it's possible that your TV uses diferent mime-type header. Can you use AV Media Controller from the Intel UPnP tools, navigate to PC Share manager node (will probably have name of your PC, should include Shared Content node), find some AVI that doesn't play, go to its properties and post here protocInfo value of resource #1 (or whichever represents the video)?
When 0.2 is out we can try to add a profile for your TV that would support playing AVI's to it.
Return to User experiences
