iTunes MP4/H.264 video not woring with my D series
thorsten
Post Wed Sep 07, 2011 11:28 am
I purchased and transcoded iTunes video. There are the only films that I cannot see on my TV using serviio. I already tried to understand the profiles XML to work it around by myself, but I wasn't clever enough. Thus I am asking for help.
Setup:
SAMSUNG D series TV, MacMini, Serviio 0.5.2. Client configured as C/D series.
FFMPEG from one of the files:
Thorstens-Mac-mini:MacOS MacMini$ ./ffmpeg -i /Volumes/minimusic/Video/HD/Insid
e\ Job.mp4
built on Jan 12 2011 19:51:48 with gcc 4.0.1 (Apple Inc. build 5493)
configuration: --enable-static --disable-shared --bindir=/tmp/ffmpeg --disable-ffplay --disable-ffserver --enable-libmp3lame --enable-pthreads --disable-mmx --extra-ldflags=-L/tmp/static/lib --extra-cflags=-I/tmp/static/include
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 0 / 0.16. 0
libavfilter 1.72. 0 / 1.72. 0
libswscale 0.12. 0 / 0.12. 0
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Volumes/minimusic/Video/HD/Inside Job.mp4':
major_brand : isom
minor_version : 512
compatible_brands: isomiso2avc1mp41
creation_time : 1970-01-01 00:00:00
title : Inside Job
artist : Charles Ferguson
genre : Dokumentarfilme
date : 2011-05-04T07:00:00Z
copyright : © 2010 Sony Pictures Classics Inc. All Rights Reserved.
description : (Subtitled) Charles Ferguson (NO END IN SIGHT), der bereits eine Oscar-Nominierung erhielt, zeigt in INSIDE JOB die schockierenden Hintergründe der Wirtschaftskrise von 2008. Der Finanz-Crash kostete über 20 Billionen Dollar und kostete Millionen von Mens
Duration: 01:48:38.40, start: 0.000000, bitrate: 1718 kb/s
Stream #0.0(und): Audio: mp3, 48000 Hz, 2 channels, s16, 128 kb/s
Stream #0.1(und): Video: h264, yuv420p, 1280x544, 1587 kb/s, 23.98 fps, 23.98 tbr, 2997 tbn, 47.95 tbc
Thanks for any help!
Thorsten
Post Wed Sep 07, 2011 11:41 am
Re: iTunes MP4/H.264 video not woring with my D series
Can you play the file in an ordinary player (non iTunes) on your PC (eg VLC)? I'm thinking it might be DRM protected file and therefore not playable. You could also try playing in on your TV from USB stick.
thorsten
Post Wed Sep 07, 2011 1:20 pm
Thanks for the quick reply. I already removed the DRM, it is NOT protected. I can play it using VLC and also I can play it using another DLNA (TVmobili). To make things short: It's playable by all but serviio.
Post Wed Sep 07, 2011 1:29 pm
Can you post detailed log of when you attempt to play the file?
thorsten
Post Wed Sep 07, 2011 1:40 pm
I completely stopped the processes, erased all logs, edited the config to DEBUG and restarted. Went straight to the folders part and tried to play the Inside Job mp4.
All I can see in the new log file is:
2011-09-07 15:36:22,180 WARN [VideoDeliveryEngine] Cannot resolve DLNA format p
rofile of the original file: Inside Job.mp4. Message: MP4 video file Inside Job.
mp4 does not match any supported DLNA profile
That's the only line containing the name of the video in the log.
Post Wed Sep 07, 2011 1:51 pm
Right, it's because DLNA spec doesn't support MP3 audio in high definition H246/mov video file. You could setup transcoding to ac3 or reencode the file to ac3/aac yourself. I'll see if I can hack it in the next version as it is a supported native format of the TV (albeit not DLNA supported).
I've added the ticket and will add support for this file to 0.6
thorsten
Post Wed Sep 07, 2011 1:58 pm
Thanks a lot.
Do you have a quick line for me to put in the config? I already tried it (as I thought that mp3 might be the problem) but was not successful. Might be because I have not really an idea on how the XML structure works (I never used XML before, honestly).
Thanks!
thorsten
Post Wed Sep 07, 2011 2:10 pm
Thanks,
I found it on my own and it's working: I added the middle line of the "matches" (just for the records):
<!-- transcode H264 MP4 files with LPCM audio -->
<Matches container="mp4" aCodec="lpcm" />
<Matches container="mp4" aCodec="mp3" />
