FFmpeg for noobs like me
berty
Post Tue Oct 26, 2010 5:35 pm
This is what i did to read the ffmpeg info of a file i wanted to provide info on...
maybe this could be made into a sticky
1. type cmd in the search programmes and files box,(located in the windows start button ) it should bring up a black screen with a flashing tab
2. type in the following... The following assumes serviio is located in c drive, programme files, and windows 7 is being used. If windows 7 is not being used, you dont need the (x86) bit.
On windows 7 there is a programme files and a programme files (x86) almost every programme installed gets installed to the x86 folder. So for windows 7, type
cd "\Program Files (x86)\Serviio\lib
3. next you need to type ffmpeg.exe -i "file name and location goes here "
so it might look like this
ffmpeg.exe -i "C:\Users\smithy\Documents\green zone.avi"
you will then get a list of results that look like this...
Microsoft Windows [Version 6.1.7600]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\smithy>cd "\Program Files (x86)\Serviio\lib
C:\Program Files (x86)\Serviio\lib>ffmpeg.exe -i "C:\Users\smithy\Documents\green
zone.avi"
FFmpeg version SVN-r23012, Copyright (c) 2000-2010 the FFmpeg developers
built on May 3 2010 19:05:24 with gcc 3.4.5 (mingw-vista special r3)
erver --enable-memalign-hack --enable-libmp3lame --enable-w32threads --extra-ldf
lags=-L/static/lib --extra-cflags=-I/static/include
libavutil 50.15. 0 / 50.15. 0
libavcodec 52.66. 0 / 52.66. 0
libavformat 52.62. 0 / 52.62. 0
libavdevice 52. 2. 0 / 52. 2. 0
libswscale 0.10. 0 / 0.10. 0
[mpeg4 @ 02a208c0]Invalid and inefficient vfw-avi packed B frames detected
Input #0, avi, from 'C:\Users\smithy\Documents\green zone.avi':
Duration: 01:54:10.30, start: 0.000000, bitrate: 858 kb/s
Stream #0.0: Video: mpeg4, yuv420p, 640x272 [PAR 1:1 DAR 40:17], 23.98 tbr,
23.98 tbn, 23.98 tbc
Stream #0.1: Audio: mp3, 44100 Hz, 2 channels, s16, 128 kb/s
4. click in the black box anywhere on the info, right click and select, select all. You will see everything turn white, press ctrl and v, which will copy all the info ready for you to paste into a post on here.
Hope thats made things a little clearer.
Post Tue Oct 26, 2010 6:54 pm
Re: FFmpeg for noobs like me
Thanks, I added link to this page here: viewtopic.php?f=5&t=960
Bboy486
Post Tue Mar 15, 2011 3:59 am
How about a version for OS X....
ffstork
Post Sun Apr 03, 2011 3:46 pm
Bboy486 wrote:How about a version for OS X....
X2!!!
Samsung LN-52B750
XBOX 360
iMac OSX 10.6
wim
Post Sun Apr 03, 2011 4:51 pm
1. Open a Terminal (Under Applications - Utilities).
2. You'll have to navigate to where your Serviio is installed (I'm presuming /Applications, if not, change accordingly):
type "cd /Applications/Serviio.app/Contents/MacOS"
3. Type "./ffmpeg -i ~/Movies/filename.avi" (of course change filename accordingly ;)) (~ is a shortcut for your home directory, BTW, eg. /Users/john/)
4. Select the output, push Cmd-C and then you can paste it in a mail, or forum post.
HTH,
Wim
Post Sun Apr 03, 2011 4:57 pm
is that the same for all versions of mac osx ??
wim
Post Mon Apr 04, 2011 3:11 pm
Cerberus wrote:is that the same for all versions of mac osx ??
Yes.
What I don't know though, if the user has a local binary of ffmpeg, e.g. in /opt/local/usr/bin from MacPorts, and if it's in the PATH, will Serviio pick that up?
Post Mon Apr 04, 2011 3:20 pm
wim wrote:What I don't know though, if the user has a local binary of ffmpeg, e.g. in /opt/local/usr/bin from MacPorts, and if it's in the PATH, will Serviio pick that up?
No, it looks for the bundled one. You can, however, point it to another ffmpeg executable by providing ffmpeg.location system property like
-Dffmpeg.location=/path/to/ffmpeg
spellcaster
Post Wed Aug 17, 2011 11:27 am
C:\Program\Serviio\lib>ffmpeg.exe -i "C:\Documents and Settings\Ägaren\Mina doku
ment\Vuze Downloads\Limitless.2011.1080p.R5 bluray.MKV.AC3.NL.Subs.DMT"
686-mingw32-
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 0 / 0.16. 0
libavfilter 1.72. 0 / 1.72. 0
libswscale 0.12. 0 / 0.12. 0
C:\Documents and Settings\─garen\Mina dokument\Vuze Downloads\Limitless.2011.108
0p.R5 bluray.MKV.AC3.NL.Subs.DMT: Permission denied
What to do about 'Permission denied'?
spellcaster
Post Wed Aug 17, 2011 11:58 am
I understood the mistake I was making. Thanks!
JonMuss
Post Fri Sep 09, 2011 9:34 am
Hi This Is my first post on this forum so I'm sorry if I have posted this in the wrong thread!
I have installed Serviio on my Laptop and have made a connection with my Panasonic TX P42V20b but Serviio does not recognise AVI files. I have run AV Media Controller and Serviio does not see the file i then followed your instructions and this is the result when I run ffmpeg.exe -i:
C:\Program Files\Serviio\lib>ffmpeg -i "C:\Documents and Settings\Jon Musselwhit
e\Videos\Videos\Video 8.avi"
686-mingw32-
Input #0, avi, from 'C:\Documents and Settings\Jon Musselwhite\Videos\Videos\Vid
eo 8.avi':
Duration: 00:00:20.36, start: 0.000000, bitrate: 30373 kb/s
Stream #0.0: Video: dvvideo, yuv420p, 720x576 [PAR 64:45 DAR 16:9], 25 tbr,
25 tbn, 25 tbc
Stream #0.1: Audio: pcm_s16le, 48000 Hz, 2 channels, s16, 1536 kb/s
Please can you help
Post Fri Sep 09, 2011 9:57 am
dvvideo video codec will be supported in the next 0.6 version.
jOkEr
Post Fri Dec 23, 2011 8:32 am
Can anyone help with the following file? What does "[mpegts @ 0xdf7420] Continuity Check Failed" mean?
> ffmpeg -i "/volume1/video/HDTV_S.ts"
ffmpeg version 0.8.2.git-05a2673-Serviio, Copyright (c) 2000-2011 the FFmpeg developers
built on Aug 22 2011 09:57:40 with gcc 4.2.3
configuration: --arch=arm --enable-armv5te --prefix=/opt --extra-cflags=-I/opt/include --extra-ldflags='-L/volume1/@tmp/lib' --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-pthreads --enable-libmp3lame --enable-librtmp --extra-version=Serviio
libavutil 51. 13. 0 / 51. 13. 0
libavcodec 53. 11. 0 / 53. 11. 0
libavformat 53. 9. 0 / 53. 9. 0
libavdevice 53. 3. 0 / 53. 3. 0
libavfilter 2. 34. 1 / 2. 34. 1
libswscale 2. 0. 0 / 2. 0. 0
Last message repeated 1 times
Seems stream 0 codec frame rate differs from container frame rate: 59.94 (60000/1001) -> 29.97 (60000/2002)
Input #0, mpegts, from '/volume1/video/HDTV_S.ts':
Duration: 01:54:59.06, start: 0.213000, bitrate: 23429 kb/s
Program 1
Stream #0.0[0x11]: Video: mpeg2video (Main), yuv420p, 1920x1080 [SAR 1:1 DAR 16:9], 30000 kb/s, 29.97 fps, 29.97 tbr, 90k tbn, 59.94 tbc
Stream #0.1[0x14]: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
Synology> ffmpeg -i "HDTV_27.mkv"
[matroska,webm @ 0xdf7420] max_analyze_duration 5000000 reached at 5024000
[matroska,webm @ 0xdf7420] Estimating duration from bitrate, this may be inaccurate
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (20000000/417083) -> 23.98 (24000/1001)
Input #0, matroska,webm, from 'HDTV_27.mkv':
title : 27
Duration: 01:50:48.67, start: 0.000000, bitrate: 2304 kb/s
Stream #0.0(eng): Video: h264 (High), yuv420p, 1280x532, SAR 1:1 DAR 320:133, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
Stream #0.1(ukr): Audio: ac3, 48000 Hz, 5.1, s16, 384 kb/s (default)
title : Ukrainian
Stream #0.2(rus): Audio: ac3, 48000 Hz, 5.1, s16, 384 kb/s
title : Russian
Stream #0.3(eng): Audio: dca (DTS), 48000 Hz, 5.1, s16, 1536 kb/s
title : English
Stream #0.4: Attachment: [0][0][0][0] / 0x0000
filename : tahoma.ttf
> ffmpeg -i HDTV_L.mkv
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (5000000/104271) -> 23.98 (24000/1001)
Input #0, matroska,webm, from 'HDTV_L.mkv':
title : L
Duration: 01:46:54.21, start: 0.000000, bitrate: 640 kb/s
Chapter #0.0: start 0.000000, end 395.812000
title : 00:00:00.000
Chapter #0.1: start 395.812000, end 638.179000
title : 00:06:35.812
Chapter #0.2: start 638.179000, end 1157.740000
title : 00:10:38.179
Chapter #0.3: start 1157.740000, end 1512.970000
title : 00:19:17.740
Chapter #0.4: start 1512.970000, end 1918.792000
title : 00:25:12.970
Chapter #0.5: start 1918.792000, end 2190.814000
title : 00:31:58.792
Chapter #0.6: start 2190.814000, end 2379.836000
title : 00:36:30.814
Chapter #0.7: start 2379.836000, end 3126.582000
title : 00:39:39.836
Chapter #0.8: start 3126.582000, end 3756.836000
title : 00:52:06.582
Chapter #0.9: start 3756.836000, end 3967.255000
title : 01:02:36.836
Chapter #0.10: start 3967.255000, end 4096.634000
title : 01:06:07.255
Chapter #0.11: start 4096.634000, end 4709.622000
title : 01:08:16.634
Chapter #0.12: start 4709.622000, end 4937.558000
title : 01:18:29.622
Chapter #0.13: start 4937.558000, end 5758.378000
title : 01:22:17.558
Chapter #0.14: start 5758.378000, end 5861.147000
title : 01:35:58.378
Chapter #0.15: start 5861.147000, end 6414.210000
title : 01:37:41.147
Stream #0.0(eng): Video: h264 (High), yuv420p, 1920x816 [SAR 1:1 DAR 40:17], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc
Stream #0.1(rus): Audio: ac3, 48000 Hz, 5.1, s16, 640 kb/s (default)
Or either
[avi @ 0xdf7420] max_analyze_duration 5000000 reached at 5024000
[mpeg4 @ 0xdf92a0] Invalid and inefficient vfw-avi packed B frames detected
messages?
The problem is I am not able to see large files starting with HDTV_*. I hope it will index sometimes but decided to check are they OK for ffmpeg :)
Post Fri Dec 23, 2011 9:56 am
not sure, ask FFmpeg guys ;-)
lsarver
Post Fri Dec 30, 2011 11:11 pm
Serviio won't enter this file into the library. I've got an ffmpeg permission problem, too, but can't determine how this file's permissions differ from others':
E:\Program Files\Serviio\lib>ffmpeg.exe -i "I:\DVD\Features\Bridge of San Luis Rey, The (2004)"
ffmpeg version N-36193-gf514695, Copyright (c) 2000-2011 the FFmpeg developers
built on Dec 26 2011 17:50:37 with gcc 4.6.2
configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-ru
ntime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libope
ncore-amrnb --enable-libopencore-amrwb --enable-libfreetype --enable-libgsm --en
able-libmp3lame --enable-libopenjpeg --enable-librtmp --enable-libschroedinger -
-enable-libspeex --enable-libtheora --enable-libvo-aacenc --enable-libvo-amrwben
c --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-
libxvid --enable-zlib
libavutil 51. 33.100 / 51. 33.100
libavcodec 53. 48.100 / 53. 48.100
libavformat 53. 28.100 / 53. 28.100
libavdevice 53. 4.100 / 53. 4.100
libavfilter 2. 54.100 / 2. 54.100
libswresample 0. 5.100 / 0. 5.100
libpostproc 51. 2.100 / 51. 2.100
I:\DVD\Features\Bridge of San Luis Rey, The (2004): Permission denied
Thanks for any insight.
(Btw, I had to replace the shipping ffmpeg, which kept crashing--I'm on XP.)
Edit: Nevermind. It looks like I bungled the rip.
rbramhill1
Post Sun Feb 19, 2012 12:42 pm
C:\Program Files\Serviio\lib>ffmpeg.exe -i "j\3d\puss in boots 3d.mkv
nfig
libavutil 51. 32. 0 / 51. 32. 0
libavcodec 53. 42. 0 / 53. 42. 0
libavformat 53. 24. 0 / 53. 24. 0
libavdevice 53. 4. 0 / 53. 4. 0
libavfilter 2. 53. 0 / 2. 53. 0
libswscale 2. 1. 0 / 2. 1. 0
j\3d\puss in boots 3d.mkv: No such file or directory
Cantget this file to stream any ideas
Heres the mediainfo data
Unique ID : 224109895926208783223599548310755325826 (0xA899FEF5E8CCA9ADAE6CC14F93BDB782)
Complete name : J:\3D\Puss in Boots 3D.mkv
Format : Matroska
Format version : Version 2
File size : 7.23 GiB
Duration : 1h 30mn
Overall bit rate : 11.5 Mbps
Movie name : Puss in Boots 3D Half-SBS
Encoded date : UTC 2012-02-11 17:12:49
Writing application : mkvmerge v5.0.1 ('Es ist Sommer') built on Oct 9 2011 11:55:43
Writing library : libebml v1.2.2 + libmatroska v1.3.0
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 30mn
Bit rate : 10 000 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.201
Stream size : 6.13 GiB (85%)
Writing library : x264 core 120 r2146 bcd41db
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=abr / mbtree=1 / bitrate=10000 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Format : DTS
Codec ID : A_DTS
Duration : 1h 30mn
Bit rate mode : Constant
Bit rate : 1 510 Kbps
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 974 MiB (13%)
Language : English
Default : Yes
Forced : No
Any ideas why it wont work
Post Sun Feb 19, 2012 1:34 pm
did you make sure header compression was off ?
rbramhill1
Post Sun Feb 19, 2012 7:18 pm
okay whats header compression? and how would I turn it on/off
Post Sun Feb 19, 2012 7:38 pm
rbramhill1 wrote:okay whats header compression? and how would I turn it on/off
http://wiki.serviio.org/doku.php?id=header_com
rbramhill1
Post Sun Feb 19, 2012 9:50 pm
cheers but no luck with the header compression off
Users browsing this forum: Baidu [Spider] and 35 guests
