Samsung default source problem
Doodles23
Post Thu Sep 08, 2011 3:04 pm
Does anyone know how to get my Samsung UN55d8000 to stop selecting "PC" as a source default? I press the "source" button on the remote again and again until the source select reaches "Serviio". Now if I don't press "enter" by 3 seconds the source will reset itself to "PC" and I'll have to start all over again. I don't even have anything connected to the PC port.
Post Thu Sep 08, 2011 3:10 pm
Re: Samsung default source problem
You can disable the windows 7 DLNA server. That is what I do.
Post Thu Sep 08, 2011 8:09 pm
moltra wrote:You can disable the windows 7 DLNA server. That is what I do.
thats not what he asking ;)
Doodles23 wrote:Does anyone know how to get my Samsung UN55d8000 to stop selecting "PC" as a source default? I press the "source" button on the remote again and again until the source select reaches "Serviio". Now if I don't press "enter" by 3 seconds the source will reset itself to "PC" and I'll have to start all over again. I don't even have anything connected to the PC port.
sound like a TV fault to me, if you havent got anything connected to that port, i would contact the HELL that is samsung support to solve this issue.
Post Fri Sep 09, 2011 12:49 pm
sorry thought you was talking about the source DLNA. I am guessing that the source is like the Input button on my Sanyo TV. I have HDMI1, HDMI2, HDMI3, AV1, AV2, AV3, cable, digital cable. I am only using 3 of them but I have to hit the input button once for each one until I get to the one I want. Some TV's have a setting in the TV menu to disable inputs, but not all Tv's do.
Post Fri Sep 09, 2011 7:29 pm
moltra wrote:sorry thought you was talking about the source DLNA. I am guessing that the source is like the Input button on my Sanyo TV. I have HDMI1, HDMI2, HDMI3, AV1, AV2, AV3, cable, digital cable. I am only using 3 of them but I have to hit the input button once for each one until I get to the one I want. Some TV's have a setting in the TV menu to disable inputs, but not all Tv's do.
yep :) and samsung might ahve a disable ability but i dont think it does, but worth a look when i get home tomorrow, i will report back.
