Error connecting from Samsung D 6050
redi_jedi
Post Tue Sep 13, 2011 12:55 am
To keep it simple i have a single folder entered in the library with a single movie in it (divx). When I try to connect to serviio from my samsung I get an error message and no files listed. I was previously able to see music and photos but no luck with video. The error in the log says:
2011-09-12 20:41:08,515 DEBUG [ContentDirectory] Browse() called for renderer UN40D6050 (profile 7) with parameters: objectID = V_L, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 0, sortCriteria =
2011-09-12 20:41:08,515 WARN [ContentDirectory] Object with id V_L doesn't exist
2011-09-12 20:41:08,515 DEBUG [ServiceControlRequestHandler] Returning error SOAP message
I've attached the complete log file and the profiles.xml file.
Any ideas? Thanks in advance...
Copy of serviio.log
(46.46 KiB) Downloaded 635 times
profiles.xml
(34.3 KiB) Downloaded 755 times
Post Tue Sep 13, 2011 1:29 am
Re: Error connecting from Samsung D 6050
try a reinstall cause i have never seen that error before.
redi_jedi
Post Tue Sep 13, 2011 1:47 am
No go. I did a full uninstall, rebooted, reinstalled, rebooted and still get the same error. Pictures and music are okay, video doesn't show up at all.
redi_jedi
Post Tue Sep 13, 2011 2:12 am
I switched it to use the "Generic DLNA" renderer profile and now it works. Any ideas as to what the differences are between the generic and the samsung c/d profiles?
Post Wed Sep 14, 2011 12:04 pm
redi_jedi wrote:I switched it to use the "Generic DLNA" renderer profile and now it works. Any ideas as to what the differences are between the generic and the samsung c/d profiles?
remove devicedescription section from top of profile 7 in the profile.xml and try again.
tonster76
Post Tue Feb 17, 2015 2:26 pm
Thanks a lot Cerberos, that just fixed the Samsung profile for me. Was displaying "[ContentDirectory] Object with id V_L doesn't exist" since the upgrade from 1.41 to 1.50
Users browsing this forum: Google [Bot] and 73 guests
