Video Playlists
rosahas
Post Sun Sep 04, 2011 4:16 pm
Video Playlists
I own a Samsung UN55C8000 and BD-6900 and I was wondering if there is anyway to create a Video Playlists with my content?
Also, where would I look to get information on how to possibly use the default "playlist" as Producer/Genre etc to perhaps make a playlist using these features built-into Serviio?
Thanks,
RoSahas.
Post Tue Sep 06, 2011 6:18 pm
Re: Video Playlists
There is no playlist feature in the TV or serviio. (although you could kind of do this be using the yellow button ( so you manualy select each fiel to play rather than letting the tv play them one by one) from the menu but all the files you select would have to be in the same folder.)
rosahas
Post Fri Sep 09, 2011 4:48 am
Re: Video Playlists
Is there anyway to explicitly have certain files show up in the predefined "Playlists"? Such as Producer/Genre? If I can get my files to show up there then both the TV and the BD will play them in sequence automatically.
Post Fri Sep 09, 2011 5:40 am
Re: Video Playlists
nope
rosahas
Post Tue Sep 13, 2011 3:47 am
Re: Video Playlists
Cerberus wrote:nope
Bummer .. ok Thanks.
Post Tue Sep 13, 2011 8:53 am
Re: Video Playlists
there is a open ticket to support playlists, hope to make it in a version after 0.6
