BD-C5500 Unplayable Quicktime Video File
Sebanisu
Post Wed Sep 14, 2011 3:07 am
Serviio version: 0.5.2
Receiver: Samsung BD-C5500
OS: Linux Mint 10 (Ubuntu 10.10 Based)
Video: Red vs. Blue - Season 5 Episode 3 - Baby Steps
Error: Blu Ray player says "Not Supported File Format"
I think it needs to trans coded but it isn't.
Seems stream 1 codec frame rate differs from container frame rate: 5994.00 (5994/1) -> 29.97 (2997/100)
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '05x03_Baby Steps.mov':
    major_brand     : qt
    minor_version   : 537199360
    compatible_brands: qt
  Duration: 00:04:08.87, start: 0.000000, bitrate: 473 kb/s
    Stream #0.0(eng): Audio: aac, 44100 Hz, stereo, s16, 97 kb/s
    Stream #0.1(eng): Video: h264, yuv420p, 640x360, 374 kb/s, 29.97 fps, 29.97 tbr, 2997 tbn, 5994 tbc
 mediainfo 05x03_Baby\ Steps.mov
Complete name                    : 05x03_Baby Steps.mov
Format                           : MPEG-4
Format profile                   : QuickTime
Format settings                  : Compressed header
Codec ID                         : qt
File size                        : 14.0 MiB
Duration                         : 4mn 8s
Overall bit rate                 : 473 Kbps
Encoded date                     : UTC 2006-10-13 19:35:42
Tagged date                      : UTC 2006-10-13 19:35:44
Writing library                  : Apple QuickTime
Format profile                   : Main@L3.0
Format settings, CABAC           : No
Format settings, ReFrames        : 2 frames
Codec ID                         : avc1
Codec ID/Info                    : Advanced Video Coding
Duration                         : 4mn 8s
Bit rate mode                    : Variable
Bit rate                         : 374 Kbps
Width                            : 640 pixels
Height                           : 360 pixels
Frame rate mode                  : Constant
Frame rate                       : 29.970 fps
Bits/(Pixel*Frame)               : 0.054
Stream size                      : 11.1 MiB (79%)
Language                         : English
Encoded date                     : UTC 2006-10-13 19:34:58
Color primaries                  : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
Transfer characteristics         : BT.709-5, BT.1361
Matrix coefficients              : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
Format                           : AAC
Format/Info                      : Advanced Audio Codec
Format profile                   : LC
Codec ID                         : 40
Duration                         : 4mn 8s
Bit rate                         : 96.0 Kbps
Channel(s)                       : 2 channels
Channel positions                : Front: L R
Sampling rate                    : 44.1 KHz
Stream size                      : 2.88 MiB (21%)
Language                         : English
Samsung BD-C5500 And XBOX 360| Windows 7)
Post Wed Sep 14, 2011 7:41 am
Re: BD-C5500 Unplayable Quicktime Video File
What is the profile selected in the serviio console ?
Post Wed Sep 14, 2011 7:44 am
Enable serviio detailed logging file (see signature), clean the log file then restart serviio service.
Check the log file when you start this movie.
This file is probably delivered in native format and your Samsung didn't support audio in first stream and video in second, usually, video is first and audio next...
Sebanisu
Post Wed Sep 14, 2011 1:58 pm
I'll work on detailed logging. I tried to enable it last night and it seems like the thing stopped logging all together.
Profile: Samsung TV/Player (C/D Series)
Sebanisu
Post Wed Sep 14, 2011 3:08 pm
Here is the detailed log.
2011-09-14 11:02:05,958 DEBUG [ResourceTransportRequestHandler] Request for resource 974 and type 'COVER_IMAGE' received
2011-09-14 11:02:05,958 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 974
2011-09-14 11:02:05,958 DEBUG [ResourceTransportRequestHandler] Entity will be consumed till the end
2011-09-14 11:02:05,958 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: -1
2011-09-14 11:02:05,958 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-09-14 11:02:05,958 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Date: Wed, 14 Sep 2011 15:02:05 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive]]
2011-09-14 11:02:09,061 DEBUG [WebServer] Incoming connection from /10.42.43.20:53410
2011-09-14 11:02:09,061 DEBUG [ResourceTransportRequestHandler] HEAD /resource/948/MEDIA_ITEM/AVC_MP4_MP_SD_AAC_MULT5$0 HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,Host: 10.42.43.1:8895]]
2011-09-14 11:02:09,061 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.42.43.20
2011-09-14 11:02:09,062 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/10.42.43.20, Profile=Samsung TV / player (C/D-series)'
2011-09-14 11:02:09,065 DEBUG [ResourceTransportRequestHandler] Request for resource 948 and type 'MEDIA_ITEM' received
2011-09-14 11:02:09,065 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 948, format AVC_MP4_MP_SD_AAC_MULT5 and profile Samsung TV / player (C/D-series)
2011-09-14 11:02:09,066 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2011-09-14 11:02:09,066 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mp4,Content-Length: 37757747,Date: Wed, 14 Sep 2011 15:02:09 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_MULT5;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-09-14 11:02:09,085 DEBUG [WebServer] Incoming connection from /10.42.43.20:43058
2011-09-14 11:02:09,085 DEBUG [ResourceTransportRequestHandler] GET /resource/948/MEDIA_ITEM/AVC_MP4_MP_SD_AAC_MULT5$0 HTTP/1.0, headers = [Range: bytes=0-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,getMediaInfo.sec: 1,Host: 10.42.43.1:8895]]
2011-09-14 11:02:09,086 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.42.43.20
2011-09-14 11:02:09,086 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/10.42.43.20, Profile=Samsung TV / player (C/D-series)'
2011-09-14 11:02:09,086 DEBUG [ResourceTransportRequestHandler] Request for resource 948 and type 'MEDIA_ITEM' received
2011-09-14 11:02:09,088 DEBUG [VideoDeliveryEngine] Delivering item '948' for client 'IPAddress=/10.42.43.20, Profile=Samsung TV / player (C/D-series)'
2011-09-14 11:02:09,088 DEBUG [VideoDeliveryEngine] Delivering file '05x01_You Can't Park Here.mov' in native format
2011-09-14 11:02:09,205 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2011-09-14 11:02:09,205 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 37757747
2011-09-14 11:02:09,205 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-09-14 11:02:09,205 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mp4,Content-Range: bytes 0-37757746/37757747,Content-Length: 37757747,Date: Wed, 14 Sep 2011 15:02:09 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_MULT5;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,MediaInfo.sec: SEC_Duration=398000;]]
2011-09-14 11:02:09,537 DEBUG [WebServer] Incoming connection from /10.42.43.20:54334
2011-09-14 11:02:09,537 DEBUG [ResourceTransportRequestHandler] HEAD /resource/948/MEDIA_ITEM/AVC_MP4_MP_SD_AAC_MULT5$0 HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,Host: 10.42.43.1:8895]]
2011-09-14 11:02:09,537 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.42.43.20
2011-09-14 11:02:09,538 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/10.42.43.20, Profile=Samsung TV / player (C/D-series)'
2011-09-14 11:02:09,538 DEBUG [ResourceTransportRequestHandler] Request for resource 948 and type 'MEDIA_ITEM' received
2011-09-14 11:02:09,539 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 948, format AVC_MP4_MP_SD_AAC_MULT5 and profile Samsung TV / player (C/D-series)
2011-09-14 11:02:09,539 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2011-09-14 11:02:09,539 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mp4,Content-Length: 37757747,Date: Wed, 14 Sep 2011 15:02:09 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_MULT5;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-09-14 11:02:09,544 DEBUG [WebServer] I/O error: Connection reset
2011-09-14 11:02:09,553 DEBUG [WebServer] Incoming connection from /10.42.43.20:36066
2011-09-14 11:02:09,554 DEBUG [ResourceTransportRequestHandler] GET /resource/948/MEDIA_ITEM/AVC_MP4_MP_SD_AAC_MULT5$0 HTTP/1.0, headers = [Range: bytes=0-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,getMediaInfo.sec: 1,Host: 10.42.43.1:8895]]
2011-09-14 11:02:09,555 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.42.43.20
2011-09-14 11:02:09,555 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/10.42.43.20, Profile=Samsung TV / player (C/D-series)'
2011-09-14 11:02:09,555 DEBUG [ResourceTransportRequestHandler] Request for resource 948 and type 'MEDIA_ITEM' received
2011-09-14 11:02:09,556 DEBUG [VideoDeliveryEngine] Delivering item '948' for client 'IPAddress=/10.42.43.20, Profile=Samsung TV / player (C/D-series)'
2011-09-14 11:02:09,556 DEBUG [VideoDeliveryEngine] Delivering file '05x01_You Can't Park Here.mov' in native format
2011-09-14 11:02:09,580 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2011-09-14 11:02:09,580 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 37757747
2011-09-14 11:02:09,581 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-09-14 11:02:09,581 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mp4,Content-Range: bytes 0-37757746/37757747,Content-Length: 37757747,Date: Wed, 14 Sep 2011 15:02:09 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_MULT5;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,MediaInfo.sec: SEC_Duration=398000;]]
2011-09-14 11:02:09,601 DEBUG [WebServer] Incoming connection from /10.42.43.20:34485
2011-09-14 11:02:09,601 DEBUG [ResourceTransportRequestHandler] HEAD /resource/948/MEDIA_ITEM/AVC_MP4_MP_SD_AAC_MULT5$0 HTTP/1.0, headers = [getCaptionInfo.sec: 1]]
2011-09-14 11:02:09,601 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.42.43.20
2011-09-14 11:02:09,602 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/10.42.43.20, Profile=Samsung TV / player (C/D-series)'
2011-09-14 11:02:09,602 DEBUG [ResourceTransportRequestHandler] Request for resource 948 and type 'MEDIA_ITEM' received
2011-09-14 11:02:09,602 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 948, format AVC_MP4_MP_SD_AAC_MULT5 and profile Samsung TV / player (C/D-series)
2011-09-14 11:02:09,611 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2011-09-14 11:02:09,612 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mp4,Content-Length: 37757747,Date: Wed, 14 Sep 2011 15:02:09 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,transferMode.dlna.org: Streaming,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_MULT5;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000]]
2011-09-14 11:02:10,216 DEBUG [WebServer] I/O error: Connection reset
2011-09-14 11:02:13,242 DEBUG [WebServer] Incoming connection from /10.42.43.20:49807
2011-09-14 11:02:13,242 DEBUG [ResourceTransportRequestHandler] HEAD /resource/949/MEDIA_ITEM/AVC_MP4_MP_SD_AAC_MULT5$0 HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,Host: 10.42.43.1:8895]]
2011-09-14 11:02:13,242 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.42.43.20
2011-09-14 11:02:13,243 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/10.42.43.20, Profile=Samsung TV / player (C/D-series)'
2011-09-14 11:02:13,243 DEBUG [ResourceTransportRequestHandler] Request for resource 949 and type 'MEDIA_ITEM' received
2011-09-14 11:02:13,243 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 949, format AVC_MP4_MP_SD_AAC_MULT5 and profile Samsung TV / player (C/D-series)
2011-09-14 11:02:13,244 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2011-09-14 11:02:13,244 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mp4,Content-Length: 15602650,Date: Wed, 14 Sep 2011 15:02:13 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_MULT5;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-09-14 11:02:13,253 DEBUG [WebServer] Incoming connection from /10.42.43.20:45948
2011-09-14 11:02:13,253 DEBUG [ResourceTransportRequestHandler] GET /resource/949/MEDIA_ITEM/AVC_MP4_MP_SD_AAC_MULT5$0 HTTP/1.0, headers = [Range: bytes=0-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,getMediaInfo.sec: 1,Host: 10.42.43.1:8895]]
2011-09-14 11:02:13,253 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.42.43.20
2011-09-14 11:02:13,253 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/10.42.43.20, Profile=Samsung TV / player (C/D-series)'
2011-09-14 11:02:13,254 DEBUG [ResourceTransportRequestHandler] Request for resource 949 and type 'MEDIA_ITEM' received
2011-09-14 11:02:13,255 DEBUG [VideoDeliveryEngine] Delivering item '949' for client 'IPAddress=/10.42.43.20, Profile=Samsung TV / player (C/D-series)'
2011-09-14 11:02:13,255 DEBUG [VideoDeliveryEngine] Delivering file '05x02_Got Your Back.mov' in native format
2011-09-14 11:02:13,276 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2011-09-14 11:02:13,276 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 15602650
2011-09-14 11:02:13,276 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-09-14 11:02:13,276 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mp4,Content-Range: bytes 0-15602649/15602650,Content-Length: 15602650,Date: Wed, 14 Sep 2011 15:02:13 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_MULT5;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,MediaInfo.sec: SEC_Duration=287000;]]
2011-09-14 11:02:13,419 DEBUG [WebServer] I/O error: Connection reset
2011-09-14 11:02:13,429 DEBUG [WebServer] Incoming connection from /10.42.43.20:35718
2011-09-14 11:02:13,429 DEBUG [ResourceTransportRequestHandler] HEAD /resource/949/MEDIA_ITEM/AVC_MP4_MP_SD_AAC_MULT5$0 HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,Host: 10.42.43.1:8895]]
2011-09-14 11:02:13,429 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.42.43.20
2011-09-14 11:02:13,430 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/10.42.43.20, Profile=Samsung TV / player (C/D-series)'
2011-09-14 11:02:13,430 DEBUG [ResourceTransportRequestHandler] Request for resource 949 and type 'MEDIA_ITEM' received
2011-09-14 11:02:13,431 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 949, format AVC_MP4_MP_SD_AAC_MULT5 and profile Samsung TV / player (C/D-series)
2011-09-14 11:02:13,431 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2011-09-14 11:02:13,431 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mp4,Content-Length: 15602650,Date: Wed, 14 Sep 2011 15:02:13 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_MULT5;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-09-14 11:02:13,447 DEBUG [WebServer] Incoming connection from /10.42.43.20:41952
2011-09-14 11:02:13,447 DEBUG [ResourceTransportRequestHandler] GET /resource/949/MEDIA_ITEM/AVC_MP4_MP_SD_AAC_MULT5$0 HTTP/1.0, headers = [Range: bytes=0-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,getMediaInfo.sec: 1,Host: 10.42.43.1:8895]]
2011-09-14 11:02:13,447 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.42.43.20
2011-09-14 11:02:13,447 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/10.42.43.20, Profile=Samsung TV / player (C/D-series)'
2011-09-14 11:02:13,448 DEBUG [ResourceTransportRequestHandler] Request for resource 949 and type 'MEDIA_ITEM' received
2011-09-14 11:02:13,449 DEBUG [VideoDeliveryEngine] Delivering item '949' for client 'IPAddress=/10.42.43.20, Profile=Samsung TV / player (C/D-series)'
2011-09-14 11:02:13,449 DEBUG [VideoDeliveryEngine] Delivering file '05x02_Got Your Back.mov' in native format
2011-09-14 11:02:13,475 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2011-09-14 11:02:13,476 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 15602650
2011-09-14 11:02:13,476 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-09-14 11:02:13,476 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mp4,Content-Range: bytes 0-15602649/15602650,Content-Length: 15602650,Date: Wed, 14 Sep 2011 15:02:13 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_MULT5;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,MediaInfo.sec: SEC_Duration=287000;]]
2011-09-14 11:02:13,497 DEBUG [WebServer] Incoming connection from /10.42.43.20:35175
2011-09-14 11:02:13,497 DEBUG [ResourceTransportRequestHandler] HEAD /resource/949/MEDIA_ITEM/AVC_MP4_MP_SD_AAC_MULT5$0 HTTP/1.0, headers = [getCaptionInfo.sec: 1]]
2011-09-14 11:02:13,497 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.42.43.20
2011-09-14 11:02:13,498 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/10.42.43.20, Profile=Samsung TV / player (C/D-series)'
2011-09-14 11:02:13,498 DEBUG [ResourceTransportRequestHandler] Request for resource 949 and type 'MEDIA_ITEM' received
2011-09-14 11:02:13,498 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 949, format AVC_MP4_MP_SD_AAC_MULT5 and profile Samsung TV / player (C/D-series)
2011-09-14 11:02:13,508 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2011-09-14 11:02:13,508 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mp4,Content-Length: 15602650,Date: Wed, 14 Sep 2011 15:02:13 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,transferMode.dlna.org: Streaming,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_MULT5;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000]]
2011-09-14 11:02:14,086 DEBUG [WebServer] I/O error: Connection reset
2011-09-14 11:02:15,794 DEBUG [ImageUtils] Starting image resize, size = 324327 bytes
2011-09-14 11:02:15,989 DEBUG [ImageUtils] Returning resized image, size = 6745 bytes
Just a sub section of the log since it's so much stuff. I just put it the folder of season 5 and pushed play. The Blu Ray player just kept popping up the error message and then going to the next file.
Post Wed Sep 14, 2011 3:19 pm
Sebanisu wrote:Here is the detailed log.
Thanks, that confirm that files are delivered in native format, so no change from Serviio/ffmpeg side.
Your player seems not support such files, why ?
Audio and video track position is an idea, could you check with "ffmpeg -i" command the configuration of some files?
Where did these files come from? downloading, ripping,camera, etc?
Sebanisu
Post Wed Sep 14, 2011 3:57 pm
Downloaded them. I believe these are the original quicktime uploads to http://roosterteeth.com/home.php
It's been a while since I've downloaded them. I was just throwing stuff at Serviio and those were the first files that didn't play. I'm gonna try to the ffmpeg -i thing once my dang computer stops lagging.
I have played them fine in VLC player.
Sebanisu
Post Wed Sep 14, 2011 4:06 pm
ffmpeg -i 05x01_You\ Can\'t\ Park\ Here.mov
FFmpeg version 0.6-4:0.6-2ubuntu6.1, Copyright (c) 2000-2010 the FFmpeg developers
  built on Mar 31 2011 18:42:12 with gcc 4.4.5
  configuration: --extra-version=4:0.6-2ubuntu6.1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-vaapi --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-gpl --enable-postproc --enable-x11grab --enable-libdc1394 --enable-shared --disable-static
  WARNING: library configuration mismatch
  libavutil   configuration: --extra-version=4:0.6-2ubuntu3.1+medibuntu1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libdirac --enable-libgsm --enable-libopenjpeg --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-vaapi --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-libmp3lame --enable-libfaac --enable-nonfree --enable-gpl --enable-postproc --enable-x11grab --enable-libfaad --enable-libxvid --enable-libx264 --enable-librtmp --enable-libopencore-amrnb --enable-version3 --enable-libopencore-amrwb --enable-version3 --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
  libavcodec  configuration: --extra-version=4:0.6-2ubuntu3.1+medibuntu1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libdirac --enable-libgsm --enable-libopenjpeg --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-vaapi --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-libmp3lame --enable-libfaac --enable-nonfree --enable-gpl --enable-postproc --enable-x11grab --enable-libfaad --enable-libxvid --enable-libx264 --enable-librtmp --enable-libopencore-amrnb --enable-version3 --enable-libopencore-amrwb --enable-version3 --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
  libavformat configuration: --extra-version=4:0.6-2ubuntu6.1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-vaapi --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-gpl --enable-postproc --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
  libavdevice configuration: --extra-version=4:0.6-2ubuntu6.1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-vaapi --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-gpl --enable-postproc --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
  libavfilter configuration: --extra-version=4:0.6-2ubuntu6.1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-vaapi --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-gpl --enable-postproc --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
  libswscale  configuration: --extra-version=4:0.6-2ubuntu6.1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-vaapi --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-gpl --enable-postproc --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
  libpostproc configuration: --extra-version=4:0.6-2ubuntu6.1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-vaapi --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-gpl --enable-postproc --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
  libavutil     50.15. 1 / 50.15. 1
  libavcodec    52.72. 2 / 52.72. 2
  libavformat   52.64. 2 / 52.64. 2
  libavdevice   52. 2. 0 / 52. 2. 0
  libavfilter    1.19. 0 /  1.19. 0
  libswscale     0.11. 0 /  0.11. 0
  libpostproc   51. 2. 0 / 51. 2. 0
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '05x01_You Can't Park Here.mov':
    major_brand     : qt
  Duration: 00:06:38.64, start: 0.000000, bitrate: 757 kb/s
    Stream #0.1(eng): Video: h264, yuv420p, 640x360, 658 kb/s, 29.97 fps, 29.97 tbr, 2997 tbn, 5994 tbc
ffmpeg -i 05x02_Got\ Your\ Back.mov
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '05x02_Got Your Back.mov':
    major_brand     : qt
  Duration: 00:04:47.55, start: 0.000000, bitrate: 434 kb/s
    Stream #0.0(eng): Audio: aac, 44100 Hz, stereo, s16, 96 kb/s
    Stream #0.1(eng): Video: h264, yuv420p, 640x360, 335 kb/s, 29.97 fps, 29.97 tbr, 2997 tbn, 5994 tbc
ffmpeg -i 05x04_Sibling\ Arrivalries.mov
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '05x04_Sibling Arrivalries.mov':
    major_brand     : qt
  Duration: 00:04:49.73, start: 0.000000, bitrate: 860 kb/s
    Stream #0.0(eng): Audio: aac, 44100 Hz, stereo, s16, 98 kb/s
    Stream #0.1(eng): Video: h264, yuv420p, 640x360, 760 kb/s, 29.97 fps, 29.97 tbr, 2997 tbn, 5994 tbc
Post Wed Sep 14, 2011 4:22 pm
Sebanisu wrote:...I'm gonna try to the ffmpeg -i...
OK so all your mov file are with audio first then video .
All software will play well, but some renderers (TV) decoder could be more sensitives.
So you have to remux them.
Sebanisu
Post Wed Sep 14, 2011 4:26 pm
Re: BD-C5500 Unplayable Quicktime and WMV Video Files
I was thinking about it while I was sitting here what other files of odd formats have I not tried yet. Found some wmv's They play find in VLC and it won't stream. Though, I think it is trying to trans-code. *shrugs* Though just ignore this if I should post it in another thread.
ffmpeg -i Dead_Fantasy_ep1_hd.wmv
Seems stream 1 codec frame rate differs from container frame rate: 1000.00 (1000/1) -> 29.97 (30000/1001)
Input #0, asf, from 'Dead_Fantasy_ep1_hd.wmv':
    WMFSDKVersion   : 10.00.00.4054
    WMFSDKNeeded    : 0.0.0.0000
    IsVBR           : 1
    VBR Peak        : 388
    Buffer Average  : 259
  Duration: 00:03:53.96, start: 4.000000, bitrate: 3357 kb/s
    Stream #0.0: Audio: wmav2, 48000 Hz, 2 channels, s16, 192 kb/s
    Stream #0.1: Video: wmv3, yuv420p, 1280x720, 29.97 tbr, 1k tbn, 1k tbc
Detailed Log:
2011-09-14 12:13:51,632 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.42.43.20
2011-09-14 12:13:51,645 DEBUG [ContentDirectory] Browse() called for renderer Samsung TV / player (C/D-series) (profile 7) with parameters: objectID = V_S#SER_148#SSN_1, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx, sec:dcmInfo, sec:MetaFileInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 1, count = 1, sortCriteria =
2011-09-14 12:13:51,717 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 8841 and profile Samsung TV / player (C/D-series)
2011-09-14 12:13:51,725 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_resetafterplay), returning it
2011-09-14 12:13:51,727 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-09-14 12:13:51,749 DEBUG [WebServer] Incoming connection from /10.42.43.20:42057
2011-09-14 12:13:51,749 DEBUG [ResourceTransportRequestHandler] HEAD /resource/8841/MEDIA_ITEM/WMVHIGH_FULL$0 HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,Host: 10.42.43.1:8895]]
2011-09-14 12:13:51,749 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.42.43.20
2011-09-14 12:13:51,750 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/10.42.43.20, Profile=Samsung TV / player (C/D-series)'
2011-09-14 12:13:51,750 DEBUG [ResourceTransportRequestHandler] Request for resource 8841 and type 'MEDIA_ITEM' received
2011-09-14 12:13:51,750 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 8841, format WMVHIGH_FULL and profile Samsung TV / player (C/D-series)
2011-09-14 12:13:51,751 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2011-09-14 12:13:51,751 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/x-ms-wmv,Content-Length: 98198812,Date: Wed, 14 Sep 2011 16:13:51 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=WMVHIGH_FULL;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-09-14 12:13:51,763 DEBUG [WebServer] Incoming connection from /10.42.43.20:54789
2011-09-14 12:13:51,764 DEBUG [ResourceTransportRequestHandler] GET /resource/8841/MEDIA_ITEM/WMVHIGH_FULL$0 HTTP/1.0, headers = [Range: bytes=0-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,getMediaInfo.sec: 1,Host: 10.42.43.1:8895]]
2011-09-14 12:13:51,764 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.42.43.20
2011-09-14 12:13:51,764 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/10.42.43.20, Profile=Samsung TV / player (C/D-series)'
2011-09-14 12:13:51,764 DEBUG [ResourceTransportRequestHandler] Request for resource 8841 and type 'MEDIA_ITEM' received
2011-09-14 12:13:51,768 DEBUG [VideoDeliveryEngine] Delivering item '8841' for client 'IPAddress=/10.42.43.20, Profile=Samsung TV / player (C/D-series)'
2011-09-14 12:13:51,768 DEBUG [VideoDeliveryEngine] Delivering file 'Dead_Fantasy_ep1_hd.wmv' in native format
2011-09-14 12:13:51,811 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2011-09-14 12:13:51,811 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 98198812
2011-09-14 12:13:51,811 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-09-14 12:13:51,811 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-ms-wmv,Content-Range: bytes 0-98198811/98198812,Content-Length: 98198812,Date: Wed, 14 Sep 2011 16:13:51 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=WMVHIGH_FULL;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,MediaInfo.sec: SEC_Duration=233000;]]
2011-09-14 12:13:51,854 DEBUG [WebServer] I/O error: Connection reset
2011-09-14 12:13:51,861 DEBUG [WebServer] Incoming connection from /10.42.43.20:60509
2011-09-14 12:13:51,862 DEBUG [ResourceTransportRequestHandler] GET /resource/8841/MEDIA_ITEM/WMVHIGH_FULL$0 HTTP/1.0, headers = [Range: bytes=98189312-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 10.42.43.1:8895]]
2011-09-14 12:13:51,862 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.42.43.20
2011-09-14 12:13:51,862 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/10.42.43.20, Profile=Samsung TV / player (C/D-series)'
2011-09-14 12:13:51,862 DEBUG [ResourceTransportRequestHandler] Request for resource 8841 and type 'MEDIA_ITEM' received
2011-09-14 12:13:51,863 DEBUG [VideoDeliveryEngine] Delivering item '8841' for client 'IPAddress=/10.42.43.20, Profile=Samsung TV / player (C/D-series)'
2011-09-14 12:13:51,863 DEBUG [VideoDeliveryEngine] Delivering file 'Dead_Fantasy_ep1_hd.wmv' in native format
2011-09-14 12:13:51,874 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 9500
2011-09-14 12:13:51,874 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-09-14 12:13:51,874 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-ms-wmv,Content-Range: bytes 98189312-98198811/98198812,Content-Length: 9500,Date: Wed, 14 Sep 2011 16:13:51 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=WMVHIGH_FULL;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-09-14 12:13:51,964 DEBUG [WebServer] Incoming connection from /10.42.43.20:51508
2011-09-14 12:13:51,965 DEBUG [ResourceTransportRequestHandler] HEAD /resource/8841/MEDIA_ITEM/WMVHIGH_FULL$0 HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,Host: 10.42.43.1:8895]]
2011-09-14 12:13:51,965 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.42.43.20
2011-09-14 12:13:51,965 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/10.42.43.20, Profile=Samsung TV / player (C/D-series)'
2011-09-14 12:13:51,965 DEBUG [ResourceTransportRequestHandler] Request for resource 8841 and type 'MEDIA_ITEM' received
2011-09-14 12:13:51,966 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 8841, format WMVHIGH_FULL and profile Samsung TV / player (C/D-series)
2011-09-14 12:13:51,967 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2011-09-14 12:13:51,967 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/x-ms-wmv,Content-Length: 98198812,Date: Wed, 14 Sep 2011 16:13:51 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=WMVHIGH_FULL;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-09-14 12:13:51,977 DEBUG [WebServer] Incoming connection from /10.42.43.20:51656
2011-09-14 12:13:51,978 DEBUG [ResourceTransportRequestHandler] GET /resource/8841/MEDIA_ITEM/WMVHIGH_FULL$0 HTTP/1.0, headers = [Range: bytes=0-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,getMediaInfo.sec: 1,Host: 10.42.43.1:8895]]
2011-09-14 12:13:51,978 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.42.43.20
2011-09-14 12:13:51,978 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/10.42.43.20, Profile=Samsung TV / player (C/D-series)'
2011-09-14 12:13:51,978 DEBUG [ResourceTransportRequestHandler] Request for resource 8841 and type 'MEDIA_ITEM' received
2011-09-14 12:13:51,979 DEBUG [VideoDeliveryEngine] Delivering item '8841' for client 'IPAddress=/10.42.43.20, Profile=Samsung TV / player (C/D-series)'
2011-09-14 12:13:51,979 DEBUG [VideoDeliveryEngine] Delivering file 'Dead_Fantasy_ep1_hd.wmv' in native format
2011-09-14 12:13:52,000 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2011-09-14 12:13:52,000 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 98198812
2011-09-14 12:13:52,000 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-09-14 12:13:52,000 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-ms-wmv,Content-Range: bytes 0-98198811/98198812,Content-Length: 98198812,Date: Wed, 14 Sep 2011 16:13:52 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=WMVHIGH_FULL;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,MediaInfo.sec: SEC_Duration=233000;]]
2011-09-14 12:13:52,018 DEBUG [WebServer] Incoming connection from /10.42.43.20:34865
2011-09-14 12:13:52,019 DEBUG [ResourceTransportRequestHandler] HEAD /resource/8841/MEDIA_ITEM/WMVHIGH_FULL$0 HTTP/1.0, headers = [getCaptionInfo.sec: 1]]
2011-09-14 12:13:52,019 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.42.43.20
2011-09-14 12:13:52,020 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/10.42.43.20, Profile=Samsung TV / player (C/D-series)'
2011-09-14 12:13:52,020 DEBUG [ResourceTransportRequestHandler] Request for resource 8841 and type 'MEDIA_ITEM' received
2011-09-14 12:13:52,020 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 8841, format WMVHIGH_FULL and profile Samsung TV / player (C/D-series)
2011-09-14 12:13:52,027 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2011-09-14 12:13:52,027 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/x-ms-wmv,Content-Length: 98198812,Date: Wed, 14 Sep 2011 16:13:52 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,transferMode.dlna.org: Streaming,contentFeatures.dlna.org: DLNA.ORG_PN=WMVHIGH_FULL;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000]]
2011-09-14 12:13:52,392 DEBUG [WebServer] I/O error: Connection reset
2011-09-14 12:13:52,401 DEBUG [WebServer] Incoming connection from /10.42.43.20:51721
2011-09-14 12:13:52,401 DEBUG [ResourceTransportRequestHandler] GET /resource/8841/MEDIA_ITEM/WMVHIGH_FULL$0 HTTP/1.0, headers = [Range: bytes=98197322-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 10.42.43.1:8895]]
2011-09-14 12:13:52,401 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.42.43.20
2011-09-14 12:13:52,402 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/10.42.43.20, Profile=Samsung TV / player (C/D-series)'
2011-09-14 12:13:52,402 DEBUG [ResourceTransportRequestHandler] Request for resource 8841 and type 'MEDIA_ITEM' received
2011-09-14 12:13:52,402 DEBUG [VideoDeliveryEngine] Delivering item '8841' for client 'IPAddress=/10.42.43.20, Profile=Samsung TV / player (C/D-series)'
2011-09-14 12:13:52,402 DEBUG [VideoDeliveryEngine] Delivering file 'Dead_Fantasy_ep1_hd.wmv' in native format
2011-09-14 12:13:52,408 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 1490
2011-09-14 12:13:52,408 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-09-14 12:13:52,408 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-ms-wmv,Content-Range: bytes 98197322-98198811/98198812,Content-Length: 1490,Date: Wed, 14 Sep 2011 16:13:52 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=WMVHIGH_FULL;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-09-14 12:13:52,425 DEBUG [WebServer] Incoming connection from /10.42.43.20:36115
2011-09-14 12:13:52,425 DEBUG [ResourceTransportRequestHandler] GET /resource/8841/MEDIA_ITEM/WMVHIGH_FULL$0 HTTP/1.0, headers = [Range: bytes=98197402-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 10.42.43.1:8895]]
2011-09-14 12:13:52,425 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.42.43.20
2011-09-14 12:13:52,426 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/10.42.43.20, Profile=Samsung TV / player (C/D-series)'
2011-09-14 12:13:52,426 DEBUG [ResourceTransportRequestHandler] Request for resource 8841 and type 'MEDIA_ITEM' received
2011-09-14 12:13:52,431 DEBUG [VideoDeliveryEngine] Delivering item '8841' for client 'IPAddress=/10.42.43.20, Profile=Samsung TV / player (C/D-series)'
2011-09-14 12:13:52,431 DEBUG [VideoDeliveryEngine] Delivering file 'Dead_Fantasy_ep1_hd.wmv' in native format
2011-09-14 12:13:52,432 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 1410
2011-09-14 12:13:52,432 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-09-14 12:13:52,432 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-ms-wmv,Content-Range: bytes 98197402-98198811/98198812,Content-Length: 1410,Date: Wed, 14 Sep 2011 16:13:52 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=WMVHIGH_FULL;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-09-14 12:13:52,573 DEBUG [WebServer] Incoming connection from /10.42.43.20:45426
2011-09-14 12:13:52,573 DEBUG [ResourceTransportRequestHandler] GET /resource/8841/MEDIA_ITEM/WMVHIGH_FULL$0 HTTP/1.0, headers = [Range: bytes=16384-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 10.42.43.1:8895]]
2011-09-14 12:13:52,573 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.42.43.20
2011-09-14 12:13:52,574 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/10.42.43.20, Profile=Samsung TV / player (C/D-series)'
2011-09-14 12:13:52,574 DEBUG [ResourceTransportRequestHandler] Request for resource 8841 and type 'MEDIA_ITEM' received
2011-09-14 12:13:52,574 DEBUG [VideoDeliveryEngine] Delivering item '8841' for client 'IPAddress=/10.42.43.20, Profile=Samsung TV / player (C/D-series)'
2011-09-14 12:13:52,574 DEBUG [VideoDeliveryEngine] Delivering file 'Dead_Fantasy_ep1_hd.wmv' in native format
2011-09-14 12:13:52,579 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 98182428
2011-09-14 12:13:52,579 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-09-14 12:13:52,579 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-ms-wmv,Content-Range: bytes 16384-98198811/98198812,Content-Length: 98182428,Date: Wed, 14 Sep 2011 16:13:52 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=WMVHIGH_FULL;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-09-14 12:14:05,054 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:fc7e3a04-0776-388b-81e5-bc82f315988c from address /10.42.43.20:1025
2011-09-14 12:14:05,055 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /10.42.43.20:1025
2011-09-14 12:14:05,354 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:fc7e3a04-0776-388b-81e5-bc82f315988c from address /10.42.43.20:1025
2011-09-14 12:14:05,355 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /10.42.43.20:1025
2011-09-14 12:14:05,655 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:fc7e3a04-0776-388b-81e5-bc82f315988c from address /10.42.43.20:1025
2011-09-14 12:14:05,655 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /10.42.43.20:1025
2011-09-14 12:14:19,545 DEBUG [ProcessExecutor] Stopping external process: Thread[Thread-3996,1,main]
2011-09-14 12:14:19,547 WARN  [OutputTextReader] Error reading output of an external command:Stream Closed
2011-09-14 12:14:19,904 DEBUG [ImageUtils] Starting image resize, size = 455933 bytes
2011-09-14 12:14:20,052 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:fc7e3a04-0776-388b-81e5-bc82f315988c from address /10.42.43.20:1025
2011-09-14 12:14:20,053 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /10.42.43.20:1025
2011-09-14 12:14:20,352 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:fc7e3a04-0776-388b-81e5-bc82f315988c from address /10.42.43.20:1025
2011-09-14 12:14:20,353 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /10.42.43.20:1025
2011-09-14 12:14:20,653 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:fc7e3a04-0776-388b-81e5-bc82f315988c from address /10.42.43.20:1025
2011-09-14 12:14:20,653 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /10.42.43.20:1025
2011-09-14 12:14:22,133 DEBUG [ImageUtils] Returning resized image, size = 6663 bytes
2011-09-14 12:14:22,551 INFO  [LibraryUpdatesCheckerThread] Updated 'Harry Potter and the Sorcerer's Stone' (/media/3TBMedia/Media/Video/Movies/Harry Potter Collection/Harry Potter and the Sorcerer's Stone [2001]/Harry Potter and the Sorcerer's Stone.mkv) in Library
2011-09-14 12:14:22,583 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: /media/3TBMedia/Media/Video/Movies/Lara Croft Collection/Lara Croft Tomb Raider The Cradle of Life [2003]/Lara Croft Tomb Raider The Cradle of Life.mkv
2011-09-14 12:14:22,583 DEBUG [ProcessExecutor] Starting ffmpeg -i /media/3TBMedia/Media/Video/Movies/Lara Croft Collection/Lara Croft Tomb Raider The Cradle of Life [2003]/Lara Croft Tomb Raider The Cradle of Life.mkv
2011-09-14 12:14:22,770 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve thumbnail for file: /media/3TBMedia/Media/Video/Movies/Lara Croft Collection/Lara Croft Tomb Raider The Cradle of Life [2003]/Lara Croft Tomb Raider The Cradle of Life.mkv
2011-09-14 12:14:22,771 DEBUG [ProcessExecutor] Starting ffmpeg -i /media/3TBMedia/Media/Video/Movies/Lara Croft Collection/Lara Croft Tomb Raider The Cradle of Life [2003]/Lara Croft Tomb Raider The Cradle of Life.mkv -an -ss 120 -vframes 1 -f image2 pipe:
2011-09-14 12:14:22,924 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2011-09-14 12:14:22,924 DEBUG [LocalContentCacheDecorator] Cleared cache (local_default)
2011-09-14 12:14:23,568 DEBUG [WebServer] Incoming connection from /10.42.43.20:56374
2011-09-14 12:14:23,569 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#X_SetBookmark"' from 10.42.43.20:
2011-09-14 12:14:23,569 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.42.43.20
2011-09-14 12:14:23,594 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 8841 and profile Samsung TV / player (C/D-series)
2011-09-14 12:14:23,605 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2011-09-14 12:14:23,605 DEBUG [LocalContentCacheDecorator] Cleared cache (local_default)
2011-09-14 12:14:23,606 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-09-14 12:14:23,621 DEBUG [WebServer] Incoming connection from /10.42.43.20:53390
2011-09-14 12:14:23,621 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 10.42.43.20:
2011-09-14 12:14:23,621 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.42.43.20
2011-09-14 12:14:23,630 DEBUG [ContentDirectory] Browse() called for renderer Samsung TV / player (C/D-series) (profile 7) with parameters: objectID = V_S#SER_148#SSN_1, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx, sec:dcmInfo, sec:MetaFileInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 1, count = 1, sortCriteria =
2011-09-14 12:14:23,645 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 8841 and profile Samsung TV / player (C/D-series)
2011-09-14 12:14:23,653 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_resetafterplay), returning it
2011-09-14 12:14:23,671 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-09-14 12:14:23,676 DEBUG [WebServer] I/O error: Connection reset
2011-09-14 12:14:26,688 DEBUG [WebServer] Incoming connection from /10.42.43.20:49899
2011-09-14 12:14:26,688 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 10.42.43.20:
2011-09-14 12:14:26,688 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.42.43.20
2011-09-14 12:14:26,698 DEBUG [ContentDirectory] Browse() called for renderer Samsung TV / player (C/D-series) (profile 7) with parameters: objectID = V_S#SER_148#SSN_1, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx, sec:dcmInfo, sec:MetaFileInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 2, count = 1, sortCriteria =
2011-09-14 12:14:26,769 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 8837 and profile Samsung TV / player (C/D-series)
2011-09-14 12:14:26,771 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_resetafterplay), returning it
2011-09-14 12:14:26,774 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-09-14 12:14:26,817 DEBUG [WebServer] Incoming connection from /10.42.43.20:38566
2011-09-14 12:14:26,817 DEBUG [ResourceTransportRequestHandler] HEAD /resource/8837/MEDIA_ITEM/WMVHIGH_FULL$0 HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,Host: 10.42.43.1:8895]]
2011-09-14 12:14:26,817 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.42.43.20
2011-09-14 12:14:26,818 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/10.42.43.20, Profile=Samsung TV / player (C/D-series)'
2011-09-14 12:14:26,819 DEBUG [ResourceTransportRequestHandler] Request for resource 8837 and type 'MEDIA_ITEM' received
2011-09-14 12:14:26,820 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 8837, format WMVHIGH_FULL and profile Samsung TV / player (C/D-series)
2011-09-14 12:14:26,820 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2011-09-14 12:14:26,820 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/x-ms-wmv,Content-Length: 267145323,Date: Wed, 14 Sep 2011 16:14:26 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=WMVHIGH_FULL;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-09-14 12:14:26,841 DEBUG [WebServer] Incoming connection from /10.42.43.20:51273
2011-09-14 12:14:26,842 DEBUG [ResourceTransportRequestHandler] GET /resource/8837/MEDIA_ITEM/WMVHIGH_FULL$0 HTTP/1.0, headers = [Range: bytes=0-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,getMediaInfo.sec: 1,Host: 10.42.43.1:8895]]
2011-09-14 12:14:26,842 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.42.43.20
2011-09-14 12:14:26,842 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/10.42.43.20, Profile=Samsung TV / player (C/D-series)'
2011-09-14 12:14:26,842 DEBUG [ResourceTransportRequestHandler] Request for resource 8837 and type 'MEDIA_ITEM' received
2011-09-14 12:14:26,843 DEBUG [VideoDeliveryEngine] Delivering item '8837' for client 'IPAddress=/10.42.43.20, Profile=Samsung TV / player (C/D-series)'
2011-09-14 12:14:26,843 DEBUG [VideoDeliveryEngine] Delivering file '01x02.wmv' in native format
2011-09-14 12:14:26,867 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2011-09-14 12:14:26,867 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 267145323
2011-09-14 12:14:26,867 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-09-14 12:14:26,867 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-ms-wmv,Content-Range: bytes 0-267145322/267145323,Content-Length: 267145323,Date: Wed, 14 Sep 2011 16:14:26 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=WMVHIGH_FULL;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,MediaInfo.sec: SEC_Duration=651000;]]
2011-09-14 12:14:26,896 DEBUG [WebServer] I/O error: Connection reset
2011-09-14 12:14:26,907 DEBUG [WebServer] Incoming connection from /10.42.43.20:39239
2011-09-14 12:14:26,908 DEBUG [ResourceTransportRequestHandler] GET /resource/8837/MEDIA_ITEM/WMVHIGH_FULL$0 HTTP/1.0, headers = [Range: bytes=267141120-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 10.42.43.1:8895]]
2011-09-14 12:14:26,908 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.42.43.20
2011-09-14 12:14:26,908 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/10.42.43.20, Profile=Samsung TV / player (C/D-series)'
2011-09-14 12:14:26,908 DEBUG [ResourceTransportRequestHandler] Request for resource 8837 and type 'MEDIA_ITEM' received
2011-09-14 12:14:26,909 DEBUG [VideoDeliveryEngine] Delivering item '8837' for client 'IPAddress=/10.42.43.20, Profile=Samsung TV / player (C/D-series)'
2011-09-14 12:14:26,909 DEBUG [VideoDeliveryEngine] Delivering file '01x02.wmv' in native format
2011-09-14 12:14:26,913 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 4203
2011-09-14 12:14:26,913 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-09-14 12:14:26,913 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-ms-wmv,Content-Range: bytes 267141120-267145322/267145323,Content-Length: 4203,Date: Wed, 14 Sep 2011 16:14:26 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=WMVHIGH_FULL;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-09-14 12:14:27,011 DEBUG [WebServer] Incoming connection from /10.42.43.20:49687
2011-09-14 12:14:27,012 DEBUG [ResourceTransportRequestHandler] HEAD /resource/8837/MEDIA_ITEM/WMVHIGH_FULL$0 HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,Host: 10.42.43.1:8895]]
2011-09-14 12:14:27,012 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.42.43.20
2011-09-14 12:14:27,012 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/10.42.43.20, Profile=Samsung TV / player (C/D-series)'
2011-09-14 12:14:27,012 DEBUG [ResourceTransportRequestHandler] Request for resource 8837 and type 'MEDIA_ITEM' received
2011-09-14 12:14:27,013 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 8837, format WMVHIGH_FULL and profile Samsung TV / player (C/D-series)
2011-09-14 12:14:27,013 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2011-09-14 12:14:27,013 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/x-ms-wmv,Content-Length: 267145323,Date: Wed, 14 Sep 2011 16:14:27 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=WMVHIGH_FULL;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-09-14 12:14:27,029 DEBUG [WebServer] Incoming connection from /10.42.43.20:38680
2011-09-14 12:14:27,029 DEBUG [ResourceTransportRequestHandler] GET /resource/8837/MEDIA_ITEM/WMVHIGH_FULL$0 HTTP/1.0, headers = [Range: bytes=0-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,getMediaInfo.sec: 1,Host: 10.42.43.1:8895]]
2011-09-14 12:14:27,029 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.42.43.20
2011-09-14 12:14:27,030 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/10.42.43.20, Profile=Samsung TV / player (C/D-series)'
2011-09-14 12:14:27,030 DEBUG [ResourceTransportRequestHandler] Request for resource 8837 and type 'MEDIA_ITEM' received
2011-09-14 12:14:27,030 DEBUG [VideoDeliveryEngine] Delivering item '8837' for client 'IPAddress=/10.42.43.20, Profile=Samsung TV / player (C/D-series)'
2011-09-14 12:14:27,031 DEBUG [VideoDeliveryEngine] Delivering file '01x02.wmv' in native format
2011-09-14 12:14:27,045 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2011-09-14 12:14:27,045 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 267145323
2011-09-14 12:14:27,045 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-09-14 12:14:27,045 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-ms-wmv,Content-Range: bytes 0-267145322/267145323,Content-Length: 267145323,Date: Wed, 14 Sep 2011 16:14:27 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=WMVHIGH_FULL;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,MediaInfo.sec: SEC_Duration=651000;]]
2011-09-14 12:14:27,061 DEBUG [WebServer] Incoming connection from /10.42.43.20:52030
2011-09-14 12:14:27,062 DEBUG [ResourceTransportRequestHandler] HEAD /resource/8837/MEDIA_ITEM/WMVHIGH_FULL$0 HTTP/1.0, headers = [getCaptionInfo.sec: 1]]
2011-09-14 12:14:27,062 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.42.43.20
2011-09-14 12:14:27,062 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/10.42.43.20, Profile=Samsung TV / player (C/D-series)'
2011-09-14 12:14:27,063 DEBUG [ResourceTransportRequestHandler] Request for resource 8837 and type 'MEDIA_ITEM' received
2011-09-14 12:14:27,069 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 8837, format WMVHIGH_FULL and profile Samsung TV / player (C/D-series)
2011-09-14 12:14:27,075 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2011-09-14 12:14:27,075 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/x-ms-wmv,Content-Length: 267145323,Date: Wed, 14 Sep 2011 16:14:27 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,transferMode.dlna.org: Streaming,contentFeatures.dlna.org: DLNA.ORG_PN=WMVHIGH_FULL;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000]]
2011-09-14 12:14:27,443 DEBUG [WebServer] I/O error: Connection reset
2011-09-14 12:14:27,455 DEBUG [WebServer] Incoming connection from /10.42.43.20:33630
2011-09-14 12:14:27,455 DEBUG [ResourceTransportRequestHandler] GET /resource/8837/MEDIA_ITEM/WMVHIGH_FULL$0 HTTP/1.0, headers = [Range: bytes=267141325-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 10.42.43.1:8895]]
2011-09-14 12:14:27,455 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.42.43.20
2011-09-14 12:14:27,456 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/10.42.43.20, Profile=Samsung TV / player (C/D-series)'
2011-09-14 12:14:27,456 DEBUG [ResourceTransportRequestHandler] Request for resource 8837 and type 'MEDIA_ITEM' received
2011-09-14 12:14:27,456 DEBUG [VideoDeliveryEngine] Delivering item '8837' for client 'IPAddress=/10.42.43.20, Profile=Samsung TV / player (C/D-series)'
2011-09-14 12:14:27,456 DEBUG [VideoDeliveryEngine] Delivering file '01x02.wmv' in native format
2011-09-14 12:14:27,465 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 3998
2011-09-14 12:14:27,465 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-09-14 12:14:27,465 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-ms-wmv,Content-Range: bytes 267141325-267145322/267145323,Content-Length: 3998,Date: Wed, 14 Sep 2011 16:14:27 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=WMVHIGH_FULL;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-09-14 12:14:27,482 DEBUG [WebServer] Incoming connection from /10.42.43.20:56995
2011-09-14 12:14:27,483 DEBUG [ResourceTransportRequestHandler] GET /resource/8837/MEDIA_ITEM/WMVHIGH_FULL$0 HTTP/1.0, headers = [Range: bytes=267141405-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 10.42.43.1:8895]]
2011-09-14 12:14:27,483 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.42.43.20
2011-09-14 12:14:27,483 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/10.42.43.20, Profile=Samsung TV / player (C/D-series)'
2011-09-14 12:14:27,483 DEBUG [ResourceTransportRequestHandler] Request for resource 8837 and type 'MEDIA_ITEM' received
2011-09-14 12:14:27,484 DEBUG [VideoDeliveryEngine] Delivering item '8837' for client 'IPAddress=/10.42.43.20, Profile=Samsung TV / player (C/D-series)'
2011-09-14 12:14:27,484 DEBUG [VideoDeliveryEngine] Delivering file '01x02.wmv' in native format
2011-09-14 12:14:27,489 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 3918
2011-09-14 12:14:27,489 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-09-14 12:14:27,490 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-ms-wmv,Content-Range: bytes 267141405-267145322/267145323,Content-Length: 3918,Date: Wed, 14 Sep 2011 16:14:27 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=WMVHIGH_FULL;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-09-14 12:14:27,627 DEBUG [WebServer] I/O error: Connection reset
2011-09-14 12:14:27,633 DEBUG [WebServer] Incoming connection from /10.42.43.20:33670
2011-09-14 12:14:27,634 DEBUG [ResourceTransportRequestHandler] GET /resource/8837/MEDIA_ITEM/WMVHIGH_FULL$0 HTTP/1.0, headers = [Range: bytes=16384-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 10.42.43.1:8895]]
2011-09-14 12:14:27,634 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.42.43.20
2011-09-14 12:14:27,634 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/10.42.43.20, Profile=Samsung TV / player (C/D-series)'
2011-09-14 12:14:27,634 DEBUG [ResourceTransportRequestHandler] Request for resource 8837 and type 'MEDIA_ITEM' received
2011-09-14 12:14:27,635 DEBUG [VideoDeliveryEngine] Delivering item '8837' for client 'IPAddress=/10.42.43.20, Profile=Samsung TV / player (C/D-series)'
2011-09-14 12:14:27,635 DEBUG [VideoDeliveryEngine] Delivering file '01x02.wmv' in native format
2011-09-14 12:14:27,644 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 267128939
2011-09-14 12:14:27,644 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-09-14 12:14:27,644 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-ms-wmv,Content-Range: bytes 16384-267145322/267145323,Content-Length: 267128939,Date: Wed, 14 Sep 2011 16:14:27 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=WMVHIGH_FULL;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-09-14 12:14:31,624 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (eth0) and address 10.42.43.1, timeout = 0
2011-09-14 12:14:31,625 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device fc7e3a04-0776-388b-81e5-bc82f315988c
2011-09-14 12:14:33,430 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface wlan0 (wlan0) and address 192.168.1.102, timeout = 0
2011-09-14 12:14:33,430 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device fc7e3a04-0776-388b-81e5-bc82f315988c
2011-09-14 12:14:35,235 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:17
2011-09-14 12:14:44,580 DEBUG [ImageUtils] Starting image resize, size = 391181 bytes
2011-09-14 12:14:47,052 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:fc7e3a04-0776-388b-81e5-bc82f315988c from address /10.42.43.20:1025
2011-09-14 12:14:47,052 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /10.42.43.20:1025
2011-09-14 12:14:47,352 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:fc7e3a04-0776-388b-81e5-bc82f315988c from address /10.42.43.20:1025
2011-09-14 12:14:47,352 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /10.42.43.20:1025
2011-09-14 12:14:47,361 DEBUG [ImageUtils] Returning resized image, size = 6816 bytes
Samsung BD-C5500 And XBOX 360| Windows 7)
Sebanisu
Post Wed Sep 14, 2011 4:28 pm
Re: BD-C5500 Unplayable Quicktime Video File
Okay will just mux them into mkv's. I wonder do you know a command line way to do it? I guess i could just google search. Doing this one file at a time will take a bit :D
Thank you for the help.
Post Wed Sep 14, 2011 4:33 pm
Idem with this wmv file, delivered in native format to the renderer and audio is in first position then video.This file must be remuxed/remapped.
Sebanisu
Post Wed Sep 14, 2011 8:11 pm
# !/bin/bash
for movfile in *.mov
    do
        mkvfile=$(echo $movfile | sed s/mov/mkv/)
        echo "Processing $file with $srtfile and output to $mkvfile"
        mkvmerge -o "$mkvfile" -A "$movfile" -D "$movfile"
    done
I found a bash script for remuxing. And modified it to put the Video before the Audio. When just remuxing it left them in the same order. After doing this everything played fine like you said. I'm 90% sure mkvmerge doesn't work with wmv's i'll do some more Google searches and see about that.
Thanks for the help again.
How to mux wmv to mkv with ffdshow it reorders the streams automatically :D
for wmvfile in *.wmv
    do
        mkvfile=$(echo $wmvfile | sed s/wmv/mkv/)
        ffmpeg -i "$wmvfile" -vcodec copy -acodec copy "$mkvfile"
    done
