[SOLVED] Remote Path Question
Syntax
Post Wed Sep 14, 2011 9:54 pm
Hi All,
Currently using a linux NAS (ClearOS based) which runs the serviio service. The console doesnot work as there's probably no correct graphical interface (X11) but as I managed to start the console from my winXP machine, this is no show stopper yet.
When trying to add folder on the NAS which contain media content I enter a path like \\ClearOS\flex\media
When I press OK i see in the shared folders overview (console) /usr/local/bin/serviio-0.5.2/bin/\\ClearOS\flex\media
Is this normal behaviour?
-Frank
Post Wed Sep 14, 2011 11:13 pm
Re: Remote Path Question
you should enter the path that is 'local' on the NAS, e.g. /mnt/media/video (not a network/UNC path)
Syntax
Post Thu Sep 15, 2011 9:06 pm
[SOLVED] Re: Remote Path Question
zip wrote:you should enter the path that is 'local' on the NAS, e.g. /mnt/media/video (not a network/UNC path)
Apparently you should take into account the install path of serviio on the NAS. My install path is /usr/local/bin/serviio-0.5.2/bin and my media is in /var/flexshare/shares/flex.
So i have to navigate back to the root first! The path in the console that is working is now /usr/local/bin/serviio-0.5.2/bin/../../../../../var/flexshare/shares/flex which is working :P
Thanks!
-Frank
Post Thu Sep 15, 2011 11:30 pm
Re: [SOLVED] Remote Path Question
it should work with just /var/flexshare/shares/flex
Syntax
Post Fri Sep 16, 2011 4:48 am
zip wrote:it should work with just /var/flexshare/shares/flex
Perhaps it should..but when I do that, the result becomes /use/local/bin/serviio-0.5.2/bin/var/flexshare/shares/flex which shows me no media files, when browsing on my tv. :?:
-Frank
