No files in C550
lordinario
Post Fri Sep 16, 2011 1:18 am
No files in C550
Hi All,
First of all... great job on this DLNA server guys!
Now, maybe I'm not setting things properly.
My Samsung C550 Tv sees the server perfectly. The problem is that the folders are all empty.
What i did is add 3 folders to serviio console in the Folders tab.
/media/DATOS/Downloads/Movies
/media/DATOS/Downloads/Series
/home/myuser/Videos
and marked all for sharing movies.
The thing is that i see all the folders there but none od them has any movies in them.
Anything missing? Maybe did not install something else?
Thanks...
And sorry for the newbieness..
Lordi
Post Fri Sep 16, 2011 7:10 am
Re: No files in C550
are the files stored localy6 or on a remote drive ?
* My files (on Local drive) are not scanned
Library population can take up to 24hours to fully finish, so please be patient and file will appear eventually.
* My files (on remote drive) are not scanned
Make sure the user that runs Serviio server/service has got access to the shared folders. If you are on Windows, check that the user running the Windows service has got access. To run the service as a different user go to Services (from the Windows Control Panel → Administrative Tools or typing "Services.msc" in the Run command on Start menu), select Serviio, right-click -> Properties, Log On tab, enter user's details and restart the service.
To access a NAS device the exact same set of credentials must be created on the NAS device. The Windows credentials must be a local user and not a domain user. The user must have "Run As Service" rights. The remote path must be entered as a UNC path in the Serviio Console (e.g. \\server\folder)), mapped drive letters will not work since user running the Serviio service is not aware of your mapped drives.
lordinario
Post Fri Sep 16, 2011 1:33 pm
They are local files.
I'm running Ubuntu. Sorry for not be specific on that.
