I don´t work connection serviioconsole with server FreeNas
rochaf
Post Tue Sep 20, 2011 3:47 am
Log Server
2011-09-20 01:41:55,299 INFO [MediaServer] ----------------------------------------------------------------------
2011-09-20 01:41:55,301 INFO [MediaServer] Serviio DLNA media streaming server v 0.5.2 (rev. 4e3210bd9ff3)
2011-09-20 01:41:55,301 INFO [MediaServer] Petr Nejedly 2009-2011
2011-09-20 01:41:55,301 INFO [MediaServer] http://www.serviio.org
2011-09-20 01:41:55,301 INFO [MediaServer] Java 1.6.0_07-The FreeBSD Foundation
2011-09-20 01:41:55,301 INFO [MediaServer] OS FreeBSD i386 7.3-RELEASE-p6
2011-09-20 01:41:55,301 INFO [MediaServer] File encoding: ISO-8859-1
2011-09-20 01:41:55,301 INFO [MediaServer] ----------------------------------------------------------------------
2011-09-20 01:41:55,526 INFO [RestletServer] Starting Restlet server exposed on localhost:23423
2011-09-20 01:41:55,635 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-09-20 01:41:57,707 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2011-09-20 01:41:58,727 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-09-20 01:41:59,223 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-09-20 01:41:59,593 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-09-20 01:41:59,875 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-09-20 01:42:00,212 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-09-20 01:42:00,465 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-09-20 01:42:00,953 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2011-09-20 01:42:01,024 INFO [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-09-20 01:42:01,879 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-09-20 01:42:03,006 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-09-20 01:42:03,338 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-09-20 01:42:03,614 INFO [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-09-20 01:42:03,752 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-09-20 01:42:03,782 INFO [WebServer] Socket buffer set to 65535 bytes
2011-09-20 01:42:03,851 INFO [WebServer] WebServer starting on port 8895
2011-09-20 01:42:03,867 INFO [Device] Created UPnP Device with UUID: 50b7f2ed-7fc9-30db-9fe2-e820d69cc99d, bound
address: 192.168.2.250
2011-09-20 01:42:03,916 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-09-20 01:42:03,928 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] bou
ndarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN
] startUpSize = [4]
2011-09-20 01:42:03,934 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-09-20 01:42:03,935 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for k
ey [jcs.default.cacheattributes], using default class.
2011-09-20 01:42:03,938 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral
= true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-09-20 01:42:03,938 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.
default.elementattributes], using default class.
2011-09-20 01:42:03,938 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true
, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 131648292
3938, LastAccessTime = 1316482923938, getTimeToLiveSeconds() = -1, createTime = 1316482923938 ]
2011-09-20 01:42:03,941 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.
region.local_resetafterplay.elementattributes], using default class.
2011-09-20 01:42:03,983 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-09-20 01:42:03,983 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attrib
utes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern
= 0 ]
2011-09-20 01:42:03,983 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.
region.local_default.elementattributes], using default class.
2011-09-20 01:42:03,983 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-09-20 01:42:03,983 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [
useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-09-20 01:42:03,984 INFO [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-09-20 01:42:03,984 INFO [CompositeCacheConfigurator] Finished configuration in 52 ms.
2011-09-20 01:42:04,023 INFO [EventDispatcher] Starting EventDispatcher
2011-09-20 01:42:04,028 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-09-20 01:42:04,030 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-09-20 01:42:04,038 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface
sk0 (sk0) and address 192.168.2.250, timeout = 0
2011-09-20 01:42:04,039 INFO [RendererSearchSender] Searching for Renderer devices
2011-09-20 01:42:04,041 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2011-09-20 01:42:30,165 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-09-20 01:42:30,167 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-09-20 01:44:46,402 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-09-20 01:44:46,618 INFO [WebServer] WebServer shutting down
2011-09-20 01:44:46,619 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-09-20 01:44:46,619 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, rem
oving all event subscriptions
2011-09-20 01:44:46,619 INFO [EventDispatcher] Leaving EventDispatcher
2011-09-20 01:44:46,620 INFO [DatabaseManager] Shutting down database
2011-09-20 01:44:46,638 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
Log Console
2011-09-20 00:25:50,893 INFO [ServiioConsole] Starting Serviio Console
2011-09-20 00:25:51,018 INFO [ServiioConsole] Connecting to Serviio REST on 192.168.2.250:23423
2011-09-20 00:26:12,331 WARN [ServiioConsole] Cannot connect to the server to get DB initialization info
2011-09-20 00:26:32,846 WARN [ServiioConsole] Cannot connect to server: Communication Error (1001) - Connection refused: connect
2011-09-20 00:26:32,877 INFO [Messages] Loaded console message bundle for locale: en
2011-09-20 00:26:53,471 WARN [ServiioConsole] Cannot connect to server: Communication Error (1001) - Connection refused: connect
2011-09-20 00:26:56,643 INFO [ServiioConsole] Leaving Serviio Console
serviio.sh
#!/bin/sh
#Serviio start Script ##
DIRNAME=`dirname $0`
PROGNAME=`basename $0`
# OS specific support (must be 'true' or 'false').
cygwin=false;
darwin=false;
linux=false;
case "`uname`" in
CYGWIN*)
cygwin=true
FreeBSD)
linux=true
Linux)
linux=true
#!/bin/sh
cygwin=false;
darwin=false;
linux=false;
case "`uname`" in
CYGWIN*)
cygwin=true
FreeBSD)
linux=true
Linux)
linux=true
esac
# For Cygwin, ensure paths are in UNIX format before anything is touched
if $cygwin ; then
[ -n "$SERVIIO_HOME" ] &&
SERVIIO_HOME=`cygpath --unix "$SERVIIO_HOME"`
[ -n "$JAVA_HOME" ] &&
JAVA_HOME=`cygpath --unix "$JAVA_HOME"`
fi
# Setup SERVIIO_HOME
if [ "x$SERVIIO_HOME" = "x" ]; then
# get the full path (without any relative bits)
SERVIIO_HOME=`cd $DIRNAME/..; pwd`
fi
export SERVIIO_HOME
# Setup the JVM
if [ "x$JAVA" = "x" ]; then
if [ "x$JAVA_HOME" != "x" ]; then
JAVA="$JAVA_HOME/bin/java"
else
JAVA="java"
fi
fi
# Setup the classpath
SERVIIO_CLASS_PATH="$SERVIIO_HOME/lib/serviio.jar:$SERVIIO_HOME/lib/derby.jar:$SERVIIO_HOME/lib/jcs.jar:$SERVIIO_H
OME/lib/concurrent.jar:$SERVIIO_HOME/lib/freemarker.jar:$SERVIIO_HOME/lib/httpcore.jar:$SERVIIO_HOME/lib/jaudiotag
ger.jar:$SERVIIO_HOME/lib/jul-to-slf4j.jar:$SERVIIO_HOME/lib/jcl-over-slf4j.jar:$SERVIIO_HOME/lib/log4j.jar:$SERVI
IO_HOME/lib/sanselan.jar:$SERVIIO_HOME/lib/slf4j-api.jar:$SERVIIO_HOME/lib/slf4j-log4j12.jar:$SERVIIO_HOME/lib/org
.restlet.jar:$SERVIIO_HOME/lib/org.restlet.ext.xstream.jar:$SERVIIO_HOME/lib/xstream.jar:$SERVIIO_HOME/config"
# Setup Serviio specific properties
JaVA_OPTS="-Djava.Net.preferIPv4Stack=true -Dderby.system.home=$SERVIIO_HOME/library -Dserviio.home=$SERVIIO_HOME
-Dffmpeg.location=/usr/local/bin/ffmpeg -Dserviio.remoteHost=192.168.2.250 -Dserviio.boundAddr=192.168.2.250"
# For Cygwin, switch paths to Windows format before running java
if $cygwin; then
SERVIIO_HOME=`cygpath --path --windows "$SERVIIO_HOME"`
JAVA_HOME=`cygpath --path --windows "$JAVA_HOME"`
SERVIIO_CLASS_PATH=`cygpath --path --windows "$SERVIIO_CLASS_PATH"`
fi
# Execute the JVM in the foreground
"$java" -xMX384M $JAVA_OPTS -classpath "$SERVIIO_CLASS_PATH" org.serviio.MediaServer "$@"
Javer version server
java version "1.6.0_07"
Diablo Java(TM) SE Runtime Environment (build 1.6.0_07-b02)
Diablo Java HotSpot(TM) Client VM (build 10.0-b23, mixed mode)
java version console in Windows XP
1.6.0_12
ServiioConsole.exe.vmoptions
FreeNas Version
0.7.2 Sabanda (revision 6694)
Firewall open ports in Server and console 23423
My Tv Sony Bravia KDL-40EX405 view the server but don't list the library why don´t add path the library because the console don´t conection the server.
What's the problem conection console with Server FreeNas ?
Post Tue Sep 20, 2011 9:22 am
Re: I don´t work connection serviioconsole with server FreeN
The server side doesn't accept the remoteHost parameter for some reason:
Check spaces, line endings etc.
rochaf
Post Tue Sep 20, 2011 1:52 pm
I install Frenas and serviio again
What's this error ?
Log server
2011-09-20 11:43:18,130 ERROR [ApplicationInstanceManager] Error connecting to local port for single instance not
ification
2011-09-20 11:43:18,133 ERROR [ApplicationInstanceManager] Operation timed out
java.net.ConnectException: Operation timed out
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(PlainSocketImpl.java:333)
at java.net.PlainSocketImpl.connectToAddress(PlainSocketImpl.java:195)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:182)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:366)
at java.net.Socket.connect(Socket.java:519)
at java.net.Socket.connect(Socket.java:469)
at java.net.Socket.<init>(Socket.java:366)
at java.net.Socket.<init>(Socket.java:209)
at org.serviio.ApplicationInstanceManager.registerInstance(ApplicationInstanceManager.java:105)
at org.serviio.MediaServer.checkForRunningInstances(MediaServer.java:230)
at org.serviio.MediaServer.main(MediaServer.java:89)
2011-09-20 11:43:18,149 INFO [MediaServer] ---------------------------------------------------------------------
2011-09-20 11:43:18,149 INFO [MediaServer] Serviio DLNA media streaming server v 0.5.2 (rev. 4e3210bd9ff3)
2011-09-20 11:43:18,149 INFO [MediaServer] Petr Nejedly 2009-2011
2011-09-20 11:43:18,149 INFO [MediaServer] http://www.serviio.org
2011-09-20 11:43:18,150 INFO [MediaServer]
2011-09-20 11:43:18,150 INFO [MediaServer] Java 1.6.0_07-The FreeBSD Foundation
2011-09-20 11:43:18,150 INFO [MediaServer] OS FreeBSD i386 7.3-RELEASE-p6
2011-09-20 11:43:18,150 INFO [MediaServer] File encoding: ISO-8859-1
2011-09-20 11:43:18,150 INFO [MediaServer] ---------------------------------------------------------------------
2011-09-20 11:43:18,360 INFO [RestletServer] Starting Restlet server exposed on 192.168.2.250:23423
2011-09-20 11:43:18,462 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-09-20 11:43:20,576 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2011-09-20 11:43:21,460 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-09-20 11:43:22,104 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-09-20 11:43:22,477 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-09-20 11:43:22,758 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-09-20 11:43:23,099 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-09-20 11:43:23,358 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-09-20 11:43:23,850 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2011-09-20 11:43:24,059 INFO [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-09-20 11:43:24,770 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-09-20 11:43:26,032 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-09-20 11:43:26,368 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-09-20 11:43:26,640 INFO [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-09-20 11:43:26,755 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-09-20 11:43:26,790 INFO [WebServer] Socket buffer set to 65535 bytes
2011-09-20 11:43:26,872 INFO [Device] Created UPnP Device with UUID: 50b7f2ed-7fc9-30db-9fe2-e820d69cc99d, bound
2011-09-20 11:43:26,871 INFO [WebServer] WebServer starting on port 8895
2011-09-20 11:43:26,925 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-09-20 11:43:26,936 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] bo
undarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [R
UN] startUpSize = [4]
2011-09-20 11:43:26,942 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-09-20 11:43:26,942 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for
key [jcs.default.cacheattributes], using default class.
2011-09-20 11:43:26,946 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLatera
l = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-09-20 11:43:26,946 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs
.default.elementattributes], using default class.
2011-09-20 11:43:26,946 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = tru
e, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1316519
006946, LastAccessTime = 1316519006946, getTimeToLiveSeconds() = -1, createTime = 1316519006946 ]
2011-09-20 11:43:26,950 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs
.region.local_resetafterplay.elementattributes], using default class.
2011-09-20 11:43:26,985 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-09-20 11:43:26,985 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attri
butes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePatter
n = 0 ]
2011-09-20 11:43:26,986 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs
.region.local_default.elementattributes], using default class.
2011-09-20 11:43:26,987 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-09-20 11:43:26,987 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [
2011-09-20 11:43:26,987 INFO [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-09-20 11:43:26,987 INFO [CompositeCacheConfigurator] Finished configuration in 47 ms.
2011-09-20 11:43:27,125 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-09-20 11:43:27,160 INFO [EventDispatcher] Starting EventDispatcher
2011-09-20 11:43:27,161 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-09-20 11:43:27,172 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interfac
e sk0 (sk0) and address 192.168.2.250, timeout = 0
2011-09-20 11:43:27,173 INFO [RendererSearchSender] Searching for Renderer devices
2011-09-20 11:43:27,175 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2011-09-20 11:43:53,310 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-09-20 11:43:53,313 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-09-20 11:44:30,125 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-09-20 11:44:30,341 INFO [WebServer] WebServer shutting down
2011-09-20 11:44:30,341 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-09-20 11:44:30,341 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, re
moving all event subscriptions
2011-09-20 11:44:30,341 INFO [EventDispatcher] Leaving EventDispatcher
2011-09-20 11:44:30,386 INFO [DatabaseManager] Shutting down database
2011-09-20 11:44:30,410 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
Post Tue Sep 20, 2011 2:12 pm
try to add
-Djava.awt.headless=true
to JAVA_OPTS as shown here: viewtopic.php?f=14&t=2060&p=16778&hilit=awt.headless#p16778
rochaf
Post Tue Sep 20, 2011 2:18 pm
I reboot FreeNas. The was solved.
When you get home from work was to test the console
Very Good.
2011-09-20 12:25:37,186 INFO [MediaServer] ---------------------------------------------------------------------
2011-09-20 12:25:37,208 INFO [MediaServer] Serviio DLNA media streaming server v 0.5.2 (rev. 4e3210bd9ff3)
2011-09-20 12:25:37,208 INFO [MediaServer] Petr Nejedly 2009-2011
2011-09-20 12:25:37,208 INFO [MediaServer] http://www.serviio.org
2011-09-20 12:25:37,208 INFO [MediaServer] Java 1.6.0_07-The FreeBSD Foundation
2011-09-20 12:25:37,208 INFO [MediaServer] OS FreeBSD i386 7.3-RELEASE-p6
2011-09-20 12:25:37,209 INFO [MediaServer] File encoding: ISO-8859-1
2011-09-20 12:25:37,209 INFO [MediaServer] ---------------------------------------------------------------------
2011-09-20 12:25:37,685 INFO [RestletServer] Starting Restlet server exposed on 192.168.2.250:23423
2011-09-20 12:25:37,876 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-09-20 12:25:41,640 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2011-09-20 12:25:42,708 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-09-20 12:25:43,210 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-09-20 12:25:43,607 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-09-20 12:25:43,897 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-09-20 12:25:44,237 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-09-20 12:25:44,494 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-09-20 12:25:44,982 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2011-09-20 12:25:45,194 INFO [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-09-20 12:25:45,911 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-09-20 12:25:47,032 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-09-20 12:25:47,507 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-09-20 12:25:47,638 INFO [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-09-20 12:25:48,858 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-09-20 12:25:48,905 INFO [WebServer] Socket buffer set to 65535 bytes
2011-09-20 12:25:49,025 INFO [WebServer] WebServer starting on port 8895
2011-09-20 12:25:49,080 INFO [Device] Created UPnP Device with UUID: 50b7f2ed-7fc9-30db-9fe2-e820d69cc99d, bound
2011-09-20 12:25:49,180 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-09-20 12:25:49,202 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] bo
2011-09-20 12:25:49,209 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-09-20 12:25:49,209 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for
2011-09-20 12:25:49,212 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLatera
2011-09-20 12:25:49,213 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs
2011-09-20 12:25:49,213 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = tru
e, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1316521
549213, LastAccessTime = 1316521549213, getTimeToLiveSeconds() = -1, createTime = 1316521549213 ]
2011-09-20 12:25:49,217 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs
2011-09-20 12:25:49,254 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-09-20 12:25:49,254 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attri
n = 0 ]
2011-09-20 12:25:49,255 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs
n = 0 ]
2011-09-20 12:25:49,256 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-09-20 12:25:49,256 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [
2011-09-20 12:25:49,256 INFO [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-09-20 12:25:49,256 INFO [CompositeCacheConfigurator] Finished configuration in 50 ms.
2011-09-20 12:25:49,665 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-09-20 12:25:49,671 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interfac
2011-09-20 12:25:49,672 INFO [EventDispatcher] Starting EventDispatcher
2011-09-20 12:25:49,680 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-09-20 12:25:49,682 INFO [RendererSearchSender] Searching for Renderer devices
2011-09-20 12:25:49,684 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2011-09-20 12:26:15,805 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-09-20 12:26:15,813 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-09-20 12:27:20,065 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-09-20 12:27:20,285 INFO [EventDispatcher] Leaving EventDispatcher
2011-09-20 12:27:20,285 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, re
2011-09-20 12:27:20,285 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-09-20 12:27:20,285 INFO [WebServer] WebServer shutting down
2011-09-20 12:27:20,285 INFO [DatabaseManager] Shutting down database
2011-09-20 12:27:20,308 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
Solving the problem with the reboot, I need to add the key ?
Post Tue Sep 20, 2011 2:26 pm
it looks like the server just stops (according to the log), the attribute should help
rochaf
Post Tue Sep 20, 2011 2:48 pm
I stop the server. Ok I add the key.
