YouTube
Post Thu Sep 22, 2011 7:58 pm
YouTube
YouTube plugin (Web Resource plugin)
The easiest way to add YouTube feeds to Serviio is by using this Firefox plugin.
This plugin utilises the YouTube API v3, which allows it to browse these resources:
Playlist
Use this URL as the resource URL:
https://www.googleapis.com/youtube/v3/playlistItems?playlistId=PLAYLIST_ID
where PLAYLIST_ID is the id of the required playlist.
Example
URL of the playlist in your browser:
https://www.youtube.com/playlist?list=PLx6bGx4zt6Em-NyeR2FFg3chd2nWx2dUp
https://www.youtube.com/watch?v=Qq8OZyruwik&list=PLx6bGx4zt6Em-NyeR2FFg3chd2nWx2dUp
In all these cases, PLAYLIST_ID is PLx6bGx4zt6Em-NyeR2FFg3chd2nWx2dUp
Videos by id's
https://www.googleapis.com/youtube/v3/videos?id=VIDEO_IDS
where VIDEO_IDS is a comman separated list of video IDs.
Example
URL of the video in your browser:
In all these cases, VIDEO_IDS is Qq8OZyruwik
Most popular videos
https://www.googleapis.com/youtube/v3/videos?chart=mostPopular
Channels
https://www.googleapis.com/youtube/v3/channels?forUsername=USER_NAME
https://www.googleapis.com/youtube/v3/channels?id=CHANNEL_ID
Search videos
https://www.googleapis.com/youtube/v3/search?q=SEARCH_QUERY
Added 22/9/2011
Updated for 0.6.1 5/1/2012
Updated for 0.6.2 31/1/2012
Updated with profile 46 7/2/2012
Fixed 403 error 29/9/2012
Changed to WebResourcePlugin 26/04/2015 (thanks to Stefan Andersson)
Further additions 12/05/2015 (thanks to Stefan Andersson)
Supports search API 16/05/2015 (thanks to Stefan Andersson)
Updated 04/07/2019
Updated 09/02/2020
Youtube.groovy
(13.68 KiB) Downloaded 15945 times
awaraarawa
Post Fri Sep 23, 2011 8:32 pm
Re: YouTube
So, how does this get installed?
I thought all I had to do was to copy the groovy file into the C:\Program Files\Serviio\plugins folder. I have copied the file while Serviio is running as well as when not running but with no change. I have waited for it to show up overnight. Is there an additional step I need to do before it shows up? All I see under the online tab is the Online RSS/Atom Feed only.
My config is WHS v1 on Acer Easystore. DLNA is operational and other locally stored files are visible and viewable.
Would appreciate a clue or two! Thanks.
Cheers
Post Fri Sep 23, 2011 10:15 pm
Re: YouTube
You now need to enter a YouTube RSS feed URL, examples are here: viewtopic.php?f=23&t=3279
awaraarawa
Post Sat Sep 24, 2011 1:07 am
Re: YouTube
OK, got it. I tried the most viewed YouTube sample URL and it seems to work.....a number of YouTube videos were listed for the URL (http://gdata.youtube.com/feeds/api/stan ... time=today) listed. However, I could not get a Hulu URL to work...does that mean I need a plugin for Hulu and thus the Empty results for it?
One more issue - While I can view the YouTube results on my non-DLNA LG TV via a DLNA capable LG BD 670 blue ray player, I am having trouble playing them. This DLNA blue ray player is connected via Ethernet cable to my home network to which the WHS server is also connected. When I play the video, the result is quite bad, one frame a second - not quite a video.....extreme stutter would be an understatement.
Obviously, I am missing something else in the configuration / setup. I manually entered the renderer profile and selected the LG TV / Player profile. Should I let the application discover the player rather than setting it up manually? Switching to a generic DLNA profile did not make any difference in the results either. The YouTube video plays fine on my laptop without a problem, so the issue is not with the video.....internet connection is fast and stable via cable @ around 18Mbps. However, the player appears to be having bad buffering issues. I have MPG videos and JPG photos on the WHS and they play fine via the same setup. So, streaming content from the WHS to the TV is not the issue. Why would the YouTube video channeled via the WHS have a buffering problem?
So, what am I missing with the Serviio configuration? I have changed the Preferred Online Content Quality to LOW from the default of MEDIUM but no change in the results.
Appreciate any assistance/suggestions to get this figured. Thanks.
PS: When adding a new URL for an online source, there is only one source type listed Online RSS/Atom feed.....should other options be showing up here? Is that what is missing?
CraigWally
Post Sat Sep 24, 2011 2:45 pm
Re: YouTube
I can't seem to get this to work
I've added the plugin
entered some url's
But, when selected the content via my panasonic blueray player I get the message
"No files are in this folder"
Post Sat Sep 24, 2011 4:16 pm
Re: YouTube
What does the log say?
CraigWally
Post Sat Sep 24, 2011 10:41 pm
Re: YouTube
Error during feed parsing : Invalid XML: Error on line 7: The entity name must immediately follow the '&' in the entity reference
Post Sun Sep 25, 2011 12:22 am
Re: YouTube
what's the url?
CraigWally
Post Sun Sep 25, 2011 5:24 pm
Re: YouTube
http://www.youtube.com/watch?v=SD1ENnVnMXM
don't laugh - its for the kids :)
Post Sun Sep 25, 2011 5:53 pm
Re: YouTube
you have to use feed URL, not the actual video.
Look here for some examples: viewtopic.php?f=23&t=3279
CraigWally
Post Sun Sep 25, 2011 6:14 pm
Re: YouTube
OK Thanks - I think I understand
Is there a way to get a feed url for a specific video
Post Sun Sep 25, 2011 6:18 pm
Re: YouTube
did you read the linked topic? viewtopic.php?f=23&t=3279#p21886
CraigWally
Post Sun Sep 25, 2011 9:11 pm
Re: YouTube
I did, but I'm still struggling
perhaps if you could write the url I need for the above example
Sorry to be a pain
Post Sun Sep 25, 2011 9:20 pm
Re: YouTube
https://gdata.youtube.com/feeds/api/videos/SD1ENnVnMXM?v=2
CraigWally
Post Sun Sep 25, 2011 9:29 pm
Re: YouTube
Nope - still no joy
Nor with the Chronos example from the other thread
the only ones I can get to work are the most viewed or top rated examples
Post Sun Sep 25, 2011 9:39 pm
Re: YouTube
Actually try http instead of https
http://gdata.youtube.com/feeds/api/videos/SD1ENnVnMXM?v=2
CraigWally
Post Sun Sep 25, 2011 9:50 pm
Re: YouTube
Nope - still no joy
I'm off to bed
I'll keep trying tomorrow
sonc44
Post Mon Sep 26, 2011 3:45 am
Re: YouTube
The below will show the Channels 5 public uploads
http://gdata.youtube.com/feeds/api/user ... be-profile
sucka_punch
Post Mon Sep 26, 2011 11:00 am
Re: YouTube
Does the videos automatically refresh?
I set the video expiry interval to 6 hours. But there are still the same videos in the feed as yesterday even if there should be some new available.
Thanks in advance.
Post Mon Sep 26, 2011 11:49 am
Re: YouTube
serviio refreshes it. if the feed XML stays the same, I don't know, you can try opening it in a browser and compare the feed contents to what is on the website itself
Return to Available plugins
