Subtitles support
gustavoas
Post Fri Jun 25, 2010 6:02 pm
Re: Subtitles support
rleonardi wrote:Maybe it´s no big deal, but my TV is in Brazil with latest firmware. Could it be any different behaviour due to different locations?? :roll:
I'm in Brazil, my TV is a 55C6900 and unfortunatelly subtitles are not working...
luiz_borges
Post Sun Jun 27, 2010 3:26 pm
I'm also in Brazil (fala moçada!) and my BD-C5500 is not playing subtitles in Serviio.
I have the last firmware installed. PCSM show subs fine.
Luiz Borges
rleonardi
Post Sun Jul 04, 2010 3:06 am
Hi everybody. I could only come back to the tests today.
Well, unfortunatelly the results were not what I expected. Due to a mess of DLNA servers in my computer - I had TVersity, PCSM, WMS, Twonky and some others installed - I renamed all instances of these servers and made a huge confusion of who is who when accessing them from my TV. So, when I thought I was accessing Serviio I was actually accessing other software. Today, when most trial ended and I uninstalled them I realized my mistake.
So, I'm really sorry for the disinformation service I did.
** Serviio is NOT WORKING FOR SUBTITLES with my TV**
To try to redress for my error, I've made a Wireshark log using WildMediaServer, which get subtitles working. This log is quite big and is from the moment I connected and started browsing the server, then played a few seconds of the movie with the subtitles on till I close the connection to the server.
Here is the log file.
Again, sorry for the misinformation. I'm available to any test you need me to do.
B.R.
Rafael Leonardi
vhs
Post Wed Jul 07, 2010 1:58 pm
Hi...im having the same problem with my PS50C7000, everithing goes perfect but no subtitles...
Any expecting date to this fix?
tjcanto
Post Thu Jul 08, 2010 7:08 pm
It took me more time than expected to understand what to do and to do it.
I attach you the first 600 lines of
I hope it is what you need.
mezzmo600.zip
Whireshark tcpdump libpcap
(98.57 KiB) Downloaded 618 times
rleonardi
Post Sat Jul 10, 2010 4:29 am
zip wrote:Regarding rendering subtitles, it's not possible with FFmpeg (so far). YOu can hack your TV firmware though (SammyGo) to enable changing subtitle size,color, etc.
:( I just saw on SamyGo site that there's no support for C Series :cry: :cry:
svb
Post Thu Jul 15, 2010 9:54 am
Hi Zip. I'm currently also facing missing subtitles issue, with LE40C650. I'm not sure if you are currently working on it or not, but I'd like to offer my help at logging and testing, in case you need it.
So far I have checked the logs others have uploaded and I found a slight differences in DIDL-Lite content of someting I believe to be a relevant part of the communication. Seems Mezzmo has his sec:CaptionInfoEx tag directly after res tag and Serviio has an other res tag inbetween. Might it be Samsung supposes his proprietary sec:CaptionInfoEx tag applies to the directly preceeding res tag? I haven't found a DIDL-Lite specification so I'm not sure if the tag order could be significant, and I'm not even sure I have picked the right part of the log. But I hope it will be a little bit useful for you though.
Some links I found when I ran out of my wits:
http://osdir.com/ml/general/2010-04/msg08386.html
http://forum.synology.com/enu/viewtopic.php?f=3&t=21443
And the relevant (IMHO) part of logs:
<DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/" xmlns:av="urn:schemas-sony-com:av" xmlns:dlna="urn:schemas-dlna-org:metadata-1-0/" xmlns:sec="http://www.sec.co.kr/">
  <item id="all*pn:0*pn:11*pn:25*fv:721" parentID="all*pn:0*pn:11*pn:25*wc:27:41" searchable="0" restricted="1">
   <dc:title>Caprica 1x00</dc:title>
   <upnp:class>object.item.videoItem</upnp:class>
   <dlna:dlnaManaged>0</dlna:dlnaManaged>
   <dc:creator>Unknown Creator</dc:creator>
   <upnp:artist>Unknown Artist</upnp:artist>
   <upnp:album>Caprica</upnp:album>
   <upnp:genre>Unknown Genre</upnp:genre>
   <av:mediaClass>V</av:mediaClass>
   <res nrAudioChannels="2" duration="01:32:20.000" bitrate="132413" sampleFrequency="48000" resolution="624x352" dlna:profileID="MP3" xmlns:dlna="urn:schemas-dlna-org:metadata-1-0/" protocolInfo="http-get:*:video/x-msvideo:DLNA.ORG_PN=MP3;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01700000000000000000000000000000" size="733581312" importUri="http://192.168.1.35:53168/content/all*pn%3A0*pn%3A11*pn%3A25*fv%3A721">http://192.168.1.35:53168/content/all*pn%3A0*pn%3A11*pn%3A25*fv%3A721</res>
   <sec:CaptionInfoEx sec:type="srt">http://192.168.1.35:53168/content/all*pn%3A0*pn%3A11*pn%3A25*fv%3A721.srt</sec:CaptionInfoEx>
   <upnp:albumArtURI dlna:profileID="JPEG_TN" xmlns:dlna="urn:schemas-dlna-org:metadata-1-0/">http://192.168.1.35:53168/content/ti%3ADAE6F66B-745D-46b5-930A-A570F45B8E3E*tt%3A*jpeg_tn*jpeg*jpeg*160*160*24*fv%3A721</upnp:albumArtURI>
   <res dlna:profileID="JPEG_TN" xmlns:dlna="urn:schemas-dlna-org:metadata-1-0/" protocolInfo="http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=01;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=05700000000000000000000000000000" resolution="160x90" colorDepth="24">http://192.168.1.35:53168/content/ti%3ADAE6F66B-745D-46b5-930A-A570F45B8E3E*tt%3A*jpeg_tn*jpeg*jpeg*160*160*24*fv%3A721</res>
   <dc:date>2010-02-01T18:31:27</dc:date>
  </item>
</DIDL-Lite>
<DIDL-Lite xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:dlna="urn:schemas-dlna-org:metadata-1-0/" xmlns:sec="http://www.sec.co.kr/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/">
  <item id="V_F#FOL_R3$MI138" parentID="V_F#FOL_R3" restricted="1">
   <dc:title>Avatar.Featurette Creating.the.World.of.Pandora.1080P.H264.AAC2.0</dc:title>
   <dc:date>2010-01-24</dc:date>
   <upnp:genre>Unknown</upnp:genre>
   <res duration="0:22:55.000" protocolInfo="http-get:*:video/x-mkv:DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=81100000000000000000000000000000" resolution="1920x1080" size="1649087264">http://192.168.79.150:8895/resource/138/MEDIA_ITEM</res>
   <res protocolInfo="http-get:*:smi/caption:*">http://192.168.79.150:8895/resource/138/SUBTITLE</res>
   <sec:CaptionInfoEx sec:type="srt">http://192.168.79.150:8895/resource/138/SUBTITLE</sec:CaptionInfoEx>
  </item>
</DIDL-Lite>
Post Thu Jul 15, 2010 10:12 am
Hi, yes I'm working on it. The position of the element doesn't matter. In fact the TV knows about the subtitle resource and makes attempt to load it - but then closes the connection. So there will be more likely some HTTP communication problem (e.g. missing header) that I'm trying to tackle now.
JKJudgeX
Post Tue Jul 20, 2010 3:45 am
Is there any temporary workaround to get subtitles working on a Samsung Series B TV from an MKV file?
I mean, even a simple way to convert using anyvideoconverter that would keep the subtitles intact? I'm getting kind of desperate here.
Post Tue Jul 20, 2010 8:22 am
It works with B series - from an external .srt file that is. If you want internal subtitles to play you'll need a tool that will extract the subtitles information from the mkv and save it as srt.
JKJudgeX
Post Tue Jul 20, 2010 11:47 pm
What is a good tool for this purpose? Everything I've tried pulls out subtitles that are badly timed from an mkv... :( ... and also i can leave the file type as mkv and it will still handle an srt the same way?
thanks in advance.
Post Wed Jul 21, 2010 8:32 am
JKJudgeX wrote:What is a good tool for this purpose?
Never used one, try googling...
Yes
jan.daniel
Post Wed Jul 21, 2010 9:09 am
I am using MKVextract 1.6.4.1
homepage here www.matroska.org, but download doesn"t work
so download it from http://www.videohelp.com/tools/MKVExtractGUI
luiz_borges
Post Sat Jul 24, 2010 3:09 am
zip, I have a Blu-ray player Samsung BD-C5500, do you want me to make any tests with it? I can tell now that serviio don't show any subs, but PC Share Manager does. Do you want me to test with another program? If so, how? Do you have any idea why the subs aren't working?
Luiz Borges
zoijar
Post Sat Jul 24, 2010 9:53 am
Do you still need more logs/debug info for this? I can try and capture it in a bit (C6500)
geevh
Post Sun Jul 25, 2010 10:30 pm
Subtitles are working fine with minidlna (http://minidlna.sourceforge.net/), but not with Serviio. Perhaps you can check how they did it?
BTW I'm on Gentoo Linux amd64 and streaming to a Samsung UE40C6000 with latest update (v. 1010). I'm using the Samsung WiselinkPro (C-series) setting
kairoh
Post Sun Aug 08, 2010 11:12 am
Hi, for my first post, i'd say i really enjoy Serviio.
Second for this problem, i've made some test with other server.
The only that has worked well, was Mezzmo (trial).
Here are the tcp dumps.
GET <...> HTTP/1.0
HOST: <...:...>
ACCEPT-LANGUAGE: en-us
getcontentFeatures.dlna.org:1
transferMode.dlna.org:Background
HTTP/1.1 200 OK
Server: Windows, UPnP/1.0 DLNADOC/1.50, Mezzmo Media Server/2.1.8.0
Date: Sat, 07 Aug 2010 23:31:11 GMT
Last-Modified: Sat, 07 Aug 2010 23:31:11 GMT
Connection: keep-alive
Expires: Sat, 07 Aug 2010 23:31:11 GMT
Accept-Ranges: bytes
Cache-Control: no-cache
Content-Length: 31110
transferMode.dlna.org: Background
Content-Type: text/srt
HTTP/1.1 200 OK
Server: Windows XP UPnP/1.0 Serviio 0.4.1
Date: Sun, 08 Aug 2010 09:26:32 GMT
Cache-control: no-cache
Content-Type: smi/caption
Pragma: no-cache
contentFeatures.dlna.org: DLNA.ORG_OP=00;DLNA.ORG_CI=0;
I try changing "Content-Type" from "smi/caption" to "text/srt".
I think these is useless header : contentFeatures.dlna.org
Mezzmo seems to always use keep-alive connection (provided with HTTP 1.1).
Hope this will help you.
If you share me your code, maybe i could implement it.
Thanks!
Serviio WebUI console developer : New Homepage | Support | Project | Issues
Samsung UA32C6600 | WinXP / Ubuntu 11.10 | Samsung Galaxy S | Freebox v6
gustavoas
Post Fri Aug 13, 2010 11:52 pm
TVMobili works flawlessly with Series C, including subtitle, it's free and allows sharing media with friends. But it does not have the cataloging capabilities from Serviio...
luiz_borges
Post Sat Aug 14, 2010 12:42 am
In my Blu-ray player C5500 the subtitles also don't work with TVMobili.
Luiz Borges
gustavoas
Post Sat Aug 14, 2010 2:55 am
luiz_borges wrote:In my Blu-ray player C5500 the subtitles also don't work with TVMobili.
Luiz Borges
Did you try to get in contact with the developer? The available version also didnt show the subtitles on my Series C TV but the developer sent me a dev build and it has worked very well. :-)
Not sure though if it's working for a BD player
Return to Feature requests
Users browsing this forum: No registered users and 51 guests
