blip.tv
DizTortion
Post Sat Sep 24, 2011 8:29 pm
blip.tv
although blip.tv is partially supported out of the box, I had some problems with async audio (on my panasonic TV) or too fast video playback (on my PS3), missing thumbnails and the option to select resolution didn't work. So I built this plugin wich fixes all these problems (at least for me ;-)).
To add a video from a specific member of blip.tv enter an URL like:
http://blip.tv/{username}/rss
To install this plugin just copy the attached file to your serviio plugin directory.
For x86:
C:\Program Files\Serviio\plugins
For x64:
C:\Program Files (x86)\Serviio\plugins
Please let me know if it works for you.
Greetings
DizTortion
BlipTVUrlExtractor.groovy
(3.69 KiB) Downloaded 1218 times
Major Tom
Post Sat Oct 01, 2011 7:59 pm
Re: blip.tv
Thanks! Works fine on my Sony TV (it was also supposed to be supported out of the box but doesn't work properly).
rrutkows
Post Tue Oct 04, 2011 10:17 am
Re: blip.tv
DizTortion wrote:Please let me know if it works for you.
It works great. Thanks! Blip videos are unplayable on Panasonic G20 unless your plugin is installed.
There is one minor issue, though. Only 8 videos are available from from http://blip.tv/redlettermedia/rss. Without the plugin all 20 are listed.
rrutkows
Post Tue Oct 11, 2011 6:20 pm
Re: blip.tv
rrutkows wrote:There is one minor issue, though. Only 8 videos are available from from http://blip.tv/redlettermedia/rss. Without the plugin all 20 are listed.
The remaining ones are not added to library because of the following error:
WARN  [FeedUpdaterThread] Failed to retrieve feed item information for . It might not play.
   at org.serviio.library.online.metadata.FeedUpdaterThread.updateLazyLoadedProperties(FeedUpdaterThread.java:188)
   at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:93)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.validateCodecsFound(FFmpegMetadataRetriever.java:318)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:68)
   at org.serviio.library.online.metadata.FeedUpdaterThread.updateLazyLoadedProperties(FeedUpdaterThread.java:169)
   ... 1 more
Phil.cdtpixel
Post Fri Oct 28, 2011 3:13 pm
Re: blip.tv
DizTortion
Post Tue Nov 01, 2011 11:32 pm
Re: blip.tv
thank you for your feedback. It is very much appreciated.
I investigated the issue rrutkows was describing and found a minor bug in my code. The problem occurred for videos that don't provide the requested quality (configured in Serviio Console).
This specific issue should be fixed now. But it still doesn't accept all the videos from rrutkows feed so maybee I'll have to dig somewhat deeper.
Please try the updated version in the first thread post.
JerseyJoe123
Post Sat Feb 11, 2012 10:45 pm
Re: blip.tv
I'm running into a bit of a issue that I can't figure out. I have installed the latest blip.tv groovy plugin and have added this RSS feed to Serviio:
It works fine. However, when I add this feed:
http://blip.tv/blackboxtv/rss
I get the error:
java.io.IOException: Cannot parse resource from http://blip.tv/blackboxtv/rss. Message: Error during feed parsing, provided URL probably doesn't point to a valid RSS/Atom feed. Message: Invalid XML
What am I missing here? What is interesting is that when I plug the feed URLs into http://feedvalidator.org or http://validator.w3.org, neither of them validate successfully.
Ideas?
Post Sat Feb 11, 2012 11:34 pm
Re: blip.tv
they would not validate that why the plugin is required to get the actual rss feed from the link. ;)
JerseyJoe123
Post Sun Feb 12, 2012 3:42 am
Re: blip.tv
Understood. Do you get the same error with the link I'm having issues with? The one included in the first post works OK for me, and I do have the plugin installed
DizTortion
Post Sun Jun 03, 2012 1:39 am
Re: blip.tv
I'm still visting from time to time :)
Are there any bugs left since my last update? Not that much feedback since then :) Please let me know
debragon
Post Wed Jun 06, 2012 11:49 am
Re: blip.tv
Thanx so much! Works smoothly.
Return to Available plugins
