MKV & Samsung LE40B650
moleculezz
Post Thu Jul 15, 2010 5:53 pm
I have a few mkv's that work and some that don't.
The one that works:
Codec: H264 - MPEG-4 AVC
Audio: A52 (aka AC3)
The one that doesn't:
Audio: DTS Audio (dts)
So I guess the samsung TV doesn't support dts. So how do I set up transcoding for only the audio?
DMS: QNAP TS-459 Pro+
DMR: Samsung LE40B650 | Sony PS3
Post Thu Jul 15, 2010 10:24 pm
Re: MKV & Samsung LE40B650
Just select Samsung B series profile in the console.
moleculezz
Post Fri Jul 16, 2010 5:06 am
zip wrote:Just select Samsung B series profile in the console.
I do have that already selected.
Post Fri Jul 16, 2010 7:34 am
In that case the transcoding should work. You can turn on detailed logging to see if ffmpeg gets invoked. Also please provide results of: ffmpeg -i "<your mkv with dts>"
moleculezz
Post Sat Jul 17, 2010 5:31 pm
When I did a restart of the serviio service it started working.
Thanks!
