serviio 0.6 and onlinetvrecorder.com files
just updated to 0.6 and its great - again. But then I noticed that just like in the previous version, HD and HQ files recorded at onlinetvrecorder.com wont play. Zip offered a solution last time I had this problem and I almost forgot about having applied it. Scanned through a HDD backup to find the solution and also found the old thread. So if anyone else is having problems with those files on a D-Series Samsung LED you can fix it as follows:
Remove this line from the C/D profile under the <!-- transcode AVI with AVC video --> section:
Problem solved. Reference http://forum.serviio.org/viewtopic.php?f=7&t=2378&p=14016#p14016
