using MKVExtractGUI :(
falconmick
Post Mon Sep 26, 2011 6:23 am
Ok, What do you guys use to extract srt's which serviio can use... Ive tried MKVExtractGUI, but half of my MKV's it doesn't find the subtitles for and I can't watch my animes with subs ;(
falconmick
Post Mon Sep 26, 2011 7:04 am
Re: using MKVExtractGUI :(
also, I am using a Sony SMP-N100, I have found a way to extract that worked on the files that didn't work (MKVCleaver) but the srt's aint working with serviio ;( is there suport for the Sony SMP-N100?
Post Mon Sep 26, 2011 8:59 am
Sony does not support external SRT subtitles
falconmick
Post Mon Sep 26, 2011 9:43 am
There's a sub's button on my controller, so is there no way I can hook up to it?
I know that it's not that simple, I just don't know how sony's interface works (as in the interface serviio uses to send data) maybe serviio could add a feature which while it transcodes the video it places subs? mayyyybeee?
Post Mon Sep 26, 2011 1:27 pm
falconmick wrote:There's a sub's button on my controller,...
Press "sub" button and you'll see the message "Not supported for this interface". Serviio could not solved that ?
WildRushSykes
Post Mon Sep 26, 2011 1:52 pm
i wish ps3 supported external subs and i didnt have to hard code them :cry:
Return to General discussion
