Samsung Galaxy S2 Epic 4g Touch
Blu3Fr0g
Post Sat Sep 24, 2011 11:06 pm
Serviio is an amazing product and I thank you for making it available to the general public and I cannot wait to see what features the next version will bring, I currently have it installed on a HP Lx-195 Windows Home Server v1 device and about two weeks ago I got the Sprint's version of the Samsung Galaxy S2. It comes with Samsung's AllShare client which allows it to be a UPNP/DLNA Client. It shows up in Serviio 5.2 as unknown. I downloaded the UPNP tools and here is the XML File:
<root xmlns="urn:schemas-upnp-org:device-1-0" xmlns:sec="http://www.sec.co.kr/dlna" xmlns:dlna="urn:schemas-dlna-org:device-1-0">
<specVersion>
<major>1</major>
<minor>0</minor>
</specVersion>
<device>
<dlna:X_DLNADOC xmlns:dlna="urn:schemas-dlna-org:device-1-0">DMS-1.50</dlna:X_DLNADOC>
<dlna:X_DLNADOC xmlns:dlna="urn:schemas-dlna-org:device-1-0">M-DMS-1.50</dlna:X_DLNADOC>
<dlna:X_DLNACAP xmlns:dlna="urn:schemas-dlna-org:device-1-0">av-upload,image-upload,audio-upload</dlna:X_DLNACAP>
<deviceType>urn:schemas-upnp-org:device:MediaServer:1</deviceType>
<friendlyName>[Mobile]SPH-D710</friendlyName>
<manufacturer>SAMSUNG Electronics</manufacturer>
<manufacturerURL>http://www.sec.co.kr</manufacturerURL>
<modelDescription>
Provides content through UPnP ContentDirectory service
</modelDescription>
<modelName>SAMSUNG Media Server</modelName>
<modelNumber>1.0</modelNumber>
<modelURL>http://www.sec.co.kr</modelURL>
<UDN>uuid:c230ae7b-cb9c-326f-8479-d7ace7d5bae5</UDN>
<iconList>
<icon>
<mimetype>image/jpeg</mimetype>
<height>48</height>
<width>48</width>
<depth>24</depth>
<url>/icon/icon.jpeg</url>
</icon>
<icon>
<height>120</height>
<width>120</width>
<depth>24</depth>
<url>/icon/icon2.jpeg</url>
</icon>
<icon>
<mimetype>image/png</mimetype>
<height>48</height>
<width>48</width>
<depth>24</depth>
<url>/icon/icon.png</url>
</icon>
<icon>
<width>120</width>
<depth>24</depth>
<url>/icon/icon2.png</url>
</icon>
</iconList>
<serviceList>
<service>
<serviceType>urn:schemas-upnp-org:service:ContentDirectory:1</serviceType>
<serviceId>urn:upnp-org:serviceId:ContentDirectory</serviceId>
<SCPDURL>cds.xml</SCPDURL>
<controlURL>ContentDirectory_control</controlURL>
<eventSubURL>ContentDirectory_event</eventSubURL>
</service>
<service>
<serviceType>urn:schemas-upnp-org:service:ConnectionManager:1</serviceType>
<serviceId>urn:upnp-org:serviceId:ConnectionManager</serviceId>
<SCPDURL>cms.xml</SCPDURL>
<controlURL>ConnectionManager_control</controlURL>
<eventSubURL>ConnectionManager_event</eventSubURL>
</service>
</serviceList>
</device>
</root>
Do I also need to provide a detailed log in order for someone to help me build a profile that will properly transcode mkv and other unsupported video files to the proper format? Currently it connects to the server and will stream AVI files but MKV files result in an unsupported format error, even though the built in media player will play them if they are stored locally on the device. I have tried just changing the profile in the serviio console but that really does not seem to make any difference that I can see. :D
Post Sat Sep 24, 2011 11:28 pm
Re: Samsung Galaxy S2 Epic 4g Touch
what OS is it running ?
Blu3Fr0g
Post Sat Sep 24, 2011 11:30 pm
Cerberus wrote:what OS is it running ?
I should have mentioned that, it is running Android 2.2.3. This phone is truly amazing with a huge 4.5 Super Amoled + screen!
Post Sat Sep 24, 2011 11:33 pm
download skifta to the phone and rockplayer lite both availible from market place and then use that to stream to it will work right out of teh box on ALL formats :)
Post Sun Sep 25, 2011 12:32 am
based on that description it looks like the software is actually a MediaServer (like Serviio) and not client. Maybe it's both but it announces itself like a server. Is there nothing else in the DeviceSpy tool?
Blu3Fr0g
Post Sun Sep 25, 2011 1:02 am
Cerberus wrote:download skifta to the phone and rockplayer lite both availible from market place and then use that to stream to it will work right out of teh box on ALL formats :)
Thank you for your response and while this solution would work it is not the correct solution I am working for. Samsung provides a Windows based DLNA/UPNP server package for use in streaming software to their devices and I could use that out of the box with minimal configuration. I chose to use Serviio instead of Twonky or the Samsung product because of the features in Serviio. For the same reason I am trying to get the Samsung All Share software to work correctly with the Serviio server software. Ultimately this particular project is a learning experience for me in preparation for using this in an corporate environment.
Post Sun Sep 25, 2011 1:07 am
Blu3Fr0g wrote: For the same reason I am trying to get the Samsung All Share software to work correctly with the Serviio server software.
you WONT get it to work, it useless that why so many people are using serviio and not the standard samsung all share software. I have given you a solution that works.
Now i can go into many reason why you will fail to get it to work on ANY media server and that the amout of files types you can use with it will be so limited you have to encoded every video file in such a way that teh software lieks to get it to work, or you can follow my advise and get it working in seconds on any7 file type you can throw at it.
Blu3Fr0g
Post Sun Sep 25, 2011 2:10 am
zip wrote:based on that description it looks like the software is actually a MediaServer (like Serviio) and not client. Maybe it's both but it announces itself like a server. Is there nothing else in the DeviceSpy tool?
I will export the two settings in the device / spytool and see what I can come up with for you.
Blu3Fr0g
Post Sun Sep 25, 2011 2:21 am
Amazingly enough it seems to work fine with everything except MKV. And other threads in these very forums suggest that there is something in the way Serviio tells the AllShare client what type of video it is. I will try the options you mentioned above and see how well it works as the combination of UPNPlay and any player resulted in choppy video on the end device.
Blu3Fr0g
Post Sun Sep 25, 2011 3:27 am
There was part of me that was hoping this would work better then UPNPlay and Vplayer which was very choppy, and unfortunately it was still choppy. The main reason I was hoping to get the allshare working was in the hopes it would somehow transcode the video and potentially reduce the bitrate or just make it less choppy through transcoding. Serviio does an amazing job sending to the PS3, although it seems to take forever for new files to be seen by the PS3 and thus playable but that is another issue.
Post Sun Sep 25, 2011 3:38 am
choppyness is more likely to be your network than the apps on your phone, as i have personaly tested them with serviio 0.6 and they run perfectly fine.
Blu3Fr0g
Post Sun Sep 25, 2011 8:42 pm
Cerberus wrote:choppyness is more likely to be your network than the apps on your phone, as i have personaly tested them with serviio 0.6 and they run perfectly fine.
I could believe that if it were any other network besides my own. I am running a gigabit backbone with business class rated switches and at the time of purchase the best rated Simultaneous Dual Band Wireless Router from Linksys. I get good signal on the device itself and have no problem streaming to a Notebook using DLNA/UPNP when connected wired or wireless from the same server. Having searched and read the forums here as well as some Android forums I am beginning to think it is the device or the players themselves as I am not the only one to seemingly have this issue. The one change I do plan to make in the very near future is to add another Wireless Router to the mix configured as a Wireless Access Point to enhance the signal I get in the most distant areas of my house.
Blu3Fr0g
Post Sun Sep 25, 2011 9:32 pm
You are correct, it acts as both allowing me to share media on the device as well as stream media from other compliant devices.
Base URL   http://172.16.69.14:33004/
Device icon   Present, 120x120
Device URN   urn:schemas-upnp-org:device:MediaServer:1
Embedded devices   0
Expiration timeout   1800
Friendly name   [Mobile]SPH-D710
Has presentation   False
Interface to host   172.16.69.210
Manufacturer   SAMSUNG Electronics
Manufacturer URL   http://www.sec.co.kr
Model description   Provides content through UPnP ContentDirectory service
Model name   SAMSUNG Media Server
Model number   1.0
Model URL   http://www.sec.co.kr/
Presentation URL
Product code
Proprietary type
Remote endpoint   172.16.69.14:33004
Serial number
Services   2
Standard type   MediaServer
Unique device name   c230ae7b-cb9c-326f-8479-d7ace7d5bae5
Version   1.0
This is what is listed when I highlight the link in the DeviceSpy. There are two sub-entries containing schemas. If you like I can copy and past those as well. Another thread you linked to or was linked to in the one you linked to said that the Samsung client expected a particular response for mkv containers in order for it to work.
http://forum.serviio.org/viewtopic.php?f=5&t=741#p15146 wrote:Try this:
<MediaFormatProfile mime-type="video/mkv">MATROSKA</MediaFormatProfile>
and then you provide the following profile:
zip wrote:Try this profile:
<Profile id="20" name="VPlayer" extendsProfileId="1">
        <MediaFormatProfiles>
        </MediaFormatProfiles>
I added this text to the profile.xml file just above the line that says Do Not Edit and then saved it and restarted the server via the Start Menu entries and the console and do not see a new profile. Granted this may be User Error on my end.
Post Mon Sep 26, 2011 9:12 am
Are you using the Samsung profile? It might work, at least is behaves the same way as the server from Samsung.
Post Mon Sep 26, 2011 3:47 pm
Blu3Fr0g wrote:I added this text to the profile.xml file just above the line that says Do Not Edit and then saved it and restarted the server via the Start Menu entries and the console and do not see a new profile. Granted this may be User Error on my end.
After profiles.xml modifications, you need to restart the serviio service, not the serviio server, are we agree?
Post Mon Sep 26, 2011 6:45 pm
same thing illico ;) as alot of user wont understand what service means, i quite often tell then to " resart the serviio server completely " or if they really struggle " restart the pc running serviio " english is a great language so many words basicly meaning the same thing :)
Blu3Fr0g
Post Mon Sep 26, 2011 11:41 pm
Aaah thank you. I restarted the sever and saw nothing. I then restarted the computer because restarting the service failed and I could not get the server to start. So I undid the changes I made (I renamed the xml file before saving the changes so all I had to do was delete the modified one and rename the original.) and everything went back to the way it was.
I then tried copying a mkv file directly to my HTC View 4g tablet and playing it with every player on the market that said it could play MKV. Keep in mind the file plays fine off the sd card on my Notebook, but was very choppy on my tablet. None of the players claiming to support hardware decoding could use hardware decoding to decode it. So then in a fit of frustration, I randomly selected another MKV file via Serviio and started streaming it and it streamed fine. Switched back to one of the previous ones that seemed to be choppy and it was still choppy. I am now in the process of using the guide in zip's signature to identify the video's makeup to see if I can then either avoid videos encoded in this method or create a profile for my HTC View that will transcode MKV files encoded in this format, if that is possible.
Cerberus: I downloaded and started using Skifia and it appears to be a much better DLNA Transport (is that the right term?) then UPNPlay. Thanks for the recommendation. Is your name from the Aardvark? :)
Cereb
Post Tue Sep 27, 2011 12:03 am
Blu3Fr0g wrote:Aaah thank you. I restarted the sever and saw nothing. I then restarted the computer because restarting the service failed and I could not get the server to start. So I undid the changes I made (I renamed the xml file before saving the changes so all I had to do was delete the modified one and rename the original.) and everything went back to the way it was.
Cereb
See trust in the DLNA gods ;) and i guess it a DLNA control point.
FYI - my name is from greek myth " Cerberus (Kerberos) = 3 headed dog that guards the gates of hell " :)
Blu3Fr0g
Post Mon Oct 03, 2011 6:48 pm
Problem Videos
Ok, so I figured out through trial and error that not all .264 videos in .mkv containers are the same. I figured out that this video:
Unique ID                        : 232663839308926656675578047163590280766 (0xAF096CEE3B2126A8B3BADE833DE4863E)
Complete name                    : D:\shares\Recorded TV\G H I\Game Of Thrones\Season 1\Game of Thrones S01E01 720p HDTV DD5.1 x264-EbP.mkv
Format                           : Matroska
Format version                   : Version 2
File size                        : 2.66 GiB
Duration                         : 1h 1mn
Overall bit rate                 : 6 187 Kbps
Encoded date                     : UTC 2011-04-19 23:25:19
Writing application              : mkvmerge v4.6.0 ('Still Crazy After All These Years') built on Mar 10 2011 02:50:32
Writing library                  : libebml v1.2.0 + libmatroska v1.1.0
Format profile                   : High@L4.1
Format settings, CABAC           : Yes
Format settings, ReFrames        : 9 frames
Muxing mode                      : Header stripping
Codec ID                         : V_MPEG4/ISO/AVC
Duration                         : 1h 1mn
Bit rate                         : 5 800 Kbps
Width                            : 1 280 pixels
Height                           : 714 pixels
Frame rate                       : 23.976 fps
Bits/(Pixel*Frame)               : 0.265
Stream size                      : 2.44 GiB (92%)
Writing library                  : x264 core 115 r1936 7a9e08d
Encoding settings                : cabac=1 / ref=9 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=tesa / subme=10 / psy=1 / psy_rd=1.10:0.10 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=8 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=12 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc=2pass / mbtree=0 / bitrate=5800 / ratetol=1.0 / qcomp=0.70 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=2:0.60
Language                         : English
Format                           : AC-3
Format/Info                      : Audio Coding 3
Mode extension                   : CM (complete main)
Codec ID                         : A_AC3
Duration                         : 1h 1mn
Bit rate                         : 384 Kbps
Channel(s)                       : 2 channels
Channel positions                : Front: L R
Bit depth                        : 16 bits
Stream size                      : 169 MiB (6%)
Plays choppy via Serviio or even if I copy it locally. I am not sure why it does this and there also may be a problem using Serviio to play it back on my PS3, but I haven't verified that yet. Meanwhile this video:
Unique ID                        : 0 (0x0)
Complete name                    : D:\shares\Recorded TV\G H I\Game Of Thrones\Season 1\game.of.thrones.s01e02.720p.hdtv.x264-ctu.mkv
Format                           : Matroska
File size                        : 1.46 GiB
Duration                         : 56mn 45s
Overall bit rate                 : 3 677 Kbps
Encoded date                     : UTC 2010-02-22 21:41:29
Writing application              : no_variable_data
Writing library                  : no_variable_data
Format profile                   : High@L3.1
Format settings, ReFrames        : 3 frames
Duration                         : 56mn 45s
Bit rate                         : 3 284 Kbps
Height                           : 720 pixels
Bits/(Pixel*Frame)               : 0.149
Stream size                      : 1.28 GiB (88%)
Writing library                  : x264 core 85 r1442tw
Encoding settings                : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=6 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=30 / sliced_threads=0 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=6 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / wpredp=0 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=3284 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language                         : English
Format                           : AC-3
Codec ID                         : A_AC3
Duration                         : 56mn 45s
Bit rate                         : 384 Kbps
Bit depth                        : 16 bits
Stream size                      : 156 MiB (10%)
appears to play fine. My knowledge and understanding of video is only very basic to intermediate and by looking at the output, I am unsure what is different between the two videos and why one plays so much nicer then the others. Any ideas?
[Quote=Cerberus] FYI - my name is from greek myth " Cerberus (Kerberos) = 3 headed dog that guards the gates of hell " [/Quote]
I knew of the greek dog but not it's name. There is a comic book from the 80's called Cerberus The Aardvaark. :)
Post Mon Oct 03, 2011 6:54 pm
Muxing mode : Header stripping <--- there your problem with that file as this is not supported and will cause issues so file will have to be remuxed without header stripping.
yep im deffinately a dirty dog and not an aardvark LOLOL
Users browsing this forum: Baidu [Spider], Bing [Bot] and 5 guests
