0.6 Doesn't work with Popcorn Hour A100/A210
RXP
Post Fri Sep 23, 2011 6:21 pm
Anyone tried it with their Popcorn Hour? It still doesn't seem to work, you enter to play a video and it just boots back to menu.
Only TVersity seems to work with the Popcorn Hour. :|
Post Fri Sep 23, 2011 6:27 pm
Re: 0.6 Doesn't work with Popcorn Hour A100
post detailed log please
RXP
Post Fri Sep 23, 2011 7:26 pm
http://pastebin.com/6YTYwrDn
First time posting a log, filtered out the library updates hope it's all OK.
Edit: Tried different uPnP render profiles (WDTV, Samsung TV etc.) still no joy.
Post Fri Sep 23, 2011 10:26 pm
what's the IP of the player?
RXP
Post Fri Sep 23, 2011 10:56 pm
192.168.1.131
Post Sat Sep 24, 2011 12:27 am
Could you capture packets when you browse for content in serviio via Wireshark? It seems the Browse method is weird and doesn't return anything.
RXP
Post Sat Sep 24, 2011 8:15 am
I'd really like to get this working so sure. What exactly do you want me to do? Install wireshark and dumb a log when I'm browing on the PCH? Won't it be a HUGE log since I got a ton of stuff going on in my NAS? Where can I send it to you?
Edit: I just shutdown all my other servers and the log file is fine. I've uploaded it here: http://www.2shared.com/file/c2iAXLaC/ServiioCap.html
I just started capture then browsed and tried to play a file which didn't play. This time the PCH is 192.168.1.142 as it's my A210 in my living room.
Also when I try and send the file via uPnP to the PCH via my Android phone with Bubble uPnP it results in an error saying "format not supported, supported formats include mp3, m3u (and more video formats). However it obviously works with TVersity so perhaps they've discovered a work around?
Post Sat Sep 24, 2011 1:46 pm
Re: 0.6 Doesn't work with Popcorn Hour A100/A210
can you try it with DirecTV profile?
RXP
Post Sat Sep 24, 2011 4:23 pm
Tried that profile but now it doesn't even show in the list of sources in the PCH.
Edit: It shows up on my A100 but still the same symptom - no playback.
Cinnsealach
Post Sun Sep 25, 2011 11:55 am
Hi Guys,
First post :]
I've been using Serviio for a while now to stream movies to my Samsung C series TV from my Ubuntu server - it's been great; thanks!
On topic:
I have a PCH A110 hooked up to the TV in my study and serviio cannot stream video to it. It populates the folders correctly (movies. series, last viewed etc with the correct files), but for some reason the PCH is listing the files as images rather than video (the icon next to the file name is the one that usually shows next to an image file).
Music works fine. And I can access the movies over smb on the PCH so it's not a big deal for me. Just thought I'd chime in with my experience.
Again, thanks; I've tried a few media servers of the years and Serviio is the best one for me.
All the best,
Andy
Post Sun Sep 25, 2011 2:13 pm
interesting, could someone capture packets browsing on your device using TVersity?
RXP
Post Sun Sep 25, 2011 2:17 pm
Yeah of course, I'll do that tonight when I have some time.
Post Mon Sep 26, 2011 5:52 pm
can you try a profile like this?
<Profile id="21" name="Popcorn Hour" extendsProfileId="1">
<ProtocolInfo>simple</ProtocolInfo>
RXP
Post Mon Sep 26, 2011 5:57 pm
How do I add a custom profile?
Post Mon Sep 26, 2011 6:13 pm
just add this into profiles.xml, before the last </profiles> element
RXP
Post Mon Sep 26, 2011 7:58 pm
No luck with new profile. Exactly the same symptoms - the video files appear to the PCH as image files. When you try and play nothing happens and it reverts back to the menu.
I've uploaded a packet capture of when I browse and start playing with TVersity. The PCH is 192.168.131 my server is 132.
http://www.gogofile.com/Default.aspx?p= ... 58750_3388
Post Mon Sep 26, 2011 10:15 pm
thanks, does it work with any other server?
RXP
Post Tue Sep 27, 2011 3:31 am
Nope only Tversity.
Edit: And it does seem to be an issue with the PCH because even TVersity doesn't work with the 200 series. Many people have mentioned it on the forums but Syabas don't seem to be interested in fixing it. Since you managed to get Serviio serving up mkv's to Samsung TV's which didn't work with any other streamer previously I'm hoping you can work some magic and bypass PCH's buggy server.
I'll become a beta tester if you need one as I've gotten both series of PCH so should be able to fix it.
RXP
Post Thu Sep 29, 2011 1:32 pm
Any updates Zip?
Post Thu Sep 29, 2011 1:46 pm
haven't had time to look further and honestly running out of ideas ;/
