Video 8.avi
JonMuss
Post Mon Sep 26, 2011 5:12 pm
Video 8.avi
Hi, I am glad to see the new version but when I play my AVI file that comes up as an MPEG-TS file on my Panasonic Tv the file is there but it will not play very well it runs to slowly so much so that it almost seems like 'frame by frame'.
I ran ffmpeg.exe and these are my results:
C:\Program Files\Serviio\lib>ffmpeg.exe -i "C:\Documents and Settings\Jon Mussel
white\Videos\Videos\Video 8.avi"
nfig
libavutil 51. 11. 0 / 51. 11. 0
libavcodec 53. 8. 0 / 53. 8. 0
libavformat 53. 6. 0 / 53. 6. 0
libavdevice 53. 2. 0 / 53. 2. 0
libavfilter 2. 25. 0 / 2. 25. 0
libswscale 2. 0. 0 / 2. 0. 0
Input #0, avi, from 'C:\Documents and Settings\Jon Musselwhite\Videos\Videos\Vid
eo 8.avi':
Duration: 00:00:20.36, start: 0.000000, bitrate: 30373 kb/s
Stream #0.0: Video: dvvideo, yuv420p, 720x576 [PAR 64:45 DAR 16:9], 25 tbr,
25 tbn, 25 tbc
Stream #0.1: Audio: pcm_s16le, 48000 Hz, 2 channels, s16, 1536 kb/s
Is the bitrate to high for a wireless connection?
Post Mon Sep 26, 2011 5:57 pm
Re: Playing "mpg-tts" files
please, do not hijack this thread and create a new topic
JonMuss
Post Mon Sep 26, 2011 6:17 pm
Sorry
Post Mon Sep 26, 2011 6:48 pm
Re: Video 8.avi
Topic split...
dvvideo codec is a new video codec supported by serviio.
https://bitbucket.org/xnejp03/serviio/i ... ec-support
https://bitbucket.org/xnejp03/serviio/i ... ideo-codec.
But probably not supported by your TV, what is your model? what is the selected serviio profile?
This video should be transcoded.
Could you enable detailed logging, check the ffmpeg command line used to transcode this file?
Return to Panasonic
