[SOLVED] 0.6 normal files wont work with Samsung LE46C750
badticket
Post Sun Sep 25, 2011 7:45 pm
Dear all,
since 0.6 most files wont work with my Samsung LE46C750 --> "unsupported fileformat" --> "nicht unterstütztes Fileformat".
With former version (0.5.2 ?) works nearly almost perfect 95% of all DNLA files works good.
mkv container Files with codec mpeg4 actually wont work.
The Log file (unter C:programs...bla..serviio.log) wont show singificant entries through the problem...
Could you help me (again ?)
Greetz
Post Sun Sep 25, 2011 8:30 pm
Re: since 0.6 normal files wont work with Samsung LE46C750
ok i have the exactly same tv as you and cannot reproduce these problems, please check you are using teh correct profile for the device.
Samsnag
Post Mon Sep 26, 2011 3:16 pm
I have been waiting for 0.6 with high hopes. Although 0.52 opened without problems, 0.6 wouldn't open until I eventually went into Administrative services and turned it on manually, after having also had to give myself a password log-on for Windows. On my 32D LCD TV I can now play .mp3 audio and .jpg image files - not .mov (format not supported) nor .avi (unsupported codec) nor .wma files. The Samsung Allshare upgrade in July means I can now play .avi files through that. Have I missed something?
badticket
Post Mon Sep 26, 2011 5:29 pm
Cerberus wrote:ok i have the exactly same tv as you and cannot reproduce these problems, please check you are using teh correct profile for the device.
Hi Cerberus,
never touched or handled the "profiles.xml" there was no need before (for me)... after looking for it I found "my" profile
--> Profile id=“7“ name="Samsung TV / player (C/D-series)" extendsProfileId="2">
interesting... looks a little bit as the PMS PS3 renderer files...
I've looked up the forum and googled a little around.... but I can't find the place where I can define "7" as my TV profile...
So my question ist...how can I set Profile id "7" as MY profile ?
Thank you in advance
Greetz
Badticket
P.S. I've enabled the detailed log... may I'll later see there which profile was taken...
Post Mon Sep 26, 2011 5:34 pm
you can select the profile in the serviio console.
badticket
Post Mon Sep 26, 2011 6:16 pm
hmmm... thank you... (I've already searched the console for the profile without seeing it :roll: ... but now... I found it...)
o.k. done... finally found it... :D but I've never recognized the collumn "Profil" for selecting specific entries...
Is there a detailed difference between 0.6 & 0.52 for choosing the profile or not ? Under 0.52 there was NO NEED for me to change and choose the right profile ...
On my PC several DNLA Server programs are running (Samsung Allshare, TVmobili, PS3 PMS, Serviio, Media Player)... So I can choose the right one for the right file... normally PS3 PMS & Serviio have the best use for me. But no media server can play all media files.
May with the selected profile it will even better work since before.
I miss this IMPORTANT hint for choosing different TV Profiles in the FAQ which the most keyusers have included in their footers.
o.k. I'll shutdown my PC and restart Serviio and hopefully the profile brings BACK the old coolness from 0.52
Thank you for your great work with SERVIIO... I love this DNLA server and try to spread it into my friendship and blogs whenever its possible..
Greetz
Badticket
Post Mon Sep 26, 2011 6:22 pm
I've added an image into the Getting started guide.
badticket
Post Mon Sep 26, 2011 6:45 pm
SOLVED !!!
Thank You all !!!
Post Mon Sep 26, 2011 6:55 pm
;) nope 0.52 and 0.6 are exactly the same but i suspect when you upgraded the renderer decided to change its ip on you at same time so it lost its profile :)
Post Mon Sep 26, 2011 6:58 pm
badticket wrote: But no media server can play all media files.
May with the selected profile it will even better work since before. Badticket
If you follow the instructions in my signature on how to get information on a video that will not play and post it here, unless it is in a container or codec, that serviio does not support, we can help you customize your profile to play it.
Zip also takes the customized profiles and if they work for a majority of the people places it in the standard profile.xml that comes with serviio.
Post Mon Sep 26, 2011 7:04 pm
99.9% of files will play with the samsung profile.
badticket
Post Mon Sep 26, 2011 7:35 pm
Re: [SOLVED] 0.6 normal files wont work with Samsung LE46C75
I'll try my x-art videos...hardest stuff for all DNLA server... most of them won't work...
I'am excited to be disabused
Greetz
Edit: wont work...
Media Infos says.... bla.mpeg, format windows media, bitrate 8 106 kbps
Id: 2, Format & Codec ID: wmv2, windows Media Video 8, Bitrate 8.000 kbps, 1.920x1.080, 29,970 FPS, 8 bits (bits/pixel frame 0.129)
serviio seems to be scanning my music database... so the entries for the film are hard to find...
2011-09-26 21:36:50,682 DEBUG [WebServer] Incoming connection from /192.168.0.41:34809
2011-09-26 21:36:50,683 DEBUG [ResourceTransportRequestHandler] GET /resource/151/MEDIA_ITEM/WMVHIGH_FULL$0 HTTP/1.0, headers = [Range: bytes=0-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,getMediaInfo.sec: 1,Host: 192.168.0.26:8895]]
2011-09-26 21:36:50,683 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.41
2011-09-26 21:36:50,683 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.41, Profile=Samsung TV / player (C/D-series)'
2011-09-26 21:36:50,683 DEBUG [ResourceTransportRequestHandler] Request for resource 151 and type 'MEDIA_ITEM' received
2011-09-26 21:36:50,683 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 151 (local)
2011-09-26 21:36:50,683 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 151)
2011-09-26 21:36:50,684 DEBUG [VideoDAOImpl] Reading a Video (id = 151)
2011-09-26 21:36:50,684 DEBUG [VideoDeliveryEngine] Delivering item '151' for client 'IPAddress=/192.168.0.41, Profile=Samsung TV / player (C/D-series)'
2011-09-26 21:36:50,684 DEBUG [VideoDeliveryEngine] Delivering file 'bla....mpeg' in native format
2011-09-26 21:36:50,684 DEBUG [MediaItemDAOImpl] Getting file of media item 151
2011-09-26 21:36:50,685 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 151) as read
Post Mon Sep 26, 2011 7:52 pm
badticket wrote:Hi,
Greetz
Edit: wont work...
yer it will give me the ffmpeg -i info on the file and i wills how you how :)
badticket
Post Mon Sep 26, 2011 8:16 pm
tooks a little time for handling this...
nfig
libavutil 51. 11. 0 / 51. 11. 0
libavcodec 53. 8. 0 / 53. 8. 0
libavformat 53. 6. 0 / 53. 6. 0
libavdevice 53. 2. 0 / 53. 2. 0
libavfilter 2. 25. 0 / 2. 25. 0
libswscale 2. 0. 0 / 2. 0. 0
Seems stream 1 codec frame rate differs from container frame rate: 1000.00 (1000
/1) -> 59.92 (719/12)
Input #0, asf, from 'I:\Blu Ray Special\bla...mpeg':
Duration: 00:05:15.45, start: 0.000000, bitrate: 8105 kb/s
Stream #0.0: Audio: wmav2, 44100 Hz, 2 channels, s16, 128 kb/s
Stream #0.1: Video: wmv2, yuv420p, 1920x1080, 8000 kb/s, 59.92 tbr, 1k tbn,
1k tbc
Post Mon Sep 26, 2011 8:44 pm
badticket wrote:tooks a little time for handling this...
nfig
1k tbc
add this line to the tarnscode section of the samsung profile. (profile.xml)
<Matches container="mpg" vCodec="asf" />
badticket
Post Mon Sep 26, 2011 9:30 pm
where exactly ? after changing the profile ... PC wont start the serviio console and provides an error..
ad first I add the line here.. <Matches container="mpg" vCodec="asf" />
<!-- transcode H264 MP4 files with LPCM audio -->
after that here...
<Video targetContainer="mpegts" targetACodec="ac3" targetVCodec="mpeg2video">
than at both places....
But it breaks up while starting the console.......
<Profile id="7" name="Samsung TV / player (C/D-series)" extendsProfileId="2">
      <Detection>
         <UPnPSearch>
            <FriendlyName>(^TV-\d{2}C\d{3}.*)|(^\[TV\][A-Z]{2}\d{2}D\d{3}.*)</FriendlyName>
            <ModelNumber>(1\.0)|(AllShare1\.0)</ModelNumber>
         </UPnPSearch>
         <HttpHeaders>
            <!-- for BD players -->
            <User-Agent>(.*SEC_HHP_BD-[CD].*)|(.*SEC_HHP_\[HT\][CD].*)</User-Agent>
         </HttpHeaders>
      </Detection>
      <DeviceDescription>
         <ExtraElements>
              &lt;sec:ProductCap&gt;smi,DCM10,getMediaInfo.sec,getCaptionInfo.sec&lt;/sec:ProductCap&gt;
            &lt;sec:X_ProductCap&gt;smi,DCM10,getMediaInfo.sec,getCaptionInfo.sec&lt;/sec:X_ProductCap&gt;
           </ExtraElements>
      </DeviceDescription>
      <ContentDirectoryDefinitionFilter>org.serviio.upnp.service.contentdirectory.definition.SamsungContentDirectoryDefinitionFilter</ContentDirectoryDefinitionFilter>
         <!-- Transcode all h264 video with HIGH/MAIN > Level 4.1 on MPEG-TS stream with MPEG2VIDEO and ac3 audio transcoding -->
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="192">
            <Matches container="avi" vCodec="h264" profile="high" levelGreaterThan="4.2" />
            <Matches container="avi" vCodec="h264" profile="main" levelGreaterThan="4.2" />
            <Matches container="matroska" vCodec="h264" profile="high" levelGreaterThan="4.2" />
            <Matches container="matroska" vCodec="h264" profile="main" levelGreaterThan="4.2" />
            <Matches container="mpegts" aCodec="mp2" />
            <Matches container="mp4" aCodec="lpcm" />
            <Matches container="matroska" vCodec="vc1" />
            <Matches container="ogg" vCodec="mpeg4" />
            <Matches container="3gp" aCodec="amrnb" />
         <!-- transcode MKV with MPEG2 video, remux into mpeg2ts -->
         <!-- transcode AVI with AVC video -->
            <Matches container="flv" />
            <Matches container="ogg" />
         <!-- For dvr-ms files force mpeg2video transcoding to fix monotone timestamps problems-->
         <Video targetContainer="mpegts" targetACodec="ac3" forceVTranscoding="true">
            <Matches container="asf" vCodec="mpeg2video" />
            <Matches container="wtv" />
         <!-- transcode audio only for wmv with wmapro -->
         <Video targetContainer="asf" targetACodec="ac3" aBitrate="256">
            <Matches container="asf" aCodec="wmapro" />
            <Matches container="mp4" />
            <Matches container="flac" />
         </Audio>
Post Mon Sep 26, 2011 9:44 pm
Please DO NOT swear on this forum.
here is the edited code below with line added to allwo your fiel to play, i changed it slight to allow wide range of files, remember to restart serviio service after making the change.
      <Detection>
         <UPnPSearch>
         </UPnPSearch>
         <HttpHeaders>
         </HttpHeaders>
      </Detection>
      <DeviceDescription>
         <ExtraElements>
           </ExtraElements>
        <Matches container="mpeg" vCodec="wmv2" />
         </Audio>
badticket
Post Tue Sep 27, 2011 6:17 am
I've deleted the comment... sorry...
Thank you for your fast an individual support....
Unfortunatly I've further errors with the modified profile.xml
2011-09-27 08:10:46,643 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: org.serviio.profile.ProfilesDefinitionException: Profiles XML file is not valid (according to the schema). Check the log.
   at org.serviio.profile.ProfileManager.loadProfiles(ProfileManager.java:156)
   at org.serviio.MediaServer.main(MediaServer.java:105)
   at com.exe4j.runtime.LauncherEngine.launch(Unknown Source)
   at com.exe4j.runtime.WinLauncher$2.run(Unknown Source)
Caused by: org.serviio.profile.ProfilesDefinitionException: Profiles XML file is not valid (according to the schema). Check the log.
   at org.serviio.profile.ProfilesDefinitionParser.validateXML(ProfilesDefinitionParser.java:693)
   at org.serviio.profile.ProfilesDefinitionParser.parseDefinition(ProfilesDefinitionParser.java:128)
   at org.serviio.profile.ProfileManager.loadProfiles(ProfileManager.java:154)
   ... 7 more
Greetz
Badticket
Post Tue Sep 27, 2011 7:08 am
Cerberus wrote:<Matches container="mpg" vCodec="asf" />
Cerberus, its not the true syntax:
<Matches container="asf" vCodec="wmv2" />
Post Tue Sep 27, 2011 7:21 pm
ok mybad so it would be <Matches container="mpg" vCodec="wmv2" /> then though thats what id put.
Users browsing this forum: Baidu [Spider] and 22 guests
