Uitzending Gemist
Badeend
Post Tue Sep 27, 2011 11:14 am
Uitzending Gemist
I would like a plugin for Dutch television site Uitzending Gemist it has support for RSS feeds.
Post Tue Sep 27, 2011 11:55 am
Re: Uitzending Gemist
can you post URL of a feed?
Badeend
Post Tue Sep 27, 2011 6:36 pm
http://beta.uitzendinggemist.nl/7dagen/vandaag.rss
This is an example of the shows from today.
Borkuz
Post Mon Oct 03, 2011 12:38 pm
if you check the settings so that the video is served in flash in stead of silverlight then the streams are in drm free m4v format, you should some how be able to capture that :D
appiem
Post Tue Oct 04, 2011 5:46 pm
I already make plugin for it, but streaming video not supported yet...
Post Tue Oct 04, 2011 7:30 pm
ok to confirm its a live stream so wont work until the next release of serviio when live streaming will be supported.
Borkuz
Post Wed Oct 05, 2011 9:32 am
appiem wrote:I already make plugin for it, but streaming video not supported yet...
Care to share it? maybe we could learn something from it ;)
appiem
Post Wed Oct 05, 2011 10:48 am
BetaUitzendinggemistNl.groovy
(5.29 KiB) Downloaded 1022 times
MBU
Post Sat Oct 08, 2011 9:24 pm
I tried the uitzendinggemist plugin, but without luck. The log shows the following:
2011-10-08 22:07:34,029 DEBUG [FeedUpdaterThread] Retrieving information about the video stream
2011-10-08 22:07:34,030 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: rtsp://mp4streams.omroep.nl/ceres/1/nos ... a/POW_0038
2011-10-08 22:07:34,030 DEBUG [ProcessExecutor] Starting ffmpeg -i rtsp://mp4streams.omroep.nl/ceres/1/nos ... 111008.m4v
2011-10-08 22:07:35,121 WARN [FeedUpdaterThread] Failed to retrieve feed item information for rtsp://mp4streams.omroep.nl/ceres/1/nos ... 0386110/st
at org.serviio.library.online.metadata.FeedUpdaterThread.updateLazyLoadedProperties(FeedUpdaterThread.java:188)
at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:93)
at org.serviio.library.metadata.FFmpegMetadataRetriever.validateCodecsFound(FFmpegMetadataRetriever.java:318)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:68)
at org.serviio.library.online.metadata.FeedUpdaterThread.updateLazyLoadedProperties(FeedUpdaterThread.java:169)
... 1 more
The above is not complete. I couldn't copy past the right side of the log. The part that is not visible on the screen.
Apparently Serviio slips over the .m4v file format. :?
Any solution?
Post Sat Oct 08, 2011 9:42 pm
it wont work yet as LIVE streams are not suppported
MBU
Post Sat Oct 08, 2011 9:52 pm
Dear Cerbures,
It's not a livestream. The website gives an overview of previous broadcasted programs.
Have a look @ http://beta.uitzendinggemist.nl/7dagen/vandaag.rss
Post Sat Oct 08, 2011 11:52 pm
hmm ok, that not what the plugin maker stated above lol ah well.
Post Sun Oct 09, 2011 2:40 pm
I haven't added support for rtsp protocol yet - it might work, but I cannot confirm that.
Lightning
Post Sat Feb 04, 2012 3:46 pm
Is this already supported?
Return to Plugin requests
